Got this practice watch identical to another watch I was doing for a friend.  Wanted a backup plan!!
Anyway, when cleaning I discovered the pallet jewels were loose and the shellac was dissolved in one-dip.
So...time to learn a new skill.  Fortunately, I anticipated this many months ago and bought a lifetime supply of shellac!!  More like ten lifetimes.
Here in these pictures are the results.  I hope I did it right.  Was careful to pay attention to location and orientation, but, hey...coulda got it wrong.
Heat a piece of shellac in the flame until it just melts (don't burn it), and poke a sharpened piece of pegwood in the gooey shellac and pull away. You'll end up with a long fine thread of shellac on the pegwood, which you can shorten to a usable length by breaking off the excess. Now you have an applicator that makes it very easy to apply just the right amount.
8 minutes ago, LittleWatchShop said:
I think the jewels are recessed too far.  I get no amplitude.  Must study this issue further!
Just from the look of the fork they appear to be far too "out", the gap between the rear of the pallet jewel and rear of the fork slot is generally quite small. But you will only know if you check the function of the escapement.
24 分钟前,镍银 说道:
在加热木胶中,直到它刚刚喷出的距离(不要点燃),然后粘在粘稠的虫胶中拔出拔出。的虫胶线,你通过它的线将它的长度延长。
You're right, that's what I did.
Edited by JinTie
Remember: shellac dissolves in alcohol. You can ease up to your desired level of clean with an alcohol soaked Q-tip or similar.
I've noodled on whether or not it might be possible to do the reverse as well: rather than melt the shellac and glob it on, dissolve it and brush it on in thick coats sort of. I mentioned in another thread recently that I also dabble in luthiery/fine woodworking, and French polish is one of my go to finishes. A French polish is mostly a technique, but the material aspect is just shellac dissolved in ethanol, and the terminology is "X# cut", i.e. 2# cut which is 2 pounds of shellac flakes to a gallon of ethanol or something along those lines. It doesn't keep, so a gallon is way too much for my purposes, hence the fuzziness on the specifics. It's definitely more art than science, so you get quite a bit of wiggle room. The Brits probably have a name for things of the sort, and it probably rhymes cognitively with "that'll do". Anyway, my thought was that it might be possible to make up a really heavy cut, and brush it on, or maybe use a small dropper/pipette (utilizing capillary action rather than an actual drop). You'd get better penetration into the joint via capillary action (assuming it's not too viscous), while adding almost no mass or mess. It might take a few applications to get where you want, and you'd be wasting the majority of your shellac/hooch, but as LWS discovered, shellac is dirt cheap on the scale we're talking here. The booze is a bit more pricey, but shellac is totally non-toxic and edible (it's often used to coat apples to keep them shiny and marketable), so....
The horse left the barn.  One pallet took flight to worlds unknown.  I thought my Dad had left me an assortment of these, but as yet I cannot find them.  That's OK...this is a great learning experience!!  And...this was essentially a junker.
And decided that "there is no place like home."
After stepping away from this for a few days, I put my loop on and scanned my skin drawer using methodical sweeps.  Lo and behold!  There it was...the missing pallet jewel.
So, using the technique offered by my wise friends on this forum, the pallet is back in place and the watch is now running!
I've been warning my wife after doing "husbandly things" that there's likely going to be a delivery tomorrow. So far it's working and she seems open to the fact that I could be starting a new hobby. Hopefully after I get over the initial purchase of basic tools, I'll start working on watches (haven't yet) and I'll be able to see if my bum left eye is going to be a problem.
Only done a couple but I use the shellac  disolved into a thick solution method. No issues so far and much easier than the traditional method.
It's simple enough to do just dissolve shellac in your chosen Alcohol (I am in the UK so have to use Methylated Spirits as the common Ethanol is not available here over the counter) just keep adding your crushed shellac untill the mix resembles a thick varnish. The mix is then added to the fork jewels with an old oiler.
Like I said above only done a couple but they are in daily use and show no signs of failing, so it's worth giving it a go. The mixed solution is kept in a screw top bottle and keeps for years.
I use it in my other hobby, fountain pen restorations and have some I mixed 10 years ago and it's still good.
  • Thanks 2
On 2/9/2022 at 3:56 PM, LittleWatchShop said:
OK, I will cleanup the overdose of shellac.  Meanwhile, here is a slo-mo video of the escapement.  Fun stuff!!!
Nice!
May I ask what equipment/software you used to record and upload that slo-mo video? I have an iPhone 8 which can record in slo-mo but it no longer seems possible to upload those slo-mo videos to YT. It feels like I've tried everything but I eventually had to give up.😒 Normal videos aren't any problem. It's the slo-mo videos that are the problem.
Edited by VWatchie
I've had moments when my wife asked me if I was married to my watches rather than her. Not very pleasant moments, so be a bit careful with the "I'm just going to take care of this little watch problem first" thinking. 😅
Edited by VWatchie
2 hours ago, VWatchie said:
Nice!
Samsung Galaxy S21. No special sw.
I fully expect ebay and paypal will send me a Christmas Turkey in appreciation of my business
  • Haha 3
I wouldn't be surprised if buying cheap watches sold for repair or parts and then repair them yourself is way more expensive than buying a Rolex watch. I actively avoid thinking about how much money I've spent on tools, parts, and consumables 😖
That's highly interesting! So, even when "flooded" with shellac a pallet stone came loose? How did you apply the shellac? Did you heat it or dissolve it in alcohol? If alcohol, are you positively sure the shellac had hardened? I personally never, under any circumstances, let alcohol near the pallets (not even for rinsing purposes). If I need to remove the pallets from the fork I use acetone.
8 hours ago, VWatchie said:
... so be a bit careful...
Thanks!
My propensity to overdo things is well known: 18 electric guitars? 6 cameras? As they say: "You can only use 1 at a time" At least I've thinned out the pile of guitars.
In another of my hobbies I was once spending so much with one supplier that they sent me a bottle of whiskey at Christmas, oops.
  • Haha 3
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
