Have some hands that needs a  be refinished with an nicer looking black stripe in the middle . Have tried to mask it and paint . Didn't look good and wasn't straight  . So do you have any tips to finish this of the strip and making it look like new again . Besides finding new hands .Which would be almost impossible . The watch is an old citizen crystron quartz .
Hi Rog!
Just my feverish mind at work here but what about getting a short length of windscreen wiper rubber and using the edge, dipped in black paint, as a sort of tampon?
If the rubber is new and the edge nice and straight, maybe under tension from either end, I reckon you'd get a passable result.
Edited by clockwatcher
There is a slit on the upper part that is going to be relumed in a white lume . Above that and on the other parts there should be a black straight black line . I tried to tape a line with masking tape .But when i removed it .It was way to uneven in the edge . I don't now where to find it ?But do you think i could use water slide paper ?
That's a really tricky one Roger.
Why not have another go at masking them, but instead of using masking tape try use sellotape as it is thinner and should have a sharper edge than masking tape. Use an acrylic matt black paint and apply the absolute minimum to the hands. Leave overnight to make sure the paint is well set then remove the tape. The thinner the coating, the less likely hood of the paint peeling when you remove the tape.
If you can't get the black line absolutely perfect, you would be better just polishing and re-luming them.
hi roger, bit difficult to see exactly from your pics so i'll have a guess, if the black line is recessed paint it with black paint then rub back with 1200 paper or finer, if not get some decal paper from amazon or the like also get bonding liquid like sol, measure up and you will be able to print it up really easy in any desktop publisher program, this is an easy project any probs get back
I will try to take some better pictures in the morning . I have a macro lens but the hand is so small it's hard to come really close . I tried the sellotape but it didn't work so good . The only sellotape i had at home was the one you can see thru . I will order some decal paper from Ebay tomorrow .Good to have anyway .
Clear tape i mean .Hard to find the right word sometimes when it's not my native language .
Should i order clear decal paper or white ?
Edited by rogart63
Hi Rog!
Missed to read your tips at first  . Nice one shall certainly try that .
you could follow Mark's video about relume hands and polish front side and applay paint to back side same way as lume is done on the video.
This might work.
When I re-gild the inlays of French clocks before proceeding I always first polish the main case with black shoe polish which is a wax.When applying the gold gild paint to the inlay any over spill just wipes off leaving nice clean lines. My thinking being if the hand is inlayed first remove any old paint then clean the hands with a degreaser including the inlayed area then try polishing the hands without touching the inlayed area with a wax based polish. Apply a black enamel paint with a very fine horsehair brush and any over spill should just wipe off.
Fail :growl:  . Tried to polish the hands with some polish . The brass came trought . It's brass with chrome over not stainless steel . Will try to find some replacement hands or a donor watch . Lesson learn . Never ever think that a citizen quartz has stainless steel hands .
I sympathise Rogart  I have had lots of disasters over the years I just make sure I learn from them.
The secret with painting whether it is a wall,wood, or metal is preparation. You know when you have prepped correctly when the paint attaches with a single stroke of the brush.
If you know the dimensions of the hands you should have no problem getting new hands to fit.
Spray the entire hand in dayglo orange...!
Old architect (and surgeon) principle: if you can't hide or disguise it, make a feature of it...! ;)
Pete, Brisbane
This is the result i came up with .Some old hands i had laying around . Relumed them in white and put them back on.More original then original .
Since them this has happen . Found a donor watch on Ebay . So some oldnew hands has found it's way to a new watch .Looking original again .
I like the look of the previous pic. I feel the substitutes look better.
The way I would go about this sort of thing.
1, Clean out the old.
2, I had an old watch oiler a thick one.
3, Airfix paint.
Turn the  hand upside down fix the hand to a piece of peg wood dip the oiler into paint and work out from the center to tip by means of a spreading motion and leave to dry.
 They did but i like it as original as possible .
There's a lot to be said for that. Be it for nostalgia, personal achievement in the restoration process, sharing with a purist, or just personal enjoyment, there can be no greater satisfaction.
    • After another long hiatus (while waiting for truing calipers to arrive), I’ve made some more progress. TRUING IN THE FLAT I was able to use the calipers I purchased to true the wheel in the flat. There’s still a very slight eccentricity in the round, but I’m going to leave it as is. It doesn’t wobble any more and I’m happy with that. Thanks for the tool recommendation @mbwatch. It worked well, though I must say it takes a delicate touch to get the balance between the calipers. Also, my calipers effectively have four different variations based on the orientation of the arms (2 sides, 2 orientations each). Some are more tapered than others, though to what end, I can’t quite tell. My first thought was that flipping them over yields arms that can be used for poising. They are K&D horizontal calipers, btw. OSCILLATION TEST @nevenbekriev @JohnR725 After truing the wheel in the flat, I carefully remounted the hairspring and did your oscillation test. Balance wheel mounted to balance cock, no pallet fork, rotate balance wheel 180 degrees, let it go, and time+count the oscillations. Results as follows for dial down orientation: Duration: 1m 15sec (to full stop) # of oscillations: About 125, though the amplitude of the oscillations decreased significantly, as one might expect I should redo the test in at least two other orientations…Forgot to do that. 🙂  In general, it’s safe to say this watch has a pretty low amplitude, likely for a variety of reasons. I haven’t oiled the balance jewels FWIW…I should probably do that, but I really don’t want to keep disassembling and reassembling the balance. Is it possible to oil those jewels (top and bottom) by just removing the capstones and putting in a tiny amount of oil, with balance in place? I can see how having the pivot in the jewel hole could change how capillary action works, and thus might pull more oil in than desired. However, those capillary forces will be in effect anyway once the balance is inserted. PRACTICE MOVEMENTS @JohnR725 I agree with your sentiment about using practice movements wholeheartedly, and I’ve done that to some degree. The watch I’m currently repairing is for a friend, and she was willing to have me treat it as a “learn-by-doing experience.” With that said,, I probably should have purchased a few more “beaters” before getting to something where I don’t want to muck things up. I’ve still got a couple of those on the bench that I used as donors, and I’ll try to rehabilitate them.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
    • A few things you should find out before you can mske a decision of what to do. As Richard said, what is the crown and all of the crown components made of . Then also the stem .  The crown looks to have a steel washer that retains a gasket. So be careful with what chemicals you use to dissolve any stem adhesives or the use of heat. You might swell or melt the gasket unless you are prepared to change that also . The steel washer maybe reactive to alum. Something I've just used to dissolve a broken screw from a plate. First drilled out the centre of the screw with a 0.5mm carbide . Dipped only the section that held the broken screw in Rustins rust remover. This is 40 % phosphoric acid. 3 days and the screw remains were completely dissolved, no trace of steel in the brass threads. A black puddle left in the solution.
