I'm new.
goose
Hello everyone. I am new to the forum. My name is Rob. I am currently undertaking Mark's watch repair course and enjoying it immensely. I have an interest in vintage watches (as I am a bit vintage myself) and enjoy the mechanical aspect of the hobby. I am slowly acquiring tools of different shapes and sizes, most recently a lovely old Elma cleaning machine. It needs a couple of new lids and the heater element is blown, but other than that is is nice. I need to buy cleaning fluids at some point once i figure our which ones to use.
I am currently working in two movements, one an MST 264 ( trying to find a mainspring), and a J693E (has a very stuck screw on the barrel bridge, In fact just about every screw was really hard to remove).
Any way I hope to chat with many of you in the coming years :)
  • 4 weeks later...
Any way I hope to chat with many of you in the coming years 🙂
Morning  Goose. Nice to meet you. Where you from ?
Thanks for the intro @goose welcome to the WRT forum! I'm also relatively new and I'm in the middle of my first service of an Elgin Grade 313 movement which has been stalled for a while as I was waiting for oil and a mainspring winder. Well, my oil arrived today and luckily I picked up an identical 2nd movement so as I disassemble that one it will help me remember how to re-assemble the first one! I've posted some shots of my watches here.
thankyou. I live in Hobart, Tasmania.
On 4/20/2022 at 6:41 PM, watchweasol said:
Hello and welcome to the forum       enjoy
thanks 🙂
On 3/14/2022 at 7:40 PM, oldhippy said:
Thank you for your introduction and welcome to this friendly forum.
We all look forward to your contributions and continued involvement.
L & R are one of the best cleaning and rinse you can get. That is what I always used
Thanks for the welcome and the advice
that's great! wish you 'the best. 🙂
On 3/14/2022 at 11:50 AM, Nucejoe said:
Welcome to WRT forum.
thank 🙂 you
    • Ah so its you thats buying up all the DD calibres 🤨.
    • Hi Richard,  I keep buying CAL.59 movements to practice on 🙂 Not started yet though, I'm gathering tools and building my confidence to start.
    • Problem solved. For some bizarre reason, the hook on the wall of this barrel is not properly centered vertically, but is oddly high on the wall, maybe 3/4 up the way up. When replacing the mainspring, this caused the outer coil to be displaced upwards as well such that it protrudes out of the barrel and caused the barrel lid to not sit quite flush to the barrel. Since this is a motor barrel, the lid is actually the first wheel and inner coil tube/hook all in one piece, with no “snap down” action that would have made the problem more immediately obvious. Maybe with an older mainspring the spring’s end hole was enlarged such that this wasn’t an issue, but hard to say how it ever worked otherwise. Replacing the barrel with one from a different model 1900 where the hook was properly vertically centered allowed the lid to sit flush without mainspring interference and the friction problem went away. The bridge was far too thick to be bent (and isn’t), for those of you thinking that was the problem. Placing the removable arbor in the watch without the rest of the barrel proved that the proper end shake was actually there as long as the overall height of the assembled barrel was correct.
    • You are so true on a lot of what you have said. The main reason for changing the mainspring even if the old one is in good order is because it will take out your thinking that the mainspring is contributing to poor power output or fluctuations in amplitude. If a new spring is fitted that box can be crossed off as a potential source of a problem. Most customers are happy to pay the extra £20 for a new mainspring if they are already parting with a couple of hundred pounds for a service. A new spring is an investment for good running for the future.
    • According to Borel the 814 and 815 use the same escape wheel. It's kind of an oddball being so long.
