5 hours ago, rossjackson01 said:
Wow! What a learning curve. 3 strip downs. Could not get the wheels to turn. Finally, after watching a video a number of times I realised that I was not getting the click to be operated on the crown wheel which is on the barrel spring. I had just been placing the crown wheel onto the barrel. No adjustment to make the click operate. Aagh! All the videos of this particular movement are accompanied with music. No verbal's. Got there. The main spring now winds. I can move the Pallet fork and the escapement operates.
As a novice. It is such a sense of achievement. Felt I had to tell you all. Sorry to be a bore.
Regards
Ross
We’ve all been in that position. The sense of excitement is out of this world… as well as the feeling of dread when a part flies off and you spend hours on your knees searching for it on the floor.
The first day of my watch repair, this watch, I lost 2 items. My bride found them 2 days later.  To overcome that problem, as a result from a comment from a member, I purchased a small plastic container from a local supermarket. Spent a few minutes cutting out the front, leaving a lip. I used an old laptop case as the base.
Since install, I think I have have in excess of 20 'pings' on the side walls. A frantic look in the box has been successful on every occasion. Whew!
I also place every item in small containers.
I don't have much space as can be seen. Tools by the computer, watch box against the wall. I store the working box on the printer when not watch repairing. I can look at the computer when repairing. Thank goodness for YouTube.
Thank you to all
Regards
On 3/2/2022 at 4:57 PM, rossjackson01 said:
Looking a the cog part at the top. I notice that the cog does not actually sit in the gem. It looks flat at the top. Is there supposed to be a point?, that inserts into the gem.
EDIT: Oops, didn't realize I wasn't on the last page...
Absolutely! The pivot has been broken off (sensitive little buggers, oftentimes only having a diameter of about 0.1 mm) You'll have to source an intact escape wheel.
Edited by VWatchie
VWatchie.
Done as suggested. Twice. Inexperience ruled.
Regards
Ross
Well, this watch keeps giving, NOT.
I can place the balance and bridge into the pivot. After gently touching, It oscillates very slowly, about 3 per second, and only to 120 degrees. I tighten the screw and it stops.  Been at it over 2 hours. Any comments would be appreciated.
Thank you
Ross
Sounds like there is no end shake on balance staff ( staff's axial end play), in which case end stones push on pivot ends and stop the balance.
Try shimming up the cock to create some end shake, ideal end shake is .02mm or less not including zero.
Thank you Nucejoe.
Does that mean, in layman speak. A shim of metal should be inserted under the balance bridge to raise it. Can shims be purchased? Could the shim be, a piece of an old spring, a washer?
Thank you in anticipation
Ross
A 1×3 mm piece of aluminum foil, placed under the inner side of the cock, is a good start.
Good luck
Tried a shim. Did not work. When bridge is place, tightened or not, the balance only spins for about 30 seconds then stops. I have tried 3 pallet forks. Same thing with all.
Depressed
Ross
Depressed
Ross
Could be a bent pivot then.
Hi Ross to eliminate the rest of the parts remove balance and fork and check the train is free, then fit the fork and add a bit of power is the fork flipping from one banking  to the other when moved, it should be a snap action if ok fit the balance and re try if same remove balance and fork and just fit th balance and puff with the blower does it move freely and oscilate for some time, If so we are looking at checking the balance spring for  concentricity and flat ness and also for the beat error. If its a long way out it will never start.  with no power on the watch check the alignment of the fork , inpulse pin and the position of the fork between the bankings. I should rest in the center.
Do you mean " the balance spin for 30 seconds"   or movements runs for 30 seconds then stops.
My take was , when you have only the balance&cock on the mainplate.
If the movement runs for only 30 seconds, its what weasol says.
All wheels work freely. Everything seems free. Movement runs. 30 seconds then stops. I noticed that the balance hairspring seems to be 'touching' when oscillating. I touched the balance surround with my tweezers. The movement ran for 1 hour then stopped. I touched it again and it has not worked since. The hairspring looks 'wrong'. Lack of skill appears to have knackered the balance. Don't have the skill to repair the balance. May have to delay any further work until I can get a replacement part.
I'm getting really good and wrecking balances and escapements.
Not stopping practicing though.
Regards
Ross
Edited by rossjackson01
grammar
Hi Ross  can you post some close ups of the balance and spring we may be able to help.  Balance spring diagnosis and adjustment is all part of the watch repair life style.
It's not often you lot are wrong. BUT YOU ARE RIGHT AGAIN. The balance wheel was not revolving. I removed the bridge and notice that the 3rd wheel did not connect with 2nd wheel. I have stripped down the train of wheels and will start again.  I still think the balance is not OK as it does not rotate.
Ross
Hi Ross when you get the balance out post some pictures of it top bottom pivots and the spring its self, good man for finding the fault with the train,we are nearly there now.  when you put the train wheels and bridga on check the rotation ie ( with the watch minus the fork) put a couple of turns on the spring, the wheels will run down and the ecsape wheel will reverse a little at the end. Once accomplished then fit the fork and check its action must be snappy under power, then the balance goes in.  If you wish before the fork goes in fit the balance and give it a puff of air and check the rotation and the contricity and flatness of the spring in the free state.
I have one of these movements in my collection - I wanted one as it's a "high end" ETA movement.
I was surprised at how "flimsy" the movement is compared to other ETA models - the mainplate and bridges seem much thinner, than say as 2836.
My movement had signs of someone heavy handed having a go - the mainplate was distorted in the centre.
Have you checked that all the bridges/cocks sit correctly and the gear train has sufficient endshake throughout  ?
Ticking, ticking, ticking, ticking, ticking ....
Thank you, Thank you, Thank you.
You are not going to believe it. When I damaged the escape wheels (yes, plural), I obtained replacements which included a pallet fork. I used these new pallet forks. They were the problem. The replacements were for an ETA 2789. Supposed to be identical with the ETA 2789-1. They're not. I put the old pallet fork with the replacement escape wheel. Still ticking in any position. Woohoo!
Job tomorrow is the calendar side.
Congrat Ross.
 The two movements differ in complicarions only, thence the thickness and so on.
I bet pallets of the replacement fork needed adjustment, the old one worked  because it was already adjusted.
  • Confused 1
Adjusted? How is that done? Not being churlish. Genuine request for information. They appear so small. At this time of my learning cycle I am genuinely interested.
Regards
Ross
Regards
 Its about moving pallets inward and outward in the fork slot, so to optimize  the  impulse  deilvered to the impulse jewel.
 There has been many discusion on the subject with pictures illustrating details, with Swiss lever the need for adjusting pallets is significant, the task involves dealing with the" lock"  run to the drop " and " drop"  at the right instance, also  issue of overbanming is of concern.
I'd say at this point you best practice with clean&lube and regulating of a movement, hopefully you will soon be ready to step in the mind field called pallet adjustment.
Regards
Nucejoe
Thank you for your kind comments. I think that pallet adjustment will be light years away for me. I ordered my first tools on 17 December 2021. Youtube was my lesson forum until January 2022 when I opened my first watch. All the watches I purchased or practiced with, were like this one. In need of repair. Parts broken. As a novice, it's been a high, slow, learning curve. But ever so enjoyable..
And... today I actually felt that I archived the accolade accredited in this forum. I'm a 'Watch Enthusiast'. Woohoo!
Regards to you, and all who have assisted.
More update will follow when I carry on tomorrow. Youtube rules! Really looking forward to it.
Ross
    • Escapement adjusting always interesting and depending upon the reference always confusing. Okay maybe it's not always confusing but it does lead to confusion. I have a PDF below it's actually a whole bunch of separate stuff including a hand out that came from a lecture that's on you tube. Then from that we get this image Consequences of doing things especially if you do things out of order or you do things for the wrong reason. Oh and even if the watches working I made the mistake one so showing my boss how tweaking the banking pins on a full plate on the timing machine made the amplitude get better and now he thinks that's what they're for and I don't think a fully grasped exactly what horn clearance means. Consequence of doing things. Notice what it says about opening and closing the banking pins and total lock? So yes I've had that on a full plate where it won't unlock at all and that's the banking pins or a combination of things basically. So banking pins unfortunately get moved. One of the ways to tell if it's been moved is the look straight down at the end of the fork with the balance wheel removed. Power on the fork push at the one side look at it push it to the other side also look at it and compare anything with the center reference the balance jewel and see if both sides of the same. No guarantee after the same there in the right place but at least are the same typically when people play with things one side will be way off from the other because they had no idea what they were doing at all because of course it's a full plate and you really have to paying attention and even then there's still hard to do. Then the other thing that comes up like it shows below is people often adjust the banking pins to do all those other things as opposed to horn clearance which is all that it's therefore and maybe bonus Guard pin clearance although you're supposed to deal with the guard pin is a separate thing like single roller gets bent in Or out or sometimes physically gets moved in and out. Some full plates older escapement's typically pallet forks held together with screws and you can actually unscrew and move the entire assembly in Or out more complications to deal with.     Escapement handout wostep nscc.pdf
    • If he was much younger and some sort of sports player it wouldn't be a problem. They would be in there and doing surgery and he'd be back on the field in no time. Unfortunately when you get older little things are bad and big things can be really bad so not good at all.
    • Where I work everything incoming watches whatever detailed descriptions are taken entered into a computer program and photograph of each item. Then ideally although it depends on who's doing the paperwork detailed descriptions can be quite good other times there lacking. Like I really like it with pocket watches if they would record the serial number it avoids confusion later on. Then when watch repairs are completed that is also entered in. It's one of the amusements I learned when I was in school instructor had a shop and commented about the important aspect of keeping detailed records of repairs. Because oftentimes a customer who got a new crystal will come back later on when the watch doesn't work and expect you to fix the entire watch for free. Then you can remind them that they just got a crystal. Strangely enough that keeps coming up or occasionally comes up where I work now. One of the problems of using the service marks on the case is that in the case of pocket watches oftentimes that's not the original case. Then case marks? What I was doing warranty work for a company I used to describe a code number in the back of the case and it would tell me the next time I see the watch that basically what I did I made no attempt at keeping track of customers because we had literally thousands of them I think they sold 30,000 of these watches and they would come back by the hundreds because they had a lifetime warranty. Yes that's a story all of itself but I would put a code number that would reference what was done to the watch the last time and think I had a date in there somehow so it did tell a story if you knew the code. Another shop I once worked out the number would reference the page in the book. So other than knowing we had been in there you would have no idea what happened because you have to go look at the page in the book to see what happened. Then the problem of how you examine a watch you should examine the watch in detail every single time to avoid complications. Although on vintage watches and this is a of amusement I have at work when people ask something and I say of the watches done when it leaves. This is because on vintage oftentimes problems won't show up until the watches much farther into the repair like it's now running and you discover things that you can't discover before because it wasn't running to discover them that also become sometimes difficult to have exact rigid prices are estimates of repairs or in the case of a pocket watch you may not find out if a casing problem to later on when you case it up in the watches running. I was just thinking for all those people that would like to leave a mark maybe you should learn to do what some of the past watchmakers did? Leave a mark but leave it in such a way that no one will ever find it? Typically not done for repair purposes but done for other reasons like identifying it's legit. I have a friend with a Gruen watch and one of the Roman numbers the bottom line that just looks like a line under extreme magnification actually says Gruen watch company or something equivalent. So here's a link showing how to mark your watch without being seen although that's not the actual title. So if you can learn micro engraving you can engrave the watch someplace probably just about any place you just have to remember where you put it. https://cnaluxury.channelnewsasia.com/obsessions/how-to-prove-if-watches-are-authentic-secret-signatures-182516
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
