Just a quick intro, my name is Craig and I've been working on watches for a couple years now, have rebuilt a couple Bulova automatics, but mostly have done battery replacements, reattached loose hands, and resized bands for friends and family. Disassembled a couple of watches, cleaned them up, and then gave them away, that sort of thing I guess. Getting older and with cold winters here in MN this intermittent hobby has become more occasional now, especially since the pandemic began, sort of needed something to keep my mind off things and keep my sanity. I decided to join this group as every so often I run into something I can't quite figure out and would like to find some direction before just ripping into a watch and destroying it. I have one right now that I could use some help on, it is a Stuhrling Targa 24 176B2 that a friend gave me. It needs a new battery which is no problem, but the small hand on one of the chronograph dials is loose in the case. I have taken off the back and removed the stem, and even pried gently around the edge of what appears to be the dial edge but it does not seem to move. This is a nice watch yet, almost like new, and I don't want to mark it up as I would like to fix and wear it myself. Any help on how you get the dial out of this watch to reattach the hands would be appreciated, I just want to be sure about how this watch comes apart before applying more force to it. Thanks.
Add a few photos, it'll be easier to figure out what's wrong.
Here are the photos. Looking at the back I tried a small screwdriver and a pick to lift the dial and it would not budge, wondering if this dial comes out from the top of the watch after you remove the bezel and crystal? No idea here, do not want to butcher it, even if it is a cheap watch it still looks good.
Welcome here. That is called a front loader and is the most common question asked by beginners. Enter "front loader" in the search box top right to be presented with all the relevant answers. Note you will need a decent crystal or caseback press and dies to to refit the bezel.
Not really a beginner and not sure this is a top loader. Looking for someone who has actually torn one of these apart and need exact detailed information on how they removed the dial.
    • Oh that's neat. I typically use a thin strap of rodico laid over the pallet fork to affix it to the upper plate but it can be hard to retrieve sometimes. And as I did more research, I may have just found your own earlier explanation: https://learntimeonline.com/forums/topic/potence-clip-for-full-plate-p-ws/
    • I've been on a ESA 9154 kick lately with this being the latest. A funkalicious 1970's Elgin Electronic with a brown and orange earth toned dial in a big old hunk of steel. Just like the last one this one runs from about -2 to +2 in 5 positions as it seems to be easy to dial these 9154's in.
    • I wonder what the theoretical size limit is for both a quartz and mechanical movement?
    • I'm currently working on a Citizen 4520 movement. This has to be the smallest and weirdest quartz movement I've ever worked on. Firstly, it's small. Really small. Here's a picture of it next to a LR44 battery for comparison.  And unlike conventional quartz movements, the construction of this movement is really weird. The moment I took off the top plate, the rotor and 1st wheel are exposed. The PCB is right on the bottom plate. There are no dial side components and cover plates. Everything goes in from the rear. Not sure if I'm able to fix this watch. The old battery leaked and there are battery juice crystals everywhere. And there is a 1 uA constant leakage current, which will drain the tiny battery in no time. But at least there's still a pulse and the rotor twitches.
    • Afraid this is where it could get down to old school adjustment and observation. There are pallet setting tools..but the calibrated ones aren't cheap. The observation holes in the plate will allow you to see if you have one or both stones hanging up/ not engaging on a tooth, That would ofcourse require you to disassemble, heat/move the jewel in/out as required..by eyesight and experience. It's truly trial and error until you get close enough that you could make small adjustments with the banking pins until they drop to the lock freely. You can use a Potence tool to help hold the rok in place during reassmbly. Here's a pic of one...made with a piece of old 18s mainspring You just fold over a roughly 2 inch piece, then file a slot on the end that engages the pallet fork arbor
