Hello,
Another first for me. I'm attempting to repair a friend's antique watch, and not until after cleaning did I notice a bent tooth on the barrel. The original mainspring had snapped and I wondered if any damage had occurred when this happened, but on inspection, the jewel holes all look fine, it's just this tooth shown in the photos that concerns me now.
So my question/dilemma is, do I attempt to straighten it, and if so, what would be the best technique to do this without causing further damage or snapping the tooth off? I'm very much doubting that leaving it alone will be an option as I'm sure that the watch will stop when the centre wheel pinion meshes with it, though I've not actually reassembled the train yet.
I guess my biggest hope would be to get a replacement barrel. I'm pretty sure the movement is from c.1928 as it has a gold hallmarked case to date it. And although I also know it's an early ETA movement, I am unable to identify the calibre (see photo). Again, if anybody recognises it, that would be fantastic.
Many thanks,
Adam
Edited by AdamC
Photos edit
That group of teeth all look in bad shape. I had a few old screwdrivers that I blunted the blades right down and would use whatever one would fit the best and use it as a lever to bend it back. You could try ebay for a donor movement. You never know one or more of our kind members might have a movement with the part and they might be able to help you.
Just be very careful. I ruined a rare Rolex barrel trying to do the same.
I had to fork out $400 to replace it. It doesn't have to be perfectly straight, just slightly more inline. Every bend will stress the metal and could crack it.
I cut a piece of fine sandpaper 1×4 cm to use as a file.
Bend back in little and file some, just enough to get it do its job.
Looking on the Ranfft website, it looks like the movement might be an ETA 128. The top plate looks identical though the bridges differ on the bottom plate and mine doesn’t have a sub second hand. There’s one of these on ebay so may take a chance for a barrel donor if the straightening goes horribly wrong.
Well I think I've successfully done it. Thanks for all your words of advice. My method was to first assemble the train wheels and bridge and check they were freely spinning - all good. Then I tried the barrel held by its bridge without adjusting the tooth and as expected, the spin came to a hard stop and lightly bounced back. The gap of the good teeth is around 0.4. My 0.5 screwdriver blade got over half way between the gap of the bad tooth so using this I did a straight firm push (no back and forth levering as I hoped the wedge of the blade would push apart). On pushing the 0.5 home, I moved onto the 0.6 and repeated. Then onto the 0.8 (sweating by now as it seemed to take more pressure to drive home). At this point, I tried it against the train, and again, the same happened with the bounce back. Feeling my luck was going to run out soon, I applied a tiny drop of HP 1300 oil on both sides of the 1.00 screwdriver blade in the vain hope it may ease the blade in, and it did seem to ease the push home. On examining, I recalled @AlexeiJ1's advice that it doesn't have to be perfectly straight, just more inline, and it did appear improved so trying with the train again, it spun freely with no resistance past the imperfect teeth. Of course I won't know if the performance will be affected until she's up and running but for now, I'm pleased with the result. I've attached a photo of the straightened tooth.
  • Similar Content
    • You're asking a pretty broad question and you didn't specify the machine but yes it's simple especially if you have the right machine. The question has problems but I'll take it as it is. Is it really that simple yes especially if you have the right machine. So in the video below he's making a screw and yes it really is that simple but pay attention to the machine it is not simple at all probably wasn't cheap but it is small it will probably fit in your garage. Unfortunately wouldn't fit in my garage as it's far too cluttered up with things. In the video he talks about making a screw and pay attention to the machine. The machine has lots and lots and lots of cutters and lots of things to do lots of machining all-in-one machine conceivably one step after another all programmable. If you look at his channel lots of CNC's stuff and there are several other videos related to this machine. He goes to the factory where they talk about it and show all the other machines they make in Switzerland.  I did look up the specifications the machine I don't recall the price it's not going to cut wheels I think it has a maximum diameter around 11 mm basically it's really good for making small diameter watch parts. Then in one of the other videos he goes to a factory that used to make parts with waterpowered machinery been in business for 100 years and everything they now make is made with CNC machines including this one. What was interesting with the factory photo was that when they make some parts they can put them on a optical comparator comparator compares with whatever the reference is and the machine can be programmed to adjust its cutting to make sure everything is actually being made to specifications. Oh and then somewhere in all of this there was at least one picture of a balance staff can't have a CNC Swiss machine without making balance staffs.   It would be really nice if we had pictures of the machine. Then yes if you look at the page for wheel cutting you can enter parameters and it will generate a G code but he left out things? Notice he has a picture of a complete wheel but the G code isn't making a complete wheel it's only cutting the gear teeth I don't see whereas the program for crossing out the spokes? Typically when you see people cutting gears once the teeth are cut most the time the spokes are cut by hand. Occasionally someone will mill them out but typically not with the program which seems strange if you have CNC capability for instance one of my friends fill it used to design assembly line equipment or things to make things. So his hobby was to continue to make tools to make things like clocks. Very interesting and clever clocks but his true fund was making the machines to make the clocks. Then machine is not controlled by G code like we would typically find today as the stepping motor controller he has was made a long time ago and the individual controllers used a textbased program. So the company had a editor you could write a program to cause each the stepping motors to do something. So basically once you figure out how to cut a gear he would just change the parameters for different size gears so here's an example of a gear as you can see we have the teeth and the spokes. Then we have a picture the machine which sucks because it would've been so much nicer if I could've taken a picture when it was cutting a gears so we can see things better. Then yes there is a worm gear stepping motor indexing this is a mini lathe and the indexing is at the end of the lathe head hiding. The basic operation of this machine would be brass sheet not cut to a specific diameter size not even round mounted on the machine. Then it turns and a milling cutter will cut the diameter. Then the gear would be cut with a gear cutter. The same mill cutter for the diameter although conceivably change the size I don't know but basically the same milling for cutting the outer diameter would be used to cut the spokes. I really can't remember how he did the center hole but whatever it was was very precise.
