Hello! Hoping someone can advise on Kendal & Dent
My newest 404 candidate, a late '60's / early '70's Waltham with a UTC 33 / Seiko 6601 17 jewel automatic movement. It needed a new crystal and I put on a strap from my Strap Graveyard. The timegrapher was a snow storm before servicing but it cleaned up nicely. I really like the funky font used for the hour markers.
Hi Rich, the main problem with the balance is if the roller is from this movement. Did Yoy try if the balance interacted correctly with the lever? You can use suitable (by size) balance/hairspring couple from You pile of balances, but the roller must be for this lever (original for the calibre). Not that making roller is impossible, but it is easier to have one. -
Its ok blueharp the pictures you provided earlier of the 3 keyless components, the setting lever, the setting lever spring and the yoke plus the brass cover plate should be enough. If they are not listed anywhere then you are relying on any lettering on the movement or someone that just knows the movement from experience. -
Thanks jon, that would be my only option but i have bigger problems now with this one
