Hi everybody,
I'm a guy from Canada in his late 30's that got into watches during the pandemic, you have to find something to do while staying at home, eh?
I started by restoring badly beaten cases by meticulously trying to keep all the edges and original design.
Slowly by slowly I got dragged deeper and deeper into the watchmaking black hole and felt the need to be part of a community
I'm also a product designer so I design and sketch a lot of watches in my free time.
I attached an example of the stuff that I do for case restoration.
Glad to be here !
