It Is Ok Or Not ?
In a very know site of trades, I found for sale a 7750 Valjoux movement. The photos show the movement and this one:
The seller in the description say: The movement is in excellent condition and works perfectly !!!
In my opinion (if I can read correctly the timer graphic), it have some problem at the escapement weel or in the followed weel.
Am I correct or not? Some other opinion?
Well, in my opinion (I can be wrong, that's why my question) the periodically split of both lines show some problem in some tooth of scapment weel or in the followed weel (may be a bent weel). Anyway, if it is OK, why this periodic split? Why not a continuous line?
As I said, I can be wrong, but if I service one movement and it shows that graphic, I will search a little more for what is causing this kind of hiccup.
Ricardo
The timing machine is showing two lines. When the watch is perfectly in beat they overlap and appear to be one line. What you are seeing is slight fluctuations in the beat which is very very minimal and not something to be concerned about.
The problem you're seeing is a problem with digital displays for timing machines. So a confusing description you see one line because it's in beat. The digital numeric display indicates that your watche is running one second fast that means the line is going to have to slope upward by a very tiny amount. So the degree of the angle is so tiny the graphical display can't show it so instead it shows it being absolutely flat then a transition where you see the one in zero pixels weird staircase effect sometimes that it shifts up by one pixel to tell you it's going fast.
This is one of the irritating characteristics of a digital machine versus the paper tape machine is the difference between one and zero always give that weird pattern of some fashion. The solution for a watch like this is to switch to a timing machine that has a resolution of +-99 Versus your current machine which has a resolution of +-999 seconds. Then much more expensive timing machine such as witschi you can change the magnification on the screen and expand the lines but you still stuck with the pixels you'll never get it absolutely perfect linear display unless you have super tiny pixels.
Nice John, and good explanation. I have a B200 and the lines as you said, are continuos. As I don't have (yet) a digital timer, didn't cross my mind that is a problem of resolution of display. As Morten, I try to analyze the graphics. It can show more than we believe.
Thanks for all.
Edited by RicardoG
Could it also be feature of the sampling period set for the timer and the accuracy of a budget timergraph.  Maybe short period is set.  Would setting to longer period give a longer steady line?
Interesting read , I have a cheapo time grapher and have tried to find info on how to interprete the results. Do you have any more info like that morten?
Mark beat me to post it. :)  The rest of the picture I posted you can find here.
http://www.witschi.com/assets/files/sheets/Witschi%20Training%20Course.pdf
Morten
Edited by MortenS
    • I kind of think the same, the surface under the oil is the same as the surface around the oil. Can epilame both repel and attract , that doesn't quite make sense in simple terms, but is it more complicated than that.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
