Harley Ronda 726 parts pdf.
Len33
Not long ago, somebody on here kindly provided me with a complete parts list pdf for the Harley Ronda 726 chronograph.
I thought I had got it safely saved but, like a click spring, it has vanished into thin air!
Any chance of another pdf, please?
Hi  Joe  Under the heading resources there could be put a heading to enable us to either drio in the link,  or the PDF's as we pick them up,  Maybe one for the future. I have a fair collection on my machines and would willingly put them up.  Google drive  I belive is a source on the net.
Hi Weasol, I remember my words in my first PM to you;
" What is easy for you,  might seem impossible to someone else"
Ease of access and simplicity to understand are keys to education for all.
Perhaps you find some way, a lesson and simple instructions, flow chart ....on how to access the files, is a key, however, the universality of the key may start with the title flashing off-on before the seeker eyes.
One might have the potential to become a master horologist but not understand a word of computer stuff.
Best wishes Joe
1 hour ago, Watchtime said:
@Nucejoe @watchweasol Good point, maybe we can ask Mark what we can do, some kind of library
It has been discussed before and the idea is not walking, for one side it requires maintenance work, for the other usually this type of documents can be found with a simple Internet search.
Quote
In case there is a possibility to share  here on WRT, I am happy to upload my collection of a few hundred service sheets....
Nothing prevents you from attaching them to a new topic with as many postings are needed. Then you can ask moderators to pin or star the topic.
Edited by jdm
    • I've also heard it called the "top side" and the dial side the "bottom side", which should make any non-repairer very confused. There are many examples and sometimes it comes down to personal preference. Personally, I like to say "dial train" whereas most other people would use the term "motion works".
    • Is magnetism such a major problem that we (as home hobbyists) need to spend $$$ on a fancy demagnetiser? I use one of the cheap blue Chinese demagnetisers (£10 from ebay). It works, and has never failed to demagnetise a movement, or my screwdrivers. Magnetometer - who needs one?  Take a very small screw. If it sticks to the clean part, it is magnetised 🤣
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
    • I come across to replace the crystal of a 7734 chronograph.  What make it special there a printed chapter ring  which fits inside the recess of crystal before inserting into the case. I am thinking of a high dome crystal such as Sternkreuz ATCH, fitting diameter OD332/ID320.  For this purpose, tension ring will be removed and fit in the chapter ring.  I understand the crystal size may not perfectly fit these two dimension.  Should aim to find the right ID, then OD can be grinded to reduce without much difficulty.  To find the right crystal, the easiest way is to get know of the OD/ID relationship of Sternkreuz ATCH/ATCG (otherwise the OD of the crystal and tension ring).  I hope you are able to help to minimize the trial and errors.
