Hi everyone, I hope this message finds you well.  I am currently attempting my first re bushing of a clock plate.  I have been using the KWM reamers along with Bergeon bushings in the KWM sizes.  I have to say this system seems to work quite well, as this is the first time I am doing this and so far so good.  The question I have is in regards to the height of the bushing.  The plate I am bushing is just over 1mm, and the bushings sizes I will have to use are 1.4mm and 1.9mm in height.  So my question is, do I need to shorten the bushings to plate height after installation, or is there an acceptable maximum height above plate height?
 When bushings such as yours are thicker than the plate they will need to be filed down to plate thickness and then an oil sink cut.  Ideally with bushing plated you should not be able to tell when its finished that it has been bushed at all. Once done polish the plates.
The old fasioned method was to use a bulls foot file but if you protect the surrounding area and are careful it should be ok.
Thanks for the reply watchweasol!  Thanks for confirming what I thought would be the correct practice.  I've never seen a bulls foot file but the concept is excellent!  I may have to attempt to make one at some point.  Another question I have is I see some people recommending "setting" the bushing by peening it.  Is this a necessary step?
I personally hate when bushings stick out of the plate. I don't mind if they are visible, but they should be flush. Two of my favorite clock brands to work on, Le Castel and Zenith, put bushings in all locations at the factory, nice bronze (Zenith), or bronze or teflon- set in bronze (Le Castel). I just replaced two bushings in a Zenith today, made from beryllium copper, cut to match the originals. Zenith has massive oil sinks and on the arbor side they are cut so a round surface meets the shoulder. Small detail to reduce friction.
Nothing wrong with commercial bushings, but yes, trim them to the plate thickness.  Some file them intalled, but even if a master of the file it's pretty much 100% sure you'll file the plate a bit. If a mid 20th century German movement, no huge issue, they are rough to begin with. But on a nice movement, it's unacceptable (personally also for crappy movements).
If you have a lathe it's quick and easy to adjust a bushing height. Making them is just a little more time...
If you don't, find a piece of metal or even plastic the right thickness, drill and stick your bushing in, file to height, and start saving for a lathe!
Setting the bush using a bearing or round punch is usually not required if the bush is fitted in tight, they are friction fitted. the recomended practise if fitting by hand is to broach from the inside of the plate as the broaches are tapered. When the bush is pressed in from the rear the tapertightens down on the bush and it will dnot move when broaching the bearing surface to fit the pivot.
I've known some who make their bushings from standard brass bar stock, and drill the plate with the corresponding same size drill. Then with plate on a solid steel block, bushing in place, whack it with a round punch and hammer to expand the bush and form the oil sink at the same time- and it hardens the brass. I've tried it and it works, but I much prefer friction fitting.
I have found it easier to reduce the height before installing the bushing into the plate. For this reason I try to purchase the correct height bushing. If the purchased bushing does not have a oil sink then I fit a bushing just a little thicker than the plate and reduce it down while creating the oil sink which helps hide the new bushing.
  • 2 months later...
I’m very lucky in having the bergeon system for bushing can’t complain at all but I do choose their bronze bushes over the brass ones.
i have in the past had long bushes and was taught by my mentor to part fit the bushes if too long and file them down to size whilst still poking out of the plate this reduces the risk of marking the plate.
then push the bush in to seat correctly, also buy some rose cutters as these are brilliant and doing the job.
I noticed nobody mentioned using rose-cutters here. That's what Bergeon supply in their big bushing tool kit. I quite like them - handy for trimming their off-the-shelf bushes and it does actually give a nice finish. Not what I usually use, but worth mentioning nonetheless.
Yes they are very good, I’m in the process of purchasing a couple now as I’ve had to use a 3mm bush in a 1.75mm plate.
I’ve used them before ( mentors ) and they are excellent and negate the risk of scratching the plate with file marks.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
