Nice to be here
Hello all!
I'm Eli. From Iran, raised in New York, and just moved to Los Angeles. I've always been fascinated with the trade since watching my grandfather in Iran work on little Soviet clocks in his free time. I've had hobbies in cars, motorcycles, and musical equipment since I was a teenager, and have found many of those skills useful here.
I finished all three levels of Marks course about a month ago. I've also made may way through a couple of books, including Practical Watch Repairing and The Watch Repairer's Manual, amongst others. I'm currently working on Bench Practices for Watch and Clockmakers, which I have found to be fascinating and highly recommend it for any other beginners looking for more literature.
I've decided joining the forum would be a great next step as I have come across an increasing number of dead ends in my watch revival projects and could really use some more experienced brains to pick. I look forward to our adventures together!
53 minutes ago, alibababoombap said:
Hello all!
Welcome Eli (myself a new member only recently).
Your user name is one of the most fun to say - I hope to see it regularly!
Edited by Flagstaff
Hi Ali, welcome, I also am new to watchmaking and so far have found the site very helpful as I am sure you will also.
My grandfather was an amateur watchmaker in his spare time too, train shunter by day, he unfortunately passed away when I was 9....71 now, but he left me a 1840's pocket watch which is what got me started. I'm sure you will have very fond memories of your grandfather.
Again, welcome Ali.
Graham
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile, and not less mobile which is the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic and cohesive/adhesive resulting in low mobility?? This may explain the high price??
    • The description there is exactly how it's done, and it's very well written!
    • Would it be correct to say that the stronger the mainspring, the thicker the oil should be? So for a fusee mainspring, should a thick grease be used?
    • I started on pocket watches as they are easier to work on than wristwatches. Many had gold cases, which is why there are so many movements for sale. I was always on the look out for cases, for as Nickelsilver says,  a 16s movement will fit any 16s case* (with tweaks to the stem). I also started hand winding mainsprings, before I had winders. It can be done without damage, but it's quite hard on the fingers.  But you can make homemade winders, see here      * some movements, eg "railroad grade", have a setting lever on the edge of the  dial at about the 1 -2 o'clock, so need a special case.
