Which Clock Have You Got Coming In The Mail (or you are picking up)? Show Us !!!
Michael1962
Hi If your clock looks like the image s  attached  all the count work is done via the snail cam (on the center shaft) the gathering pallet, the rack, and the strike wheel. once the warning has released its stopped by the long lever, when the center cam drops its lever the long lever falls an releases the the warning wheel and the count starts. The lever dros onto the snail which controls the amount that the rack drops and the gathering pallet then counts back the appropriate number untill the sequence is counted and the rack is back in the locked position .  No physical count wheel like the American Ansonia clocks.
The last photo gives you a good clear view of how the wheels go into the plates. See my list of the strike side and look at the picture and try to remember it. The going side is
Escape Wheel
Intermediate wheel some times called the third wheel
Center wheel
Great wheel going side
Barrel
The great wheel on the going side is much larger then the one on the strike side so remember that.
This is the most common set up for wheel trains in clocks. As I said you do come across odd counts which will add a wheel or in very rear cases less wheels.
Barrels, caps and arbors. Mark the barrels and caps before taking them apart with a marker pen or similar always keep them away from each other.
Thanks @oldhippy. My time as a fitter would have automatically had me keeping barrel assemblies and springs together s sets anyway, but the info is great. Thanks.
Your descriptions of the wheel trains makes understanding the picture much easier. Thanks for that.
Doesn’t mean I’m not going to take photos though. The movement has a few bushes in the plates. Mostly invisible on the insides of the plates, but you can definitely see them on the outside of the plates. I would suggest they are kit bushes as you can see the outer diameter of the bushes in the holes in the plates. Everything seems to move very well so I would say the work has been done fairly well. At least I have a movement now that I can learn on without being worried about it too much. I may possibly even practice rbushing some of the holes. Gets me on the lathe and gets me practising and learning.
Back to fitting practices, just on a smaller scale.
You description tells me the clock has been bushed with those ready made bushes, they are OK for this type of movement, but you cant do invisible re-bushing. As you have a lathe why not buy some bushing brass rods and practice making you own, practice countersinking, measure pivots length & diameter and the thickness of the clock plates. That is the way to learn how to invisible re-bush. Get your self a few counter sink tools. If you get the chance to repair a French Carriage clock or any clock that you can see the movement the last thing you want to see is ugly re-bushing. Brass bussing rod can be bought on line any good suppliers.
I already have a fair bit of brass that I have salvaged from some pins that are used at the place where I work. What I don't know is the composition of this brass. I think I can find out though. Just not sure if it will be ok to use. Don't suppose anyone knows the composition of bushing brass?
And you're right @oldhippy, my thoughts are exactly as you have said. Practice using this movement as a donor. Get good at part nomenclature. Understand the ratios. Understand what timing is required between certain parts of the movement for it to function correctly. My question regarding where the strike warning wheel pin should be was from my first ham fisted effort to get the rear plate back on after I had removed the great wheel and the fly. I think the pillars are slightly out to the holes in the rear plate as it took a bit of mucking around to get it all to line up so that I could get the plate back on. I know for a fact that the warning wheel lost its mesh with the third wheel. I am just lucky that it is in a position where the timing still works and I can watch how it all works together.
I'm really looking forward to this.
Joe Collins mainspring winder is getting cut by my friend up the road this weekend. I just have to get hold of some different size stainless steel tube to make myself some spring holders. I'm going to base the sizes on the C clamps that I bought.
I have some other ideas for making myself some tools. I'll see how it goes.
Just brought this home from a local thrift shop.  In an effort to step out of my "comfort zone" of pocket watches,  I saw this charming old Hamilton on a shelf, needing some TLC, and decided to buy it.  It was only $35, so not too dear.
Now, my knowledge of clocks is sparce, and is primarily mechanical - and related to function.  I'm a little ignorant regarding striking clocks.   This one seems of good quality and I am familiar with the Hamilton name.  And it has a floating balance, and I am more used to working on balances than I am upon pendulums.
All that said, if O.H. or any of the rest of you clock veterans have any tips or caveats, feel free to share.  I am preparing to clean, and to locate my clock oil.  And I plan to search the forum for wood refinishing posts, and how to tell if a clock needs bushings, and other fun stuff.
Wish me luck.
Hi Karl    It may be stamped  Hamilton  But the movement is Hermle 340-020 probably a bought in movement. done a few of these they are nice clocks .
Its an eight day Westminster chime movement with underslung hammers. the Floating balance is a nice feature and as long as its not maltreated in any way, very good.   Cleaning and oiling the balance ,  when dry its recommended that you use Moebius 8000s  but I have always used Windle's on the top and bottom of the tube carrying the wire.  Its beat rate is 150 BPH. Never had one to bush as yet.  For $35 a cracking buy. I did one for a friend some time back that he retrieved form the repairers after a 3 month wait and a quote for £300 plus.
I know the Hermle name also.  I wondered about that. I've worked on a Hermle before too.  It was nicely made.  This one is like that.  It seems fairly robust compared to my Linden 8-day.  The wheels are thicker and the teeth more crisply cut it seems.  Thanks for the beat rate and the other tips.  I think I will stick with Windle's here.
These movements wear a lot because they are not made of really hard brass or steel. Its modern and modern is never as good at wear as really old brass and steel. As far as I know you can still buy parts for Hermle clocks. I always oiled the floating balance ends with pocket watch oil. Oil the escape wheel every other tooth not the pallet pins as the pallet pins will pick up the oil as the escape wheel rotates.
Thank you, Watchweasol and OH both, for confirming it to be a Hermle.  I know a couple good places to get Hermle parts, and I know a clock technician personally who services mostly Black Forrest stuff and he stocks Hermle parts at his shop.  So I won't be worrying about parts.
And thanks to @oldhippy for the oiling tips; I'm going to try that.  As to wear - I don't think there is very much.  Aside from gunky old oil, the wheels look like they were just cut.  Considering that when I opened the back, it had a sort of musty, old-house smell, and there were two cobwebs and a crumpled Beeman's gum wrapper in there, I think this clock has not been used in a few decades.  I think it spent much of its recent life in an attic or cellar or some such.  It sounds like horrible treatment, but all I can think is that someone must not have appreciated such a nice clock - digging it out of a long period of storage, only to donate it to a thrift shop.  Ah well, their loss...my gain.  I shall now have at least one more striking clock adding to the background noise of my little house.  That is fine; it is a quieter clock than most.
Edited by KarlvonKoln
I think what happens is people buy chiming clocks as they sound nice, then as time goes on the quarter chime gets annoying and eventually they get fed up of it and they are confined to attics/cellars or a little used room.  I did a charles Frodsham three train clock for a friend which had not been going for some time and exactly that happened. In modern times there are so many ways to tell the time, Mobiles, smart watches, talking clocks/watches the humble clock gets side lined shame nut true.
  • Sad 1
That's why many chiming clocks are fitted with a silent turn on or off. Striking clocks you just bend the hammer away from the bell or gong, but it is best to wind both sides up as some movements can and do jam up which will stop the clock. French clocks are a bugger for that.
2 hours ago, oldhippy said:
…it is best to wind both sides up as some movements can and do jam up which will stop the clock. French clocks are a bugger for that.
Same with my Kieninger here. After years of useless winding I finally solved the problem by blocking the fly with a bit of Rodico.
Yes, from what I can see, the Kieninger mechanism does look nice.  I've heard of those.
And I will certainly be winding all barrels.  I like the sound of mechanical striking clocks.  I grew up with them.  My parents and grandparents all had them.  And they kept them wound and in good order.  I was always surrounded by that sound.  When I first moved out on my own, I didn't have a clock with me, and on my days off from work it was so quiet at the apartment that I almost went mad.  After that I got a clock.
I can buy bushing wire here as well. I have to check with the supplier as to the internal holes sizes. Not real clear on the website.
When you say counter sink tools, are you referring to the 'sell-a-kidney' Bergeon ones? I haven't seen many others for sale and I'll admit I have not seen many tools on ebay here at all. I had a thought to making my own countersink tools out of square tool steel, but my grinding wheel is just not a fine enough grade to be up to the task.
    • I used to be quite active on The Lotus Forum when I owned my Esprit. I was there for so long, Bibs asked me to be a moderator. I'm not sure how long I did that for, but I think I turned into the second longest serving moderator. When I 'handed back my keys', Bibs made me a Full Forum Member. Normally this is a paid membership. My reward I suppose for helping out for many years. Bibs (forum owner) is quite active on there and if I am not wrong, don't quote me in other words, I think he once said that the money from memberships didn't cover the running cost. He adds money himself to keep it going. Does Mark have any sort of subscription scheme on here? I'll admit that I never paid to be a member on TLF. I should have. I never did. I agree that it would be a good idea that there is some sort of contingency plan for this forum. I intend on becoming more active on here. Life has just been getting in the way recently. I enrolled on Mark's watch course and was keenly doing that, but even that has had to take a back seat for a while. I am looking forward to getting back into that and also starting to do work on the clocks that I have been amassing. To do that successfully, I see myself needing to lean on the other members here. If for whatever reason this forum was to close, I think a great many of us would struggle.
    • I think we are about there, if there were still lots out there then the cost of a watch from 5 years ago would be around the same as it is now (allowing for inflation). Given that the price has gone up several times over we can only assume that supply cannot keep up with demand so we must be at or past peak supply, especially if the trend continues. I see even places like Australia, Ukraine and even South America are selling watches on eBay, picking over their stocks, mixed in with fakes and Frankenwatches etc.
    • I understand the demand bit, the generation below me 30ish are too technology engrossed to own a mechanical watch and they just dont like old stuff. I also consider myself at the getting on age of 57 to be a rare find of someone that likes old stuff, i did buy an almost 100 year old book yesterday titled " The New Modern Home " printed 1929.  Cost me a quid. What i was trying to work out is if we have reached a volume peak of watches being discovered hidden in the back of drawers.  Those watches that were hung onto until they entered the hands of the non sentimental generation.
    • Even for myself who only started getting into watch repair/servicing during COVID I have seen a huge jump in watch prices - we have a 404 channel on this forum. When I started you could relatively easily find a watch on eBay to restore and put onto the channel, however this is now almost impossible and the only feasible solution is to buy a job lot with an average price <4.04. Even watches sold for parts/spares are 3 or four times the price of only a few years ago. Why - Either Demand must have increased in order to push up the price, or supply is reduced. I think it is a little of both, I think that most watches in the UK/US may have been picked over, which agrees with most of what @Neverenoughwatches says so supply of all kinds of vintage watches, including tat is dwindling. As a double whammy I think that more people are wanting watches, either to work on, or as a way to differentiate themselves from the Apple Watch and FitBit crowd. The upshot is that half decent watches that require restoration are now $500 instead of $100 and cheaper watches (Seiko 5 etc) are now $50 instead of $10, and even Mumbai Specials and garbage are now pushing $50 each. When - how long will this last, I think that most of the people who are returning to mechanical watches are those that have previously experienced life without them and want to return to something with a bit of personality that doesn't buzz every 10 seconds on your wrist and tell you how many steps you have done today. i.e. the 30-40+ generation. My son who is 17 has several mechanical watches but only wears one on a special occasion and is obviously only aware of them at all in part due to my hobby. I asked him the other day how many of his friends wear a watch and he told me that some use a smart watch but most just use their phones. So as I see it, demand will start to fall once the sub-thirty crowd start becoming the majority and/or the older amongst us stop buying watches and switch our attention to mobility scooters and trying to remember our bank password. Price - I think this is here to stay, even if demand does start to drop as the older generation becomes to decrepit and stops buying and the younger generation isn't interested in buying, supply will become progressively less as time goes on as more vintage watches become lost or broken beyond repair. I think the prices will plateau at some point as an equilibrium is reached as reduced demand is balanced with reduced supply, i.e. less and less people buying less and less watches. Sorry for the long ramble!
    • Hi. Use a PVA based glue, gorilla glue it dries transparent then do as advised by Old Hippy, smoothe down using very fine  0000 wire wool and either French polish or beeswax for a finish.
