Wheels behaving badly.
fjseal
Check if the fork to escape wheel flutters, the bad guy could be teeth of escape wheel, otherwise its back to usual faults namely  pinion leaves, gear teeth, excessive side shake  between neighboring gears even bent arbour or worn jewel holes.
Judging by the vid, its most likely bad pinion leaves or gear teeth.
Good luck
That is not a video, but an animated GIF which the OP made instead of uploading to Youtube  an high frame rate video with sound and posting the link. That would have allowed a better guess about what's going on.
The other thing missing is a timegrapher picture. If the OP doesn't have one, and he is serious about repairing movements, he should definitely get one, or an equivalent application and suitable microphone.
1 hour ago, jdm said:
That is not a video, but an animated GIF which the OP made instead of uploading to Youtube  an high frame rate video with sound and posting the link. That would have allowed a better quess about what's going on.
I be darn, animated GIF !
 Anyway,    Merry Christmas Jdm.
    • Hello, I am working on a eta 2970-1 and as soon as I screw down the rotor, the watch stops. The watch runs great without the automatic bridge, when I attach the automatic bridge, it continues to run well, but as soon as I attach the main rotor the watch stops. Can anyone please share schematics or pictures of the automatic bridge? I have looked up a few pictures online and it looks like I have assembled the bridge correctly after cleaning, but the fact that the watch stops as soon as the rotor puts counter pressure on the bridge, points me that there js something wrong with the automatic bridge. Thank you.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This should help you.  704789946_TZIllustratedGlossary(2).pdf
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
