French clock update
clockboy
I have spent many, many hours in my workshop restoring this clock after it arrived totally wrecked (see pic). There are still issues that need resolving. 1. the minute hand Is not correct and is just a modified hand that came with the clock and as yet I have still not found a replacement that fits. 2. The chiming sequence goes out of sequence now and again. The issue might be when in the strike mode it runs very, very fast so it might be skipping the count wheel, maybe !!!.. or The fly wheel bushings might need replacing!!!
However lessons learnt. When sticking alabaster together use epoxy glue BUT mix it with some alabaster powder. This hides the joins (almost) When replacing the pendulum the numbers found on the rear of the case are really useful. This particular clock has 4.8 and using the PDF (see attachment) it gave me the length required and also the BPM expected. Using the Clock master app on my iPhone it was almost spot on with regard to timekeeping. If careful spelter can be drilled and have a thread tapped into it. When gold leafing use fresh  size and after applying leave for at least 15 mins before attaching the leaf. To get a smooth finish I found my finger gave the best results.
BEFORE
AFTER
FrenchClockBeatRates2.pdf.pdf.pdf
Dude!  That's amazing!  I remember that original post where you showed the pictures of it arriving in pieces.  Your description of the restoration sounds both arduous and educational.  But the clock certainly has come a long way.  From the pics here, it looks like it was worth all the work.
To hold the case furniture I used a small amount of epoxy putty.  To complete the joins I used epoxy resin. I then rubbed all of the case down with 2500 grit and a little water. I then polished with clear wax.
ps the chiming issue is (I think)I removed the count wheel without marking its position so I will  have to remove and try in another position. However my wife loves the clock and doesn’t want me to remove it ☺️
If you look carefully the square the count wheel fixes onto some have a mark on it for a guide for fitting it correctly.
BEFORE
AFTER
What a super job, well done!!!
Its a countwheel issue.  They are bastards, especially if a previous meddler has "manipulated" it.
You did an incredible job rebuilding the case!  Alabaster? Marble?
I was in vienna at a very fine clock shop where i bought a marble french portico clock.  It arrived at my house in the USA as pile of dust.  I was so upset!
Years ago i bought a late 1700's early 1800s alabaster clock that was in pieces in several boxes and glued it all back together.  I enjoyed that.
Cheers!
Yes it is annoying but that’s all part of the fun. The issue I have is my wife loves the clock and does not want me to remove it. Quote “I don’t count the chimes I just know it’s either half past or the hour”.
I will tackle the issue after the festive time. My only fear is that the count wheel is not the original one which will be a challenge.
    • I suppose this fits "best" in this forum 😃 Im looking for some wall 'art' that doubles as a reference. Specifically Id like to find an ETA 28xx or Sellita exploded movement view. 2824/2836 would be ideal. Have any of you seen/found such a thing - there seem to be a lot of these for specialized movements, and none of them ready to print or to be had as a poster. Why help is appreciated.
    • The diameter is that of the ring - afaik, will have to look it up. “Wiggle room“ doesn‘t matter as long as the spring length is in the ball park.  Essential sizes of a mainspring are thickness, width and length. Diameter is just a hint if you can push into the barrel directly or will need a winder, it is no property of the spring. Frank
    • Hi @Zendoc, I guess you're like me and you don't have a mainspring winder.  I searched GR mainspring for the AS 1686 mainspring and I now understand your dilemma. The exact one is discontinued. To answer you question more directly, I see two good alternatives for you: a) GR4485 with 1.60 x .10 x 280 x 8.5 ( I guess this one is the one you found): https://www.cousinsuk.com/sku/details/mainsprings-by-list-watch-pocket/GR4485 OR b) GR4477 with 1.60 x .095 x 320 x 9. https://www.cousinsuk.com/sku/details/mainsprings-by-list-watch-pocket/gr4477   As you know, the the AS 1686 spring is supposed to be 1.60 x .10 x 300 x 9. - both of the above will fit and you'll manage to insert them from the retention ring without need for a mainspring winder (provided you know how to do it). - GR4485 will give you more power (=higher amplitude), but less power reserve (due to shorter length) than the original. - GR4477 will give you the same power reserve as the original. However, a bit less power.   Personally, I'd take GR4477 for two reasons: 1. Well, the power reserve is better. 2. With modern lubricants and modern mainspring metal alloys, you tend to get a higher amplitude anyways. You'd maybe even end up with too much amplitude (knocking) if you go with the original size and use thin synthetic oils-- see discussion here: https://www.watchrepairtalk.com/topic/10580-omega-calt17-help/#comment-248101
    • Your setup is correct. The smallest diameter of one pulley must correspond with the largest of the other one, else not speed variation. Frank
