I slowly and carefully (I'm a newb) disassembled my Waltham 1883 that I got with a broken mainspring.  I took tons of pictures, and I kept all the major parts groups together to avoid issues identifying the proper screws.
I got it all the way down to the base plate, and upon inspecting the jewels, it appears that the 4th wheel jewel (top) is in bad shape, and the 3rd wheel jewel (bottom) has a chip also.  Can someone take a look at my photo and confirm?  I haven't cleaned it much yet, besides trying to scrape the jewels with a sharp toothpick to check if it was just debris.
I'm really now sure how to proceed from here.  Would the watch potentially run with the jewels in that condition?  What effect would it have?
I wouldn't even know how to start looking to find replacements for the jewels, if they do in fact need replacing.  Could anyone provide guidance?  I did intend on getting a staking set off of eBay, eventually.
Edited by kibbler
specifying which jewel is which
Doesn’t it say on the movement or dial about how many jewels the movement has?
Looks like brass bushings, jewels are normally red or pink in colour. I would like to see the other side of the plate that way I should be able to tell if these just push in or are they part of the plate. Brass doesn’t chip are you sure it’s not wear. Whatever they are work will need to be undertaken (1) by replacing or (2) brass bushing so you will need pocket watch Broaches and some sort of staking tool or even a Jewelling Tool.
You know, I had to look at this a few times, and zoom way in.  I don't know if it's the lighting or if the jewels are clear and uncolored, but it looks like there are pressed-in jewels there.  If those are jewels though, then yes, they're a mess and will need replacement.  Either way, OH is right, work will need to be done there.
True, both are damaged.
You will find white (clear) sapphire jewels no more (I have a few sizes in stock), but red jewels are available.
Frank
He says it's not been cleaned yet, and that's hardly a great photo. How do you guys know it's not just thoroughly oxidized/polymerized oil? Personally, without my stereomicroscope (and I could conceive of a scenario where even that would leave me unsure), I think I'd be hesitant to make any such calls prior to a good cleaning...
OP, give it a good bath, and then get a really good look and/or take some really good photos.
Edited by spectre6000
The jewels are a very pale pink, almost clear.  The golden/brass looking color in the photo is just glare from the lighting as I was trying to get the detail of the defects with my camera.
Here are some pictures that better-show the plate from the front and back
PXL_20220216_145558267.thumb.jpg.72013fa9f97aefac6b0f3184fa5b6f04.jpgPXL_20220216_145707455.thumb.jpg.a6116ebbf611c5120f31cba28fbd5df3.jpg
So how do I go about sourcing replacements for the jewels?  I'm assuming I need to press them out, measure with a micrometer, and measure the pivots of the wheels, and order based on that.
I found what I believe is jdrichard's own video on replacing a jewel in what appears to be this same movement, so that is quite helpful
On the other hand, it seems like I'm missing quite a lot of tooling; a jeweling tool set, micrometer (I have a digital caliper), pivot gauges, burnishing tools.  I'm not sure I'm quite ready to dive in so deep.
10 hours ago, jdrichard said:
The jewel simply needs to be replaced. You need to buy a watch repair book and start reading.
It would be rude to direct a newbie to dive into the deep end.  Just a bit of wading, to test the waters. As J D Richard says, start with a book, and then you will learn which tools to begin getting and how deep is "deep".  I recommend "Practical Watch Repairing" by Donald de Carle.  Excellent for beginners, it is a bit dated in places - but so is the watch you're working upon.
Thanks for the book recommendation.
I do think a jewel repair is a bit beyond my experience level right now.  This project was intended to be my first "real" repair on a watch I hoped would work afterward.  I think I will treat it as further practice disassembling, cleaning, lubricating and, reassembling a movement.  If I succeed there, I will set it aside for another day.
I already felt like I over-did it with tool purchases for a new hobby, so it's a bit disappointing I will have to find another project watch.
Or The Watch Repairers Manual
Lets not forget that the Watch Repair Channel on YouTube has several videos on the subject of how to replace a jewel.. I used this search and found several:
  https://www.youtube.com/results?search_query=watch+repair+channel+jewel+replacement
Mark's videos are excellent. There are additional resources on the Chronoglide Watchmaking Channel. Try this YouTube search for a four part series on how to replace jewels:
https://www.youtube.com/results?search_query=chronoglide+watchmaking+jewel+replacement
I have seen all of these and bought the tools from eBay. I'm searching for a project watch to try this on as we speak. I am also a newbie, so I'm going through the same process. If you have not taken Mark's courses yet I highly recommend them. I took them all and they really helped me bootstrap my journey into watchmaking.
By the way, the replacing of a jewel is not going to be high quality work using a staking set. The end shake of the wheel is determined by the position of the jewels above and below it, with accuracy down to 10th's of a mm. As a first timer (like me) it was clear I could not get that position that accurate with a staking set. One of the things about that jeweling set is you can make very small adjustments to the jewel position, and that's critical to a proper repair.
(Unless there is a trick to doing this with a staking set that I am not aware of.)
Do this at your own pace, you'll get there and have that pride when the basket case you just repaired comes back to life and ticks for the first time. Enjoy the journey!
Seriously, what is it about those photos that's causing everyone to immediately jump to not one, but TWO chipped jewels on a movement that OP explicitly states has not been cleaned? I know I have a sub-third world internet connection up here, but pretty sure we're looking at the same photos, and I see nothing that says the jewels are broken that couldn't just as easily say they're caked with old polymerized oil.
I should follow up, because I did appreciate your point from before, and I took the time today to clean the plates as best I could in lighter fluid.
The damage is still there, and quite apparent now that the all of the jewels are otherwise very shiny.
If the rest of the watch parts are OK just clean and reinstall. It should work as these watches are quite robust. Even if it doesnt you can put it away for the moment while you get experience on other watches and in the meantime start hunting for a jewelling set.
Anilv
As you progress in watch repairing you will find other tools are a must. You should be able to find jewels at the many watch suppliers, a good place to look is ebay. Lots of old stock including jewels are for sale on there it would pay you to look two or three times a week, you can also pick up old tools as well. It is a good place in which to add stock. These jewels are just press fit, so you could probable get away with just a flat end stake and a light weight hammer that is if you go careful.
I am very pleased to report that to my surprise, the watch came to life upon reinstalling the balance wheel.  That moment is the reason I was drawn to this hobby, so I was very happy with that.  With the new mainspring I installed, it seems to be ticking along very strong, although I don't yet have a way to measure.  I'm going to let it wind down from a full wind once before setting it aside - to see if it continues running, and I'll note how far off it drifts in 24 hours.
Thanks, I will definitely come back to this one at some point after I expand my tool collection.  I am tracking staking set listings on ebay, and I'll keep my eye out for a decent micrometer also.
Based on jdrichard's jewel replacement video, and seeing the size difference between the top- and bottom-side of the jewels, I was under the impression those jewels on this movement were burnished in.  How can I tell for sure if they are friction-fit or burnished?
Edited by kibbler
typo
9 hours ago, oldhippy said:
Have a look here this explains the different types of jewels.
 https://pocketwatchdatabase.com/reference/jewel-settings
Based on that chart, these look burnished/rubbed-in (are those the same thing?) to me.  Will a standard Seitz jewel just slot right in there with a friction fit?  I was under the impression that it would not.
*edit* As a side-note. This movement has been running for almost 30 hours, and is now slow by around or just under a minute.  Given that I don't have any sort of time grapher and didn't touch the regulator, I'm going to chalk that up in the "win" column.
Edited by kibbler
The Seitz is for the press in jewels. There are tools for rubbing in jewels but I don't know if they are still made. I have seen them on ebay so when you see a set try and buy them.
    • Do you have the service manual for 3135 as it would explain the procedure then in the absence of that the current procedure for modern mainsprings would be breaking grease on the outer wall as it's an automatic watch. The mainsprings are considered prelubricated no lubrication is required. Then the arbor is lubricated with a suitable lubrication. Typically the only time you see well I haven't ever seen anything quite like that Rolex but Seiko watches often the barrel is filled with some sort of I believe graphite-based lubricant. Or if too much breaking grease was applied in it leaks out but that would be a heck of a lot of breaking grease. I wonder if the black would be molybdenum disulfide? There is a variation of 8200 Quite remember the number were a little bit of molybdenum disulfide Which is a really nice high-pressure powder is mixed in with the eighth 200 and maybe they applied a heaping quantity of that?
    • The watch is from 1990 and was serviced just once around 20 years ago. No idea if the mainspring barrel was ever opened or changed before now.
    • Interesting but I think we have a problem here? We probably need to split hairs on a definition problem. For instance take a real Rolex movement put it in a real Rolex case but not the one it came in take a real dial real hands and make up a watch that is 100% real and what exactly is this? If you send your Rolex in for servicing and anything's been changed at all from what it was when it left the factory Rolex will be unhappy and remove all offending components. This does become a problem of people changing things because they think it's their watch and they want to have a different dial Lord diamonds the bezel or whatever words Rolex sees all of this as evil and bad as far as a Intel Rolex only things the watch is legit if everything is exactly what it was when it left the factory and nothing's been changed including the stem everything asked me Rolex original or their very unhappy about its existence. Then you think about a fake watch what is its real purpose? Well its real purpose is to make money for somebody and fool the customer. So all the watch has to do is look pleasant on the outside and inside can be anything. Typically nobody's going to see inside. So typically anything that's not legit counterfeit movement etc. why would someone spend so much time and effort making it look just like a real Rolex when there's no need to? Unless of course you have one or two movements to impress somebody with this is what's inside your watch but even that is problematic Now we don't end up with I've interesting problem that troubles me where I work. The owner will offend a cage your watch by looking at it carefully with a microscope the timing machine etc. and he will point out all the things that he feels are not appropriate correct or whatever for your watch. But in my example above of mixing and matching legitimate Rolex parts he wouldn't necessarily be able to tell. The problem I have with this is it often times things like his claim to telling a counterfeit is look at the second hand the quality of the secondhand is not as nice as a legitimate one. But maybe somebody replaced a second hand on a real Rolex. Or the other day at work I don't know what it was in before but there was a really pretty movement transparent back and they decided it was fake because of? Now I didn't think it was fake I took one look was beautifully manufactured but they had a reason What bothers me with counterfeit Rolex is or anything counterfeit watch related it is reminding me of a witchhunt. The early days of witch hunting how can we tell a which Manon which? That makes me wonder how many super fakes are really fake at all it's basically somebody deciding it's a fake based upon inappropriate assumptions. Like the secondhand is been changed or the watch was worked on the screws are perfect or other things. Other minor problems with super fakes for instance I have a long story the not going to tell the short version is I found the website once where they claim to be counterfeiting Rolex watches. They even had a picture to prove their counterfeit watch the problem with pictures online how do we know it's really a counterfeit watch and not a real Rolex watch that you're telling us is counterfeit. Oh and they had testimonials from all kinds of people who bought their watches and were very happy with the service of course the problem with the watch is you don't know what's inside it unless you take the back off and just because somebody shows a picture online and says this is their super fake maybe it really isn't a super fake they be there just trying to say that. We end up with a interesting problem of manufacturing a watch. Does Rolex actually make every single part found in their watch? Then the year 2004's basically irrelevant. This is because initially Rolex buys stock in the company and they manufacture Rolex watches. I'm assuming over time Rolex will acquire more stock and only in 2004 do they get the whole company. But the company itself hasn't really changed other than the name on the front of the building. The real question is did they really make every single component found in the Rolex watch from the beginning of time until end of the time? A lot of the components found in a watch would be extremely specialized did they make their own jewels or their own mainsprings for instance? But that is looking at the article they employ a heck of a lot of people now I would guess now that Rolex probably does make everything in-house. Especially when they have nifty CNC equipment like for making screws were he could make a huge batch of one type it instantly switch to another type where before he needed specialized machines for one machine for one screw now manufacturing all kinds of stuff in-house becomes very simple. But still is possible that in the early days they might have outsourced something may be perhaps. But conceivably we do have minor changes in thing is due to how things have been made over time which can lead to confusions over whether this is legit or not when it may be as a change of manufacturing methods oh and regarding the screws found in your Rolex watch? In about mid-80s I went to a school reunion in Switzerland. One of things we could do was visit a factory and I picked Rolex because I wanted to see the mass production making of Rolex watches. Which is very disappointed I did not get the sea at all because didn't see them making Rolex watches in their Geneva headquarters even though the building is really fake? So what did we get to see well after sales service because after all were watchmakers we should see that. Did learn something interesting about Rolex screws if your watch was sent to Rolex the screws that come back are not the ones that went there. As they are using powered screwdrivers they don't want to risk breaking heads off and they will replace the screws of every single watch. The other one of interest was suppose there's a scratch and you can see the brass? No problem they have a solution that basically electoral plates without electricity so the scratch goes away. The research Department was quite boring and didn't look like anyone was ever there. Then it was too long ago to remember all the details other than I was disappointed I want to see manufacturing.   Yes the joys of artificial intelligence that is more like a trained monkey that's there to please you.
    • Hey everybody! I just registered to WRT. I found this forum searching for informations about ELMA watch cleaning machines (will get one ELMA tomorrow ✌️). I'm new in watch repair, collecting watch repair tools to fill up my work space 😎.   Greetings from Vienna Michael
