Bergeon Cannon Pinion Remover
Seth
Good Afternoon,I hope you are all keeping safe and well during this tough time.I wonder if anyone can help me with a small problem I have.I have just purchased a new Bergeon Cannon Pinion Remover and it will not remove any cannon pinion's from wristwatch movements as when the lever is fully depressed the collet will not close enough to grip the pinion it just is too big for watch pinion's.It works on large pocket watch movements but not on wristwatch movements of various sizes as I have tried 5 different movements with all the same results.I enclose photos of the new tool as received from H Walsh I await any replies before I send this back for a full refund. Regards,Seth.
When I bought mine the information on CousinsUK clearly stated: "for small and large watches” and ”adapted to all calibres”. It was not, and Cousins changed the description (added: "Can lift cannon pinions diameter Ø1.00 to Ø1.80mm") and refunded the money. I record a video about it...
Hi to you all,just a quick update on this Bergeon Cannon Pinion Remover 4854, I emailed Bergeon to say how disappointed I was that this item will not remove pinions of 1.0mm and less and Bergeon have said that this 4854 Cannon Pinion Remover is for pocket watches!! They suggest that I use either a Presto type remover or Hand levers (hairspring collet type) and they have even enclosed their part numbers and PDF images of these items!!!! Regards to all and keep safe,Seth.
Good Morning to you all and I hope you are all keeping safe and well.Just a quick update on my Bergeon Cannon Pinion Remover,l decided to keep the tool and investigate if I could alter the collet size somehow.Well after disassembly of the tool and looking at the collet size I found out that with a small alteration of a Dremel collet using my Lorch lathe I think I might be on to a winning situation!! I will keep you posted on this.Regards to all and keep safe,Seth.
Cut a piece of thin aluminm foil, like 1.5mm by 3mm, warp it aroumd a screwdrive about the diameter of canon pinion, role as you would a cigarrete, you are making a tube of aluminum, place the tube on the CANON pinion, you have increased diameter of the canon pinion by the tube's thickness, the tool grabs the bigger diameter.
It works.
Good luck.
  • jdm changed the title to Bergeon Cannon Pinion Remover
    • Just got these good quality diamond files from the bay for Just a fiver, we all love a bargain dont we. Brand names are J.K.Smit  and Triefus, two old diamond tool makers so not cheap crap.
    • Its a touch under ive just remeasured it and added a wrist shot. Unbelievably it was £13  plus 3 postage. You dont find watches that nice for that money every day of the week. Maybe removing the epilame in the oil region improves the purpose of it. We may know very soon as i emailed Episurf 4 hours ago to ask that exact question. 🤞they are happy to provide an answer for us. How do you fancy trying a stearic acid vapour treatment experiment  H .  Shall i have a go this afternoon ? Stearic acid experiment underway,  its started to melt at around  65° C. The idea is to find a large cap jewel to suspend over the vapour release.
    • That's the size of my grandfather's Ernest Borel watch. Definitely not a lady's watch! 👍
    • Thanks H It does have a big crown for the watch , it could be considered a ladies watch these days i guess, it measures 33mm case 36mm with that large crown 18mm lug space. A tad small for a guy of today, but still very wearable. The photo was deceptive so here it is adorning my 7 1/4 " wrist. It need some love to make it run better. The hair coils are touching so running a bit fast at the moment,  not caused by magnetism, and maybe just a clean and a service. The dtal is in fantastic shape.
    • That's one beautiful timepiece! Love the big crown in proportion to the case. Perhaps a ladies' watch, but I don't think so. I have a "modern Ingersoll" watch, but it has nothing to do with the original brand (Miyota 9015 movement). Interesting synonym for synthetic oils! 😆 There is, of course, a limit to how large a volume of oil epilame can bind and hold in place. If the oleophobic effect is too strong then it can become a problem. I'm not sure where I heard or read it, but as I understand it, the active ingredient in a bottle of epilame is extremely small and more than 99% of the contents of the bottle is just a transfer agent. If the active ingredient becomes too concentrated, which it can become over time, or if the product is of poor quality, the oleophobic effect is amplified. This in turn causes the applied oil to look like a gummed-up ball on the surface of the treated part. If that happens, we know that the active ingredient has become too concentrated. What we want is for the oil to bind but not to the point where it is formed into an excessively round ball on the surface. The highlighted text in the patent that you refer to describes well the problem that can arise with too high a concentration of the active ingredient. However, I would be extremely surprised if the entire amount of oil leaves the treated surface as water on wax would. At present, I am convinced that the analogy between wax and water on the one hand and epilame and oil on the other is incorrect. Epilame is described as binding and that is also my absolute experience. Epilame probably has some repelling effect but that is not its main purpose and that is not how epilame is designed and works. The method of abrading the epilame treatment from the section of the pallet stones coming in contact with the escape wheel teeth seems after even more research to be well established, but if it actually works, if so how and why is beyond what I can currently understand. Perhaps it is just to do and trust that it is based on well-established experience. I am, after all, inclined to think so.
