Pocket watch.
1 hour ago, Alexandros said:
Hi, so I just bought a broken pocket watch to learn a bit. If i push the button next to the crown and I change the time forward the mainspring starts running but if I wind it it won’t doe anything, does anyone know what I have to do?
O boy.. Let me try to explain.
When you push and hold that thing with your thumbnail it allows you to move the hands forward or backwards. When you release that thing, you should be able to wind your watch by spinning the winding crown in one direction..
If it does not work that way, you may need to disassemble your watch partially for inspection.
Edited by Poljot
If the seller promised that it was working, return it and ask for a refund.
Otherwise if you will try to repair it yourself I wish you better luck than with the Seiko you have asked about previously.
There are two possibilities,  As Poljot said, The mainspring is broke or the spring is off the arbour in either case you will have to remove the barrel and have a look.  It looks like a cylinder movement so be careful with it people who can fit new tampons are thin on the ground,.
2 hours ago, Alexandros said:
No no the seller showed 10 or so and said idk if they are working, there was one which was working but I didn’t like it.
so I taught maybe I could fix this one but yeah rip lol.
Of course you can with just a little effort. The good thing is that you do not need a timegrapher to fix this watch. Just a screwdriver (-s) at this point and a new mainspring later... There is always a chance that the old mainspring could be repaired (not recommended )
I'm proud to fall into that category but I still depend by my mentor's stock. And since the OP wrote that he can wind the mainspring, that is the most likely failure, - a broken pivot. A broken mainspring cannot be wound.
Sorry for being somewhat OT but I thought I'd take the opportunity to ask about what signifies a cylinder movement.
Looking at this video it would seem that what signifies a cylinder movement is its escapement, the way the balance interacts with the escape wheel teeth. That part on the staff is obviously called the "cylinder", hence the name of this type of movement, yes, no?
Now, the word "tampon" I associate to something quite different than watch movements. Is that slang for the cylinder part or something else?
Edited by VWatchie
5 hours ago, watchweasol said:
Hi jdm  if you fall into that catagory you have my admiration as there are not that many who will even attempt to fit tampons as it takes great care.
It is not that difficult but is a case where one really appreciate having ready top quality tools like a Feintaster micrometer, a complete staking set and of course the small stakes for tampons. They come however in hundreds of sizes so you must have a vast assortment, then some refinishment may be expected to the total lenght ot pivot shoulder.
3 hours ago, VWatchie said:
Sorry for being somewhat OT but I thought I'd take the opportunity to ask about what signifies a cylinder movement. Looking at this video it would seem that what signifies a cylinder movement is its escapement, the way the balance interacts with the escape wheel teeth. That part on the staff is obviously called the "cylinder", hence the name of this type of movement, yes, no?
Yes a cylinder movement uses a cylinder escapement. As watchweasol correctly said, the tampons are plugs in the ends of the cylinder which are also the pivots. As the cylinder is drilled through (thus a cylinder, haha), plugging the ends is the only solution. Tampon is French for plug.
I've never had a huge assortment of tampons or cylinders, and always figured that by the time I sorted through and made whatever modifications necessary I could have just made a new one so I do that. Cylinders are a bit of a pain to make, the tampons not so bad. I do have a large assortment of cylinder escape wheels and wouldn't want to try making one!
    • That's the right technique Mal 👍 If you are ok with a loupe ( which I'm not ) then pick up the dial in your left hand and make a tripod holder out of 3 fingers and then exactly how Mal and me described with your right hand, press and flick out the stem at the same time. You need three fingers to do this, i use my ring ring finger , sounds like mal uses his little finger, just whatever you feel comfortable with. The key point and dangerous side to this is the tweezers or driver slipping off the release screw. Stablise your left arm by resting your elbow on your bench, so that you can hold the movement horizontally flat, use a x5 loupe to view  and good light so you can see well and have a good tight fitting screwdriver to push the release down. Or as suggested a pusher mounted solid upside-down somewhere then all you need to do is push your movement up to it. I'll rig something up in a bit to show you what i mean.
    • Thanks Michael, shes a real soldier, it would take a tank to knock her off her feet.  Shes surprised even me and i knew she was a tough cookie.  Good for you Michael, you keep at it. I've been reading your posts re. your watchroom they're inspiring and it doesn't matter how long it takes you to get there its about the journey. Rome wasn't built in a day, our watchcaves are our solitudes, our own little empires where we can shut ourselves away from the crap that goes on around us in the world. I look forward to seeing you progress, I have my own ideas how i like to do things. But in answer to your questions on that thread, just let your workspace evolve around you and how you work. You wont figure it out straight away but you will know when to change it and when to leave it alone. But most of all just enjoy it.
    • That can be tricky. Sometimes I hold the movement from the edges in left hand and with right hand I push the release with tweezers and simultaneously pull the stem out with right hand pinky or something.
    • I see what you mean. I must admit I’m not entirely comfortable with that but I can’t see a better method than what you suggest. I’d like to see something like this mirror with a short spike: https://www.cousinsuk.com/product/mirror-for-observing-movements Place it on, push the spike on the post with one hand and release the stem with the other hand. Minor problem, it doesn’t exist.
    • Hope you mum keeps on mending. I was adamant that I was going to get myself going after my stroke. I was only 52. I still have a lot of life left to live. Some people give up. Some people don't let it beat them. Your mum sounds like one of the winners. 👍
