Kundo Clock Suspension Unit
bosstaki
Depends on the caliber,
Kundo, 49,52,53,54,55 use 0.0032" (0.81mm) HOROLOVAR
Kundo junior's 52,53,5455,56 use 0.0023" (.058MM) HOROLOVAR
Kundo Midget 58 use 0.0022" (.056mm) HOROLOVAR
The set up is very critical with a 400 day clock. The length of the spring & the position of the lever that operates the escapement is important.Also what is also important to get correct is the thickness of the suspension spring. Too thick or too thin & it becomes impossible to get the clock in time as you run out of adjustment. Even with the correct thickness sometimes it is necessary to thin the springs thickness a touch. Over the years I have repaired & serviced a lot of these movements & because they use very little energy to run for in theory 400 days with one wind everything has to be correct. I highly recommend you invest in a book "400 Day Clock" by Charles Terwillinger
Get a copy of this book The Horolovar 400-Day Clock Repair Guide
It is invaluable for anyone who is going to attempt to repair a 400day clock, although the name 400day clock had to be changed here in England, it was all to do with the trade description act, because some of the clocks could run more or less then 400days when fully wound, so technically it did not run for 400days so they changed it to anniversary clocks. There is also a very good tool that you can buy that helps to adjust the beat of the clock. I found it to be tremendously good and because of its long handle you can adjust the beat extremely finely.
I'm new to this forum. I've uploaded a picture of the beat setting tool for you. I hope it shows up and its not to big
post-1154-0-18360300-1433961445_thumb.jp
    • You often see the term used on old watch part boxes.  Staffs for bracelet watches, timing washers for bracelet wstches etc.
    • The Boro has changed quite a lot over the last 20 years, and not for the better. I actually moved out of the town 15 years ago to a small village not far away. Thanks for the pdf! Looks a great read. I'll get it printed today and put it on my work bench!
    • Not having all the fancy equipment, this is a way I came up with. I never said it was the best, the most ideal or the safest way. Working on balances is always a delicate task whereby full concentration & common sense should prevail. I was well aware of the "dangers" / short comings involved, hence my "warnings", as quoted above. The balance wheel of the Omega was nice true, flat and one could clearly see how much gap there was left before the grinding wheel would touch the balance wheel. I stopped when the generously applied diamond paste started to touch the rim of the balance wheel, which turned out to be with a seat thickness left of 0.1mm. Tapping the remainder of the staff out went easy and flawless. My idea of penning this article was to show/share a way which, in my case, perfectly succeeded. If deemed to risky, or if the balance wheel is not true or has a wobble, other methods have to be followed.
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
