Hobby Watch Maker
Hi Sendikumar, if I remember well, the minute hand is inserted in the gap between the hour wheel and the cannon pinion or rather on the cannon pinion (I haven't worked on one of those for some time now. It depends on the hands you are getting and yes, it looks a little high but it might be the way the picture was taken. Just get a dial as Geo suggested and check that you have enough of the hour wheel out and clearance for the hour and minute hands.
Also, don't cut the stem until the very end when you are ready to give the watch as finished: that's the last thing you would do. Also, I wouldn't cut the hour wheel because of many factors, one that come to mind is finish and another is "even", if you screw up you will be in a real fix to fit the hour hand properly if at all. Remember the hands tool stops on the rim of the hour wheel (on top). That surface should be even or the hand will be twisted and you will have to adjust by sight...it still can be done but not very professional. I 'd rather get a shorter wheel or a longer canon pinion...they are all the same for that movement regardless of country of origin.
Good luck with your project!
Cheers,
Bob
I am bit busy with my work , with computers creating software, in tight deadlines. However I ordered dial and it will be ready in couple of weeks time will start again.
For sure I will post lot of questions and queries
Sent from my XT1068 using Tapatalk
Ah Sendil
Work - that horrible four letter word that stops the fun in the pursuit of income.  I well remember that from pre-retirement times before my hair turned grey and then fell out.
Hope your ventures are successful and I look forward to the next posting.
Cheers,
Vic
I'm there now Vich, glad you read my future! Four more years....I can't wait!
Cheers,
Bob
  • 10 months later...
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
