Hello From Virginia Usa.
djqsrv
Hello
Just wanted to introduce myself. I have been facinated by mechanical watches for as long as I can remember. I am now 42 and I finally decided that I might want to learn how to service and restore old watches. So I purchased an Elgin pocket watch and went right on ripping it apart and putting it back together. Broke some parts along the way but the education was invaluable. Sense then I have collected a small number of American pocket watches and now I'm moving onto wrist watches.
I stumbled onto this sight wile I was searching the net for a Waltham crown. (Still searching for that one :)
I am so glad I found this place and I look forward to learning as much as I can.
Daniel
Hi Daniel - welcome to the forum. My interest in watches started with American RR grade pocket watches - Elgin, Hamilton, Waltham, etc. - then the wrist watch interest kicked in. Lots of expertise and friendship here!
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
    • I overhauled a ladies Rolex and noticed erratic performance so I stripped in down again and did fault finding. This is what I saw. The lower jewel (the one in the plate) is cracked and the hole is too big. Before discovering this, I stripped down and re-cleaned the main-plate (and parts) by hand with a fine natural fiber brush. I somehow missed the fault the first time and cannot understand how it was still running. Perhaps re-cleaning it dislodged some pieces of the jewel widening the hole? I don't know. Now I need to replace the jewel but don't have a Seitz tool. The Rolex part is 2130-0913 and the top and bottom are the same. The part comes complete in brass setting with KIF elastor spring and cap jewel. Note: I have never replaced a jewel. I do have a good vintage stacking set that I've used quite a bit.  Can I replace using a stacking set? Any suggestions would be greatly appreciated.
