I recently got this from my sister-in-law...it belonged to her father who was a foot soldier in WWII--I believe in Italy but not sure.
I have removed the crown wheel to expose the rust.  I cannot remove the setting-lever screw (been here before) and thus cannot remove the crown.  However, I was able to remove the crystal, hands and dial and thus disassemble the watch while in the case.
I see very little info about this watch on the web.  The keyless works will need to be replaced and it looks like I am going to have to make these from scratch or improvise some replacements.
Anybody in this group know anything about this watch?
I really do want to restore this knowing full well that I am an amateur...lol
I posted about this here.
Well...I have made a lot of progress.  I had to disassemble the watch while still in the case because the rust around the stem locked it in solid.  After trying various techniques...WD40 etc. I was able to remove the stem but the keyless works were still stuck in the movement.  I have some super duper penetrating oil that has been in my chemical bank for probably 40 years or more...soaked the main plate with keyless works for 24 hours...voila!!  After removing all of the parts, I ran everything through the cleaner--first the ultrasonic and then using the L&R (no, I did not run balance and pallet fork through the ultrasonic).
After everything was clean and dry, I did the reassemble.  Obviously I could not wind it with the stem, but could wind with the rachet screw.  I did not install the crown wheel because I did not need it for now and I was also missing the crown wheel spacer (I think).
Well, here it is and it is running.  I took a short video of me installing the balance when with power so that exact moment when the watch was recalled to live could be captured.
After checking with family, I am confident that this watch was retrieved during the Battle of the Bulge in 1944/45.
Where to from here?  I am going to need a new stem, clutch, winding pinion, setting lever screw, and perhaps some other things as well.  I also need to do a proper clean/oil on the balance jewels.
For now...I am happy with my progress.
Well done! It must have been very satisfying to get it working again.
Good luck finding the parts you need. Precimax also sold under the Helios brand so worth keeping an eye out for spares via that route i.e. Helios watch with a P300 movement.
  • 3 months later...
This watch is mostly complete now.  Found a donor on the web and used the winding pinion, sliding clutch, setting lever, and settling lever screw, and a case screw from the donor.  Kept everything else original except I had to make to dial screws and still need to make one more case screw.
Decided not to replace the crystal...only polished it.
what a history, I take it that it was a German issue to their forces,  Brilliant to see it set off after so many years,  Love the origiality of it all the hall marks of a hard life. well done that man
I bought this watch on ebay awhile back, thinking it would be a donor to the Wehrmacht watch.  It was a different movement: ETA 810.  But I love the style, so I serviced it today.  The dial says 15 Jewels, but the movement has 16.IMG_8340.thumb.JPG.0a6ed1fe7e34653db546939635a9e9da.JPG
    • Regarding the spring winders, I made my own and used copper pipe reducers as the tubes to retain the spring. You will need to cut out a section for the end of the spring to protrude but if you watch one of the many videos on this subject that will make sense. You can find a selection of sizes on Ebay for very little cost. I'll attach a pic showing one of mine.  Good luck!
    • There were things bothering me about this discussion that took me a while to figure out the problem. In the image below it appears to be the spring may be pushing up? Normally when Omega has a spring pushing up the pinion has a pivot with a bridge to hold it in place so in other words the spring can push on something that stationary as opposed to this which appears to be floating? To understand the problem with the above image we need another image of side view which I have below. In my image down below on the left-hand side it agrees with the image up above. But the only problem is the left-hand side is defective and the right-hand side image is the way it's supposed to look. Then Omega if you can access the right documents does explain how and why this problem occurs. With the pinion floating around it might be assumed that you support it when putting on all the hands but you do not because as noted below if you do this small bush on the pinion will relocate out of position exactly what we see in the image up above.   Then Omega does not mention this but there is a possibility of also damaging the pinion and causing the bush to move to where it's not supposed to be when removing the hands.
    • Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD.
    • The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position.  Please help !
    • Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
