Seiko 6139
Hi all experts.
i have recently brought a seiko 6139 chronograph from Venezuela which wasn’t working at the time and I had tried to fix the balance but ruined instead.
I have brought a donor movement to replace this whichh the balance on this movement was working fine and spining  freely.
now I have reassembled all of the movement and Serviced it. All wheels are working perfectly, the pallet fork is working as it should. However, when I then put the new balance on the movement. It doesn’t spin freely and doesn’t work as should. I have tried the pallet fork in both positions and the balance does nothing but struggle to spin freely. Can anyone advise.
Without the pallet fork does the train run freely when you wind the mainspring?
As you have a spare movement......
Have you swapped the pallet fork and or its bridge? Try swapping the escape wheel as well.
Finally have you oiled the diashock jewel in the balance?
Edited by Melt
Check endshake on staff, if no endshake, both endstones might be pushing on pivots.
You can also loosen the stud screw 2 to 3 turns to release pressure on end stones.
if this did no good and you haven't check both the upper and lower jewel assemblies, you might have broken or very dirty jewel.
Third possibility is if something is rubbing, like hairspring runbbing on balance spokes or the cock, or pivot shoulder rubbing on jewel housing.
Good luck.
Good luck.
Correction: You can also loosen" THE COCK SCREW"   2 to 3  turns to release presuure on endstones.
I had written "stud " instead of screw.
Loosen the screw to a point that staff shows a bit of emdshake, nominally .02mm endshake is ideal.
If the issue turned out to be "no end shake" you might want to shim up balance cock or bridge to create some endshake.
What Joe refers to is the balance cock( the part which holds the balance wheel), Just back off the screw a half turn and see if the balance starts up, Check the end shake of the balance wheel if it now runs shim the balance cock with a little aluminium foil (temporary )and re tighten the screw if it still runs  then the problem is lack of end shake. If that is the case the balance jewels/settings may need adjusting.
I'm having a minor confusion here? So the first part you have a donor movement balances in everything works fine?
Then his service the watch but you have a reference to putting a new balance wheel in? So is this the balance wheel that up above was working fine or is this an entirely new balance wheel?
If I make the assumption that the donor movement balance wheel was working fine and that's still the same balance wheel after servicing it's not working fine then there's probably still nothing wrong with that balance wheel. But if you find when you're tightening the bridge screw for the balance wheel balance stops spinning it may be the balance  jewels if you took them out. It's usually not clear in the servicing guide but the end  stones have a curved surface and a flat surface. In some watches there actually a different thickness whether there on the one side or the other. you want to make sure that the curved surfaces out because otherwise that is a place you'd lose your end shake.
I am attaching a picture as that's always helpful hopefully.
According to my Seiko parts interchangeability guide, the upper and lower cap and hole jewels are identical. Swapping them should not be an issue. There have been a lot of good suggestions made here. What does the balance do with the pallet fork removed? does it have good motion then? How about with the hairspring removed? It should spin freely. just some things to check. According to my Seiko reference on the 6139A, the chronograph adjustments can be a real beast to get right. make sure the time train is in good condition before starting on that.
On 12/17/2020 at 1:08 PM, RyanGreerMcGilloway said:
How can I unscrew this balance staff because I think that might be the issue. Just having the staff pressed down with nor movement in it
Sorry, I meant loosening cock screw, miswrote the word stud instead.
Considering that balance spun freely on other movement, staff pivots are alrignt.
Moving jewels as weasol says is actually prefered to shimming, seiko jewels are easy to move, I can move em without jewelling tool.   ?
Hi all I think I have finally discovered the error with the balance. It wasn’t the balance itself. It seemed to have been the pallet fork. Now, I’ve purchased a NOS pallet fork for the same movement and I’ve come Across another hurdle, whenever I Place the fork in its jewel and the bridge on top and screw into place. The forks snaps as it should a few times and then seems to jam and I can’t figure out why. This is the course to the balance not turning. The wheels work perfectly when the forks not in place as well
Do you have enough end shake on fork arbour?   if yes;
I would keep nudging the fork to snap until it jams there ink mark the escape teeth and the pallet in contact with the teeth.  If it kept jamming on the same tooth, that is where the fault is, most likely a defective tooth, perhaps dirty.
One you have ink marked the tooth, you might put the oscilator-cock assembly back on, shake to run the oscilator at low wind, see where it stops.
Good luck and happy Christmas.
    • Thanks Rich, its really not that difficult to make them, simple ones anyway. Cousins didn't have the part though i could find it on ebay at 6.50. I figure i earned about £1.50/ hr . It paid for the diamond files i bought.
    • If you look at this thread, you can see I had exactly the same problems with balance springs with 2 prongs on a Smiths 627. The slots in the chaton were not big enough to get the ends of the spring out. I had to bend them to get them out and back in. Not ideal. I don't fancy having to do it again as they could easily break, and where would you find replacements? I didn't come across the 3 prong type.
    • I visited the Breguet Exhibition today. https://www.sciencemuseum.org.uk/about-us/press-office/rare-timepieces-unveiled-new-display-science-museum The Science Museum now holds the collection of "The Worshipful Company of Clockmakers" - "The collection includes more than 600 watches, 90 clocks, 30 marine chronometers and a number of fine sundials and examples of hand engraving, mapping the history of innovation in watch and clock making in London from 1600 to the present day." It's well worth a visit. They have some amazing pieces by the likes of Harrison, Breguet, Tompion etc . I've visited twice before but decided to go and see the Breguet Exhibition. Maybe I was expecting too much, as on reflection, "More than 20 extraordinary timepieces designed by inventor and watchmaker Abraham-Louis Breguet " isn't going to take up that much space. In reality, it's just one cabinet. But, Oh those watches, stunning 🤩 , e.g. (No 1297 was made for George III and is valued about £1m)   I tried a couple of pics, but with subdued lighting and taking through glass, they aren't good. I like thin hands on a watch - how about these (I think this is a split second chrono)   And this one, with all it's complications, is only 10mm thick !   What I found very interesting were a few very old machines for making watch parts, like this 17th Century gear cutter. The disc below has concentric rings with holes in, so that is can be set to cut varying teeth numbers.
    • Firstly sorry for poor image quality I only have an iPhone for photos.    Im working on a 512 movement and I’ve had some trouble with the “jewels”. I’ve got the metal one out, but when I tried to put it back the three sides of the spring seem to need pressing all at once to fit it as there are three “holes”. I get two corners in but as I go for the third the first two pop out! Constantly I’ve lost the spring. I’ve done the similar ones on seiko movements without trouble. Assuming I find it/a replacement, what am I missing!   on the other side with the only ruby in the movement is a setting with no “gap”at all. How do I get the spring out, and of course get it back in!    What am I missing!    thanks in advance.    Rob
    • Links like that are the reason I routinely donate to the Internet Archive - they are the last safe house for a tremendous amount of useful info that is otherwise lost.
