My new victim
Ammar
Hello everybody
I got my self this ladies watch to play with, I hate ladies watches but I liked this one, it's barely running I think it just needs a good clean the proplem is this is the first time I come across this type of balance jewel assembly and I'm not sure if I should take it apart clean it and oil it I've seen it on youtube but I've never done it.
You think I should give it a try and risk ruining the movement?
Hi Ammar  nothing ventured nothing gained, Granted they are more fiddly than gents watches but the same rules apply. Document what you do (photos) at each stage and take your time and most of all be carefull,  They are quite a bit smaller therefore finer engineered and by such easily broken, but having done it and got a worker the experience gained . is well worth the effort    The last one I did was ladies ball watch the size of a marble with a broken balance took a day or two but worth the effort.      wish you good luck.
Hi Ammar, I preume you are talking about the jewel assembly, no shock protection just end stones. Its easy if you go about it the right way.
1- Unscrew stud screw, push on stud a little to make sure its loose enough to come out, all while the cock is still on mainplate.
2- Take balalnce& cock assembly out, flip it over and lay on hard flat surface with the balance on top, turn the boot to release the hairspring, You can flip the cock over again so balance would be dangling down, hold the assembly about a CM or less above bench, push the stud out, balance falls out, one CM drop would not damage the hairspring,specially if dropped on tissue paper.
There are two little screws holding the end stone plate, break easy, I soak the cock assembly in coca-cold over two nights, coke will penertate the screw thread so screws can be remove with incredible ease. Dress a driver blade for perfect fit into slit of the two screws.
This method is prefered since you can check the jewel and end stone as well as good access to peg.
Good luck.
Done loads of very small ladies watches.  Basically endorse comments above.  Only advice I can give is take great care when handling the balance as the hairsprings are extremely delicate and very easily damaged (a super sensitive hand is required to correct !!).
The spring needs to come off to get sorted out.
Insert a safety razor into the seam between the collet and collet seat, work you way around the staff to open a gap. The sides of the razor are thicker than the blade, drive the side into the gap to widen it more, by then you should be able to get a thin screw driver blade into the gap or just wiggle the razor to remove the hairspring, you should have some sort of area, a tray or something to drop the hairspring on, so you can find it right off, as you would have a macroni hairspring if you swept the floor to find it.?
Next clean the hairspring in lighter fluid, then spread a white sheet of paper on top of a flat surface, drop the coil on it, you can see the coil and circles in contrast with the white, sort the coil, I know easier said than done.
Do I have a good chance in you opinion? I've never done this before so I'm scared to do it, I have a couple of mangled spare hairsprings I think I'm gonna practice on them before I try to fix this one
18 minutes ago, watchweasol said:
Hi Ammar  managed to dig up a little information on the dogma make The following likn will explain a little more   https://chronotimepieces.com/dogma-one-of-the-many-that-didnt-quite-made-it/
Thank you, you always help with links anf files and information I'm gonna call you The Info Guru ?.
Have you worked on a Dogma before this movement looks and feels high quality at least compared to the crappy movements I usually work on.
Hi From the information I have looked at Dogma used quite a few eubauches movements across the range, so from that I gather they are typical swiss movements and probably worth doing if we can identify the maker. The mark an cal would most likley be either under the balance or on the front plate under the dial.
Ofcourse you do, oh, I would unpin the hairspring from the stud while stud is in its holder arm, just get the stud out of your hair.
Sometimes I run a pin through the collet hole and pin the coil onto the paper or cardboard, keeps the coil from moving.
Never met anyone with 100% success record, you might mess this one, so what.
I, also, think you have a good chance.  I have gotten lucky with sorting out springs before.  You just learn not to be rushed; move carefully and calmly; it will take as long as it takes.  Practicing on junked springs is a good idea to get a feel for how it will go.
And like Nucejoe said, you may never reach 100% success, but you may get pretty good.  So it's always worth a try.
    • Following on from my question about identifying screws in the AS2063 movement that basically fell out of the case in bits, I’m pleased to report that I’ve got it all back together, and the movement is running pretty well.    But… There’s something wrong with the keyless works and hand setting. It’s fine in winding and quickset date position - these work - but in hand setting position winding the crown turns the whole gear train.  I don’t really understand how it’s meant to work. It doesn’t have a traditional friction fit cannon pinion.  The second wheel is unusual with a pair of smaller pinions on it, which seem to interact with the barrel and the motion works.    Could this be the problem? I must admit I just cleaned it and popped it in place when reassembling the gear train. I’ve lubricated the pivots but didn’t do anything to the extra bits on the second wheel.    Does this make sense and is anyone able to figure out what I’m doing wrong? Thanks in advance, as always.    ETA - the parts list calls it the Great Wheel, not second wheel.
    • You're thinking metal to jewel in general I guess. Maybe it would be a good idea to peg the pallet staff jewel hole on the main plate after the epilame treatment. I think that could work as it is my impression that the epilame doesn't sit very hard, but I could be wrong about that so feel free to educate me. I didn't remember that 9501 was thixotropic (thanks for the link). That would mean it's even runnier during impact (lower viscosity) so perhaps it's time I get some fresh grease as mine seems a bit too runny. What I have seen is a whitish surface after washing but it goes away if I scrub the surface with a brush in a degreaser (Horosolv). I don't think it embeds itself in the metal but sticks very hard to the metal. I don't worry too much about the cleaning solution. I just want perfectly clean parts and my solution can be replaced for little money (ELMA RED 1:9). Anyway, I quite often need "to strip back and rebuild" and scrubbing parts by hand isn't exactly the most stimulating part of a service. Just got confirmation that Moebius 9501 has a lower viscosity (68 cSt at 20° C) than 9504 (305 cSt at 20°). The viscosity of Molykote DX is 285-315 cSt at -25° to +125° C. I was surprised to see that the viscosity of Moebius 9010 (thin oil!) is higher (150 cSt at 20°) than my 9501 grease!
    • I’ve had a couple movements where it is clear the previous watchmaker was diligent with lubrication but the old epilam had turned to a fine white powder covering the pallet fork and keyless parts, which can’t be good for parts. I’m spare with epi since I don’t know how long it takes to degrade to that state…
    • I have read some suggestions that it can cause wear , particularly on the fork horns of a fully treated pallet fork. I've had half a kilo of steriac acid powder on a shelf for almost a year now, might have a little play today with a heater and a jar.  I think its because it gets into their cleaning solutions Mike. Theirs or anyone else's that services the watch next time, or if they need to strip back and rebuild. Could preclean but thats all time for a pro. I thought the idea was for the epilame to create a barrier, a wall between the lubrication and anything else, so the lube cant spread.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
