Very late introduction.
Plato
Hi.
I've been a member for 4 years and I never gave an introduction. I read a post earlier and it's considered a bit rude not to, so apologies. My excuse is that I only dip in and out every now and again after a google search for answers usually brings up this website.
I'm an electronics technician based in Wales and caught the watch repair bug about 5 years ago after 'upgrading' my Tag from a quartz to an automatic chrono... I set myself the goal of being able to service it myself when due.
I started mainly on quartz watches, especially those from the 70s and early 80s (mostly Seikos) and then tuning fork watches (ESA 9162/4) but after 3 years I realised I was mostly stuck in my electronics comfort zone.
Since then I've concentrated on mechanical watches and hope to become proficient within the next decade or so!
It's a great hobby and if nothing else it keeps me sober on a Saturday afternoon.
I've kept photos of every watch I've serviced (or tried to?) and will post something in the correct forum soon if that's permitted. My next project is a wrecked Valjoux 92 ?
All the best and keep up the good work.
I go to new members introduction to get an idea of his/her tech knowlege/experience, his horo tools arsenal, this often helps me give a more suitable response, nevertheless, my responses are often with considerable beat error.
Wouldn't it be nice if introduction section directs new comers to give more useful infos to our community.
Joe
Joe
Maybe a Q&A sheet? I wasn't too sure what to write.
Just a breif message of who you are your experience, we dont need the family history unless you want to give it what you write is entirely up to you how ever short or long.
Always remember to add photos of the watch /movement and or caliber numbers and makers as it helps members in their daignosis .    Thanks
    • Bringing this old thread back to life, as I have similar problem. I did follow this advice, but while inserting a male stem (crown side) and just pushed it to the female part, and the fork (female side) of the stem has broken. What is the right way? Push the stem part so it widens the gap and fits in? Why it was then receiving side got broken? Old metal? It is a vintage watch from late 60s.    or the outer part should be inserted somehow from the side (slipping to the gap), but I don’t have space there for this manipulation. The watch is Orient Fineness monocoque case.   thank you!
    • Thats insane Nev that you cut those tiny pinion teeth with a cutter you designed and made.
    • I certainly do Razz. Ive just started work on this AS554, interestingly enough it had a paper dial made from a postcard , look at the brand name on the dial, very curious.
    • [SBGA405] Grand Seiko “Godzilla” Spring DriveI always enjoy coming back at the end of the week to my first Spring Drive watch which is a combined automatic mechanical watch and a high quality quartz — a Spring Drive.Impressive accuracy (10 seconds per month) and wears remarkably comfortable at 44.5 mm in diameter and 95 gm.Love the power reserve indicator, and the colour of the dial amd the watch band.One of my “perfect” watches!!😍
    • Yep, so we got a 10 1/2  ligne movement, thats the starting point now these bad boys books should hopefully get us across the finishing line . Next we need a good clear picture of that rocking bar, the setting lever and the setting lever spring. I've already got an idea what it might be.
