Janta / Pearl Watch Cleaning Machine
Hello Everyone
I have been looking for a watch cleaning machine here in the U.S. and i am not finding any used Elma machines
but i did run across the Janta Machine. It is a seller in New York who sells them, i talked to him over the phone and he said that they perform very well and he has sold a lot of them. He is getting some more in Stock in about 10-14 days
I was just wondering if anyone here in the US has used them, and will they perform well in the long run?
i would probably use it once a week, for i don't have that many cleanings right now.
Any info would be greatly appreciated. Here is a link to the seller in the US
http://www.tuxedonyc.com/files/TX268.html
thanks for taking the time to read this
p.s. This seller has it marked for $449.99 + Shipping
which is much lower than the ebay prices that i have seen
~Omar
Edited by OmarHaltam
I think our Lawson (check out the walkthrough section) has one and he even posted some pictures of it in his Seiko 7S26 walkthrough. I believe he talks favorable about them.
My own opinion is that you should look up PEARL which is the direct distributor from India...Also, they offer it for half the price you were quoted...If I'm not mistaken.
http://www.sunrise-exports.com/watchtools/equipments_machinery.html
http://www.shafatools.com/products.php
Hello Everyone
~Omar
It looks very much like an Elma (which I think Mark uses). I purchased & had re-furbished an L&R a couple of years ago & could not do without it now.
In my opinion if you can afford it and have the room go for it.
According to Elma the Pearl Janta is a rip-off, there was no licenced replica from India. I just got my Elma Standard from 1971 today. Searched for it for almost a year, but it is worth to wait, as this was now a bargain.
Edited by Cougarnaut
so could I have two beakers or jars with lids, fill them with watch cleaning solution and stick them in my Elma ultrasonic for cleaning.
I use a plastic tray for large parts and a mesh "thimble" for small ones.
Quick and and easy.
I like the way you marked the different sections  :)
I am thinking of trying the ultrasonic cleaning method since i have one on my desk running all the time.
I am going to order the bergeon 16mm and 23mm baskets and try that method.
i like the white tray in the picture, is that from a jewelry cleaner basket or bought separate?
thanks
Yes, cheapie from Cousins. Parts removed which are large enough go straight into it, and back.
I think that good watchmaking is more like practicality and efficiency than a parade of tools and equipment.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
