Hi all,
I recently got interested in vintage pocket watches after doing family tree research and finding out many of my ancestors were watch makers in Coventry. I met an elderly family member who carries on his family tradition and helps restore pocket watches and clocks for friends and acquaintances. He showed me the intricacy and beauty of these devices and taught me a great deal of history. It is fascinating how the Coventry watch legacy produced so many talented engineers and metal workers, when watch making went on the decline, these talented people used their knowledge to get a head start in the bicycle and then automotive industries, etc etc the stories go on 🙂
Anyway, my wonderful family member gave me a lovely Coventry Astral watch, my first vintage pocket watch, I feel very lucky. It works but most likely requires some cleaning and lubrication after 100 years as the second hand struggles after a while. So I've joined this forum to read, learn and absorb as much as I can so that I may be able to service these lovely old time pieces just like my ancestors did back in Victorian times.
Thanks and nice to be here 😊
How wonderful to have such a history.  I am probably the only one in my family lineage to take up watchmaking.  And I too have a deep adoration for antique pocket watches.  But I have not yet encountered an Astral.  Could we talk you into posting pictures?
And welcome to our forum!
Thanks for the welcome guys. As requested here are the photos of the Coventry Astral. From what I know it was original made in 1916, then was repaired in 1938, then further serviced in 45 and 49. I think it is a Swiss movement made in England with a patent. I tried to photograph all the super fine and tiny inscriptions inside the ALG Dennison case. Thanks 👍
The movement is called a full plate, it is at the low end of the market as the train which we call all the wheels from barrel to pallets are not jeweled. The pattern on the plates is known as Guilloché. Looks to have a Breguet Balance which I'm not sure as the photo is to rar away for my eyes a good clean close up photo is needed for me to be sure. The case is silver and by identifying the marks will give you the age. Enamelled dial with roman numerals and spade hands which I would say are original
It doesn't seem to me, is a flat spiral and regulator. The picture can be magnified, first click on it once and it will appear in a black frame, then swing the mouse across until the pointer changes into plus sign, click again and it will be magnified. Dismiss the picture view mode clicking the X top right.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • I found this string about this problem. I've not gone through it all, but I believe it also mentions making a spring. If not in this string, the info is online.
    • No, I now realise it’s broken😥 ive looked for one online, but v. Expensive! im going to service as is, in the hope that  one turns up. Thank  you.
