I presume it uses a digital printer somewhere along the lines as there is stair-casing on the curves such as the number “6”. Still looks very good to me.
By the way, “W10” is an Army designation. It would be “6B” or latterly “6BB” to denote flying equipment.
1 hour ago, toptime810 said:
Some things in watch making are to remain secret. I dont work hard to give my ideas away
As you're not sharing your secret would you make a dial and sell it to me?
I've seen some fantastic artwork done on custom motorbikes during my time with clubs. It gives the impression it is airbrushed by an artist when in actual fact it is done by transferring a print image off paper.
You print a mirror image on paper and then apply a transfer gel medium to the metal surface. You then apply the paper to the gelled area ink side down and leave it to dry. The next step is to soak the paper and rub it off with your thumb like removing a sticky label residue from a tincan.
Two issues to deal with as I see it. 1),Could you print a suitable 'skeleton' image (e.g. 'chapter' or 'railtrack' only) and 2), I'm guessing you will end up with a matt finish although maybe gloss lacquer will solve that.
The other thing is, to my knowledge, you cannot recreate a metallic colour with a printer such as silver or gold. Hence you end up with solid colours as per the OP's photos.
7 minutes ago, toptime810 said:
Dials not for sale
That's good that they're not for sale because had you've offered to sell me a dial  I would've reported this discussion to Mark as you would be in violation of the message board rules. There's a section in the rules titled "Advertising, self promotion and posting links."
As someone else pointed out were an open discussion group we share ideas and knowledge. You asked for our help you need our feedback and you don't want to share other than look what I did isn't it nifty. Just my personal view that doesn't seem like you're embracing why this group is in existence.
I'm intrigued, and even though toptime810 is a little cagey about his methods, that wont stop me from speculating.
Ignore the fact that the video in the link below uses a lot of expansive hardware, the basic idea that I would like to explore is the thermal transfer films. Ignore the fact that youtube embedding is currently not working, I'm sure that will be fixed soon.
https://www.youtube.com/watch?v=IMr8uFlsvtU
This is one of a bunch of techniques I would be keen to apply. Thermal transfer films allow the use of titanium whites, metallics and a bunch of other stuff that would be pretty difficult to do any other way. You can also get some small rolls of thermal films from ebay, and application could be with something as simple as a clothes iron or a pouch laminating machine.
Edited by AndyHull
Andy
How much would your idea add to the thickness of the dial, would you still be able to fit the hands ok?
The thickness wont be much I suspect.
The way the films I looked at typically work is by adhering to toner, so you print, or transfer your laser or copier toner design on to the brass or whatever your substrate is, then you put the foil on top of  the metal substrate, pass it through your heat source, and the foil bonds to the toner (which melts and becomes tacky due to the heat, as heat bonded toners are designed to do). This changes your black toner design to gold, white, metallic, holographic, or whatever your film produces.
This means that the layer is likely to be a few hundredths, or even thousandths of a mm or so. The actual thickness will depend on the density of the toner, and the thickness of the bonded layer from the film, but we are talking pretty thin.
Here is an academic paper on toner thickness which gave me the ball park figure for the base toner layer. It talks in terms of μm or micrometers (thousands of a mm or 10^-6 meters if you prefer).
https://www.imaging.org/site/PDFS/Papers/1997/RP-0-68/2318.pdf
Search for information on "laser transfer foils" and "hot stamping foils" if you want to learn more about the idea.
Edited by AndyHull
The hardest part of this 20 step process is drilling the chrono hand holes with precision without out $20,000 equipment. Then comes the lume and casing process. Everything has to be precise or it will not work. I had to make 30 dials just to get two that are perfect enough to work for the case and movement.
You might get some use out of a small cross slide, it would allow precise and repeatable alignment.
Search ebay/ali for something like 32mm Metal Cross Slide Block. Expect to pay around $20 to $30 for something cheap from China, which would probably be good enough.
Couple that with a pre-drilled clear plastic alignment drilling template, and a base plate to hold your blanks precisely and you should be able to get repeatable results.
You might need two for complete x/y control. Mount one on the other, and bolt the lot to your drill stand.
Edited by AndyHull
  • Similar Content
    • Thanks for the information, its a big help. I'll try and pull off the pipe. I think I'll try using the Presto hand remover. Then I guess I'll try to fit the pipe into the hands(?) though maybe I won't have to as I'm putting a new set of hands on the movement.
    • One of the problems with chronograph hands and whoever manufactured the watch would be that often times they are put on with considerable force. The problem with the amount of force they go on with is that often times when removed they disintegrate. So disintegrating hands unfortunately is quite common on a chronograph. With those lucky enough to have an account with were be authorized by whoever made the watch or the service center they would have a complete package of hands. so yes that does look like the brass tube of the hand that disintegrated.
    • The unfortunate problem of the three jar cleaning machine. At least I assume it's a three jar machine. Classically with three jar machine the first is a cleaner and the second to be a rinse of the same type. Cleaning is a interesting process and it's not exactly cleaning and rinsed the entire procedure is cleaning. The cleaner is supposed to have chemicals to put things in the solution and things to make things right and shiny. The rinse continues to put things in solution and reduces the concentration of things in the fluid on the plates. Ideally you should have two rinses not one and alcohol. If you look at the modern cleaning machines you find typically now they will have a minimum of four jars or whatever. Often times the last one will have alcohol because depending upon where you live the rinse itself may not evaporate. So you have a final rinse of alcohol just to rinse off the rinse. Then the only thing I've ever seen on baskets would be this quoted below from something Omega has. But they are assuming that you have genuine Elma baskets and not a machine made in India from unknown materials. Although a lot of people are using the baskets from India I just don't know enough about them. Personally I've see in the baskets for other machines especially the holder which would be as it's implied below nickel plated where the plating wears off and eventually the brass will be etched away from the chemicals in the cleaning product. One thing I didn't see you mention was how long in the each of the baths? Usually for the cleaning products that make things bright and shiny. Time-limited approximately 4 minutes works really well. The rinses of less of concern it depends upon how much the cleaning fluid is dissolved in it though. You can download the specifications the cleaning products I like they have recommended times the final alcohol rinse is supposed to be relatively short as any time we mention alcohol and watches people get excited over dissolving the shellac. But typically with isopropyl alcohol it takes a little while longer and I've even used alcohol which I know dissolves shellac but I was just using it to rinse off the rinse so it was never a problem.
    • I think i am done. I was working withe two pieces, one was 316 SS and the other 304 SS. The starting material for 304 was thinner, so I opted for finishing it. Since I only have images of one of these watches, I cannot know the exact dimensions. The owner is not critical...just wants a working solution. I think this is it. It was quite the challenge to turn the inside  locking rim. An inside angle cut. Had to be damn close in order to have a snap fit. Frankly I think I just got lucky. Sometimes lucky is better than smart! The inside edge that interfaces with the crystal is an interference fit. This was on purpose in case my locking-edge cut was overshot...then the bezel and crystal would work together to stay put. Tens of hours working on this, and I learned a lot!
    • I'm using: 2.5L Elma WF Pro – New Formula for the main cleaning 2.5L Elma Suprol Pro – New Formula for the first rinse Isopropanol Alcohol IPA 99.99% for the final rinse So far, all fresh fluids. I was also under the impression they shouldn’t cause rust, so I’m wondering if maybe the damage was already there and is just progressing now. Because my baskets came with the machine when I bought it pre-owned, I’m not sure if they’re original Elma or not. That’s exactly why I’m hesitant to buy a new set—I don’t want to end up with lower quality clones again if that’s what these are.
