Rotary mp00712 running too fast
Hello!
I have a Rotary mp00712 skeleton pocket watch. It was bought for me as a gift several years ago. I love it but it runs a bit fast (several minutes gained per day). My other pocket watch has a very clear lever in the back with a +/- adjustment, but I havent been able to find an equivalent on the Rotary one.
I have managed to unclip the glass (front and back) to see if there was an adjustment that I couldn't see, without success. It was hard work getting the glass to clip back on - any technique I should know about? There are plenty of pictures online if you google "rotary mp00712". Mine is a gold one but I don't expect that matters for this.
I'd be happy to take any specific photos if it helps. I love the watch and wind it every day, it would be nice if it would tell the time reliably too!
Thanks,
Stewart
While that is a true statement that there are plenty of pictures online they are worthless for what we need. We need a picture centered above the balance wheel on the back side. Then another decent picture of just the entire movement on the back side.
Update: I have made a few adjustments over the last couple of days, resulting in the image as below. It turns out that both of the little silver arms move, I'm not sure if it matters where they are positioned, or whether it's just their position relative to each other, but it seems to keep fairly good time now. Running ever-so-slightly slow this morning so I know the range and need to make my tweaks smaller!
Thanks so much for your help.
The arm where the end of hairspring is adjusts the center of oscillation, as explained in this video by our Host Mark Lovick. For an accurate setting of that, as well of the rate, a timegrapher is needed.
That looks like a "Tongji" or Chinese Standard movement.
https://en.wikipedia.org/wiki/Chinese_standard_movement
I suspect the coils on the balance are touching while it is running, or there is oil on the coils, or the movement simply needs servicing.
Can you post a current picture of the balance at rest. i.e. after you adjusted it.
The good news is that the movement is very easy to find and to get spares for. The quality of the movement is variable though. Some versions are actually quite well built, and some are, well, not so good to put it politely.
Rotary used to only use Swiss movements, but their more recent offerings use movements from China, Japan and Switzerland.
I have a couple of watches with skeletonized Chinese standard movements and they are reasonable time keepers once cleaned and oiled, so you should be able to get it working acceptably well.
Edited by AndyHull
You could use tg-timer from here -> https://tg.ciovil.li/
There are also a couple of phone apps that can do watch timing, but I haven't tried any of them.
I do however use tg-timer on my laptop, which is almost as good as a "proper" watch timegrapher.
Unfortunately, as most readers here know well, there is little chances of getting realiable results from a PC or mobile app without using a proper microphone. That should be told t9 beginners in order not to set wrong expectations. The thread below is about that exactly.
I think this is getting a bit beyond my capability (and aspirations)!
I'll wait for the watch to run down and take another picture as requested, but I'm minded to carry on with the tiny tweaks until I get reasonable performance and if I don't manage it I'll look up somebody local to service it once things start opening up again.
The internet is a wonderful place for help with anything and everything, I'm grateful for your advice. If any of you experts happen to live in the East Devon area and would do a service that might be of interest!
Quote
I agree completely.
I personally get away with using the built in microphone on my laptop or the one in my headset, however your mileage may vary.
You also need a very quiet environment, otherwise you will pick up spurious noise from your surroundings. This is why a good quality microphone in a sound proofed container is a very good idea.
This is one of the advantages of a "proper" time grapher. It includes the microphone and a clamp that lets you time the watch in different positions. They are probably also a little better at filtering out noise from their environment.
For hobby use though tg-timer has served me well.
Edited by AndyHull
If you are careful, and take your time, there is a pretty good chance you will get it working.
By the way, "The basic specification of the Standard wristwatch caliber is a minimum of 17 jewels, 21,600 bph (beats per hour) escapement, a minimum 40-hour power reserve and an average rate within +/-30 seconds per day."
The ones I have perform better than this, but an average rate within +/-30 seconds per day is the figure to shoot for.
Edited by AndyHull
    • We need to identify the movement to help you, but the oldest of these Rolco watches use Aegler-Rebberg movements that lack a calibre number and are very difficult to identify. You may end up having to make or modify a stem to fit . Post pictures of both sides of the movement when you have it and the size of the movement and hopefully it’s one that has a calibre number.  Gruen used a lot of the same Aegler movements at the time and it’s worth comparing your movement with those if you can’t find it labeled as an Aegler or Rolex/Rolco calibre. Best Regards, Mark
    • Onlly a pro's eye would notice that OH, you've still got it old fella 🙂
    • The triple lobed spring, as you suggest needs to be rotated to remove it or replace it. Suitably shaped pegwood should suffice, but tools (shaped as you describe) for the purpose also exist.  If you have an assorted of replacement springs, a trilobe style KIF spring of the right size might fit.  The other spring securing the jewel also needs rotating. There is a slight opening in the setting at about the 5 o’clock position in your photo and one side of the spring should be able to be removed  there when rotated into position.  Hope that helps, Mark
    • As an update, it transpired the setting on the balance side, with the jewel had one flat end and one curved. When I rotated it enough it popped out. The chaton was entirely conical and a tricky customer but once lubricated and dropped back in I put the flat edge in first and poked it in with the peg wood tool mentioned above (I made it with flattening off the end then sizing with a pencil sharpener before poking a hole in the end) then rotated and it went in well.    For the other side, magnet searching for the spring has been fruitless.    thanks for the link to the other thread
    • Thank you. It didn’t look rusty. For sure old.    Female part was inside the movement, and when I pushed male part, it got broken. I didn’t apply grease. Here is the photo.      Could it be that male part is too thick for some reason?
