Can anyone recommend a supplier of decent watch bands in the U.S.?  I ordered one from Esslinger and this is what happened the SECOND TIME I put it on:
I don't necessarily need top of the line licked by kittens and blessed by angels quality.  Just something that will hold up.
That's too funny! :) In any case, have you tried ofrei? I believe their quality is a bit better, some are the same though!
Cheers,
Bob
I have a few natos from Crown and Buckle and have been pretty happy with them.  My wife bought me a leather strap from Worn and Wound for Christmas and it is also very good quality.
Just wondering about selecting the correct size for this band.  The crappy band was an 18 mm and as you can see it is a bit smooshed.  The next standard size seems to be 16 mm.
I measure the width between lugs on this watch to be 17.43 mm.  What is the right choice for this measurement?
As the others have said, for leather I think the 18 mm should be fine.  I just measured my NATO from Crown and Buckle and it was exactly 22 mm so that kind of strap might be a tighter fit.
If we complicate it ? The right size for your watch should be a 11/16 . That is 17,43 mm . There are straps out there in that size . But i would go for a nice 18 mm strap . From Hirsch och Rios . Rios has some very nice straps .
I'm surprised with that failure. I've had good quality from Esslinger. They will refund with no hassle though. They also carry a line of 17mm bands. I would go for one of those. I did for a vintage Elgin and am very happy with it.
Good luck,
Stu
Edited by Gotwatch
Esslinger did indeed refund my money with no issue.
The band from Ofrei arrived and I am quite pleased.  Here is the fit.
Great fit and color! I'm glad everything ended to your satisfaction. I do order a lot from esslinger and they have always come through!
    • First of all, thank you for the pdf file of the book on how to replace a gem. So, if there is a problem with the ruby in the movement, should I buy a new or used movement and replace it? When I watch videos on YouTube of people fixing used watches, I feel like there should be a way to buy a gem. Is there no way to buy it?
    • I suppose @donutdan is not forced to earn his living by repairing watches.  I suppose he does it as a hobby and wants to gain experience, to get better in watchmaking and time is not the issue. Then @donutdan should rather try to repair the damage instead of swap parts from a maybe intact other movement. Swapping parts is not watchmaking. And often swapped parts are not the expected solution of all problems. All mentioned damages are repairable. Frank
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
