Chronotachymetre Servicing
I found a rather elegant chronograph pocket watch on the bay recently. It was listed as non-running so I took a punt on it. Not cheap, but I liked the dial. The watch wouldn't run if the chrono was engaged, and would barely run without it. It's a French watch made by LIP.
Popped the moment out of the case to have a look. It's very pretty in there...
Time to strip it down. Took many photos so I could put it back together in the right sequence. Here's a bird's eye view of the chronograph works
Removed the operating lever, pillar wheel, transmission wheel and various springs
Removed the chronograph bridge:
And the movement's now just a plain ol' pocketwatch movement:
Time to see what's wrong with the movement itself:
...and found the culprit, or at least a suspect! Cracked 3rd wheel jewel:
Spent a quiet Sunday morning sifting through my box of random jewels until I found one with the right diameter for the pivot:
Reamed a wider hole and fitted the new jewel. I was pleased the colour matched the old one:
Now I can put the movement back together. With the new jewel and a lot of cleaning the watch works extremely well - one or two seconds fast and only a little beat error which I'm going to ignore. Putting the chrono works back together was relatively straightforward - just a matter of lubrication and adjusting the eccentrics so that the depthing was correct:
Time to fit the hands. The second hand for the chrono wasn't tight enough on the arbor, so every time you re-set to 0 the hand would spin! Tightened it with a cannon pinion tightener - there must be a better way!
Movement goes back in the case:
And another fine watch for my collection of slightly-battered-but-working-well watches. This was the first chronograph I've done, so I'm extremely pleased that it's working nicely. Learned a lot in the process. One of the things I learned was not to use Naptha on dials. The astute observer will notice that the word LIP has vanished from the dial. While I feel extremely guilty for having done this to a 100-year old watch, I'm secretly delighted - the first thing my wife said when the watch arrived in the post was "lovely dial, pity it says LIP on it...", and I agreed.
Thanks for watching.
  • Like 6
I do it this way - it often works.
  • 4 weeks later...
Brilliant job - well done. And I really love that watch - it's a cracker.
Regarding the hands, I can never be bothered with doing it with a lathe collet - the pin vice is always to hand and a lot less messing around.
But you might argue that a lathe collet would compress more evenly across the length of the tube than a pin vice.
Here is yet another way of tightening a second hand that is only a little loose - with digital output!
Somewhat like canon pinion tightening.
I like your thinking Colin!
Another great use for digital calipers is removing splinters from your skin. They grip a lot better than tweezers and even let you know what size the skelf is! :)
Both new uses of caliper noted for further use! I can combine them when a splinter gets in a watch's hand... aaaah! Just me and one of those moments!  :)
Great thinking guys!
@Colin: Good to see you around, Colin and as always with great input! Cheers!
Cheers,
Bob
Geo that last suggestion is hilarious. I just had an image of me trying to pull out splinter from my foot with a digital caliper--
JC
I wasn't joking Joe, they are brilliant for that. Working in engineering I was forever getting tiny slithers of metal in my fingers, and the callipers always worked when tweezers failed!
Excellent wakthrough and job!!!
Congratulations!!!
Another way to evenly tighten a hand tube, is by using the appropriate size of a punch stake in your staking set. Just find the one that nearly fits the tube diameter and push the punch lightly onto the hand (no hammer needed just a finger push from the top).
    • Couldn't see it on the tech sheet , picture is a bit fuzzy though . Is that to keep the pinions pressed on Marc ?
    • Doctor, If the train turns when hands setting, this means that the train is not blocked. And this is true for all kinds of trains design. The train is normally blocked by the lever. So, put the lever in place and try again. If the train turns again, search where You have placed some wheel upside down and it is not meshed with the next one in the chain. The other thing is the amount of friction that is needed to overcome when setting hands. Yes, the friction part here is in the great wheel, and it needs lubrication. If the parts are dry, then friction will arise, seizing will happen and thus risk of breaking of teeth in the train or breaking of joint wheel/pinion. I don't know this calibre, but I guess the clip is part of the friction device. But for sure it stays tilted, which is not normal. So, pay attention to it and see what is wrong there
    • It most certainly should be there, but it should fit better than that. Here is what it should look like.
    • This way is dangerous. The problem is that the collet is not expected to be perfect in this tool and the wheel used for the grinding is big and easy can touch the balance wheel. Can You show the bottom side of the balance wheel?
    • It shouldn't be attached    The pinions look independent of each other, not in alignment,  but the clip is bothering me or have you just placed that on the pivot end?  Found a cannon pinion maintaining clip in the tech sheet, is that the disk on the end and is broken.  Whatever happened to exploded diagrams 😠
