New member w/rust surprise
Finished Mark's second course, looking forward to 3rd.  Not sure if I'm obsessed more with movements & tools or Mark's videos. ?
Have a few projects in flight right now; learning many things, mainly what not to do! (removing springs without securing them, not taking enough pictures, being impatient/in a hurry, etc.)
Disassembled & cleaned 50's ETA 1256 in ultrasonic bath, rinsed in plain water and laid out to dry.  First time cleaning a movement.  Most of the parts & screws now have what appears to be surface rust which was not there prior to cleaning.  I'm thinking maybe this is related to not actively drying the parts quickly or maybe the cleaning solution (came with the cleaner) or maybe rinsing with just water?
Is there a simple/easy way to fix?  (ie., soak them in a different solution/actively dry?)
Any insights greatly appreciated.
Thanks!
Best, John.
Hello John  rinsing with clear water, distilled or not and air drying is most likely the cause, best to final rinse in isopropyl Alcohol and dry with gentle heat, a hairdryer or the like. that way no water remains on the surface. Other members will have other ideas and other methods which they personally use and will all be valid so the choice will be yours.
Oh goodness, all you need for a delux rust is water.
With the exception of the fork and balance wheel I give everything else a bath in lighter fluid IN ULTRASONIC.
Stick the fork pivots into pegwood or tooth pick( turn the tooth pick) peg them pallet jewels and brush the rest of the fork with a bit of lighter fluid.  The fork should not spend but a few seconds in lighter fluid.
A quick bath( NOT IN ULTRASONIC ) wount  hurt the balance complete.
Good luck pal
    • I am pretty sure the correct practice to insert a tensioned crystal is to use a crystal press - although I always hate doing it as one slip and the crystal can skid across your dial, this happened to me on a Tissot, mangled all the hands and scratched the dial down to bare metal. I much prefer to remove the bezel and install the crystal into the bezel and then the bezel back onto the watch, not sure if this is an option for you?
    • Well, Geiger counter showed up today and the dial and/or hands were extremely radioactive, reading quickly spiked from a baseline of 10-20 cpm to 100 and was still rising when I removed it. Trashed the whole thing. Thankfully nothing else outside the components was registering - work surface, tools, the paper I had used to clean off some components....    And now I have a Geiger counter to use to  check practice watches BEFORE disassembly
    • Usually the coiled spring contacts the piezo sounder and the finger spring is the ground.
    • So I checked with my friendly local lab supplier and they can supply the following in 2.5 lt bottles: Tetrachloroethylene (B-Dip) - approx £65 Trichloroethylene (one-dip) - approx £43 n-Heptane 99% (Essence of Renata) - approx £35 Hexane - approx £45 I can't import or buy locally the 'real' products, hence the raw chemicals above. What do you think would be my best option? I'm edging towards Trichloroethylene - I know there are greater health risks, but given the very small quantities used for each treatment and 99.99% of the time it will be sealed in a jar, I think any risk is vanishingly small? This is mainly due to its assumed superior cleaning properties, or from the experience of this group, is the extra cleaning noticeable compared to its safer alternatives?
    • Unfortunately after much investigation, apparently the coil has been discontinued! Shall I get my service guy to try the solder or the conductive paint? 🎨 Final recommendation please🙏
