Favre-Leuba 253 Service
Hey all,
Here is my first Service Walkthrough for servicing the Favre-Leuba 253 movement.  I found it easier to do this in a word processor and save it as a PDF rather than trying to make it into a giant post.  I hope that's ok.
I welcome any and all constructive criticism of the document.
FL_253_Service.pdf
  • Like 8
Thanks for the kinds words guys.  Glad you all like it.  I have more to come for sure.
If anyone is interested in the arrows I used for lubrication markers,  here they are:
Photoshop Format
https://drive.google.com/open?id=0BwTSe2ImNk_qeW1wQU5mV25Kb0k&authuser=0
GIMP Format
https://drive.google.com/open?id=0BwTSe2ImNk_qdGR3Y1F4a1F0amc&authuser=0
  • 8 months later...
  • 10 months later...
Tracy.  I think it is working again.  Maybe it was because I haven't logged in in quite a while?  When I click it it immediately downloads it rather than trying to open it in the browser.  Let me know if you are still having trouble.
