Twisted Stem?
tpt
Hello folks,
Starting out on my BHI 'technician grade' distance course here and I've got hold of 2 practice pieces. A quartz Seiko and a mechanical 'Chronostar' which has an automatic movement cal. 2788 which I'm presuming is ETA although I've yet to learn where to look for that gem of information...
Apologies if I get terminology a bit wrong to start with but I have a quick question...
The squared section of the winding stem has a slight twist in it. (counter clockwise. oddly)  would it be manufactured like this? or do I need to look at replacing?
Many Thanks
Tim
Many thanks.
I wish I had a camera that could take a macro pic for you.
Do you have a loupe ? Put it in front of the mobilecamera . Or any other camera that has a small enough lens .
Edited by rogart63
brilliant. here goes...
Edited by tpt
Now that's interesting.
Never having seen one, can someone please tell me why it is designed with a twist ?
Is it for operating a quick set system?
Edited by Geo
That stem is shot .Takes a lot of force to twist like that . Nice picture with the loupe :)
I'm not convinced Rogart, I think it is meant to be like that. The twist is anti-clockwise, you couldn't cause that damage in the watch because the clutch would free wheel.
Odd stem but apparently manufactured that way.  There is a bit on the net about it but finding out why it is made like that is harder to establish.  I did find this patent that seems to give an answer, whether its the right one I can't be sure but it certainly sounds like a good explanation.
US2655784.pdf
Cheers,
Vic
For my first watch uncasing I'm happy to have generated such interest!
While we're on the subject of twisted things... who'd like to tell me if they think this can be saved??
From Junghans cal. J30 BZ aircraft clock.
Mark?
Edited by tpt
If at all possible I wonder about the time and trouble it would take...on the other hand, maybe it can be sourced (the hairspring alone) to be refitted? Let's hear the experts' opinions...
Great find Vic. :)
I'm absolutely sure you have found the right answer. It takes a bit of digesting, it would be a lot easier to see it in the metal.
    • £4.04 originally worked out to $5, or thereabouts accounting for currency fluctuations. Inflation calculator from 2020 (when the thread was started, though not when Andy coined the term) says we're looking at $6 currently. What currency is the 6.99 inflation adjusted figure cited in the poll? $6 may still seem restrictive, but don't forget that's part of the point. It's a challenge. Thrill of the hunt and all. Diamonds in the rough. Also, and my personal angle on the game, a fun and inexpensive way to learn watchmaking skills.
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one  ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • Dear all My first experience servicing a quartz watch after servicing as an hobby my mechanic watches for many years. This is an old Certina that was given to me by a friend, with  a ETA/ESA 9362 movement. Before service I put a new battery and the watch was working. After servicing the movement stopped working. i understand that there might be a lot of reasons for this (including the fact that I used technics and oils from mechanic movements on this one 😞 ), but at this stage I would only need to check if the electronic module is good. Don't have a quartz tester but only a multimeter. You will see on the photos that the battery contact is broken and needs soldering. With the battery in the movement I can confirm that the electronic module had power (1.57v). Question: what basic tests can I do with a multimeter to confirm that the electronic module is good? how to check if the coil is good and if there is pulse in the electronic module? what contacts should I use to test it? (I saw some videos on you tube but was not able to find the specific test procedures for the ETA 9362). Any information to help me check if the reason for the movement to stop is on the electronic or mechanic part of the watch is much appreciated. Many thanks
    • I have bought without seeing inside before and have generally been luck Michael. If its a screwback case i seem to allow some leniency on the removal of it, i dont know why because I've never struggled to remove a back with very basic equipment.   If everything is inside them, then once restored and keeping time the oris could be worth 20 -30 each, I've paid a lot more Oris date pointers in the past.
    • I use a nylon bristle from a brush to run around the coils or a thin piece of copper wire, you need .1 - .15mm.
