Had a practiserun with the movment again.
Was very relaxing to sit down and work on ot again.
Had it apart and reasembled again. Less pings! Overall, i noticed big improvment in handeling screwdrivers and tweezers. Its not like the old days. But getting there. Not finding a comfortable sitting position yet. Think I’m going to build som type of raised top. Until I get a more dedicated watch bench.
Bit off topic. But thinking of order a proper benchmat, among other small things. I see there is several types. So if you have any recommendations, I’d appreciate that a lot! ?
Hi  Both bench mats and desk top benches come in all types see below.  The options bench mat  Bergeon   around the £20 mark but a lot of people use craft mats (cutting mats) like from Hobby Craft.
The desk top options are as below  The DIY option at low cost but very practical solution to restricted space and the ready made one from H.S.Walsh. Even the ready made one can be a DIY project.  On both counts the options are numerous its just a question of cost against time for DIY.
I like the upper one a lot! I’m planning to find a convert a electrical hightadjustable office desk. When I find a used one in the area. Replace the top with a wood type kitchen top. Cut down to a managble size. A small and removable top like in the first image. Would be great!
I have been using a large gaming mousepad. Its nice in regards that screws etc dose t bounse much. But I think a better mat is a needed. Rubber bechmatas seems to be much more pricy, compared to “plastic” But is there a real practical difference?
Hi Depends on the composition of the rubber some are softer and absorb shock and the hard ones stuff bounces on,  The cutting mats are really quite good and relatively cheap, If the grid markings are a pest they can be rubbed off using Isopropyl alchohol, I did that with mine and now have a plain green mat.
The green mats are drafting table top. An art supply store should have them. And they’re green.
I have an IKEA desk top, lifted on blocks, which sits on an old kitchen table in the basement. Overhead I have an LED shop light from Home Depot. I bought two, thinking I’d need more light but one is quite bright.
Im 6’2” tall so hunch over to work but it’s not uncomfortable. The top work surface is huge (I have a tuner and cassette deck piled up on top along with all my tools and parts). I could make it another 2-4” higher but it’s working and cost was very low.
Yesturday afternoon. I started to work on the donor st96 movment.
It is in much, much better condition, than the one I started with. Nice experience! It feels that the skills are imroving. But springs and clickworks are still my nemisis! ?(but starting to get a hang of it) A few pings. But only a clickwork yokelevel/cam lost. Also have to say, it seem to be a bit better production quality.
I always seems to forget to fit the yoke, the one that is connected to the stemscrew..Ofcoarse when the barrelbrige is all set and done. Including the clickspring! ?
During the night. I discovered that the tweezers needed better dressing. Made a noticble improvment. Eventhough I was getting tired. Bit had so fun, I couldnt stop working.
Finding ”pings” in a better way. I took some extruded pvc board (commonly named Forex) that is used for advertising/signs ect. Fitted a few feet of selfadhisive magenticstrips. To sweep the floor and desk with. Had a few lucks with that. Things seems to ”ping” to other places, directions. Than you actually think they do. ??
The movment was quite clean. But did try a regime of letting it soak in 3M industrial cleaner. Then rapidly flushed with hot water. Then final rinse in IPA. (Not the beer, though it’s nice) Pallet fork and balance did have a bath in lighter fluid.
Did take my time oiling. Including first proper removal and cleaning of the cap jewels. This morning it was up and running! ?????
What a joy! ?
Sitting there watching the movment ticking away friskly! Albeit tired and with sore eyes and neck. It feels really nice!
Realized a few things. I need a stem and crown! Also a few screwdrivers needs dressing. So I went to order a stem, crown and the classic dressing tool. While browsing cousins. I realized, it would be nice to see how well the thing ticking on the desk. Actually runs.. So clicked and added a timegrapher to the basket. Expensive morning. Cant wait for the stem though! ?
Wish you all out there, a nice sunday!
Dont forget to fika! (Google Swedish fika)
Edited by Rocket
Small uppdate.
The movment has now been ticking away with good spirit for about 46 houers. Checking it now and then. Have to say it feels very, very nice. Watching the balance, fork nd timing wheel ticking on beautifully. Is a nice feeling!
Cant wait until the timegrapher arrives. Start learning adjusting ect!
And oh.. A landeron 48 movement arrives any day. Longterm project. Bit can’t wait to check how the cronograph works, works.. ?
But first, lets finish this watch!
Looking good rocket man a couple of more rounds and you are ready for the next level! .. After that the Landeron 48 ?
Leveling up, like in gaming! ?
I have to say, this is a nice movment!
Today was another good day!
The timegrapher arrived. So went to work, checking the pocket watch. Then the newly server 96 movment.
Was Intresting. Probably doing something wrong regulating. Gave it a full wind and starting the timegrapher.
It was going Rocket fast! ???
Never got it slower than just under 500sec a day. Got beat error down to 1.5 ms. Liftangle is set to 52. Autodetecr beatrate is 18000.
Not sure about Whats wrong. Spring looks fairly ok to me. Not perfect.
Was thinking, canonpinjon not fitted. Not likely. But is it needed to crate friction to slow down the movment? Sounds unlikley to me. Think I have to ask, Atleast.
It did slightly slow that Waltham pocket watch I was working on.
But it’s not going to add 500 seconds.
Has it run in overnight at least?
I did check it early this morning again. And now after about 28 hrs.
Been very buisy day working. But thank god, one have watches to think about too!  ?
But its a intresting problem. It shouldn't be overpowered by the mainspring. As it easily stops. It now runs at about +570 sec away. As slow as I can get it. Dial down.  Now, if I move it to another position. it tends to stop completely.
Maby my timegrapher setting are messed up? Liftangle is set to 52. 18000beatrate.
As Tg is brand new, and me too.. I had to make a check with the pocket watch. Regulated it a bit. Worked as a charm. It needs a service. But keeps close to - 10 sec a day. Dial up. +25 in crown up position. should be fairly ok, for a pocket watch. 1930´s era?
So when trying to regulate the ST96 it only responces with a zero to +570 spann, since everything else looks good there probably is a hickup on the hairspring a small nick, dirt, oil or magnetism. You should be able to see if it compresses to much so the hairspring sticks or are stuck all the time. This phenomena makes the spring act shorter and the rate shoots away into the sky.
Ty HSL. Sounds logical!
Did just take a few pictures from right above. Including a slowmo. clip. Intresting!  (could not up load the clip)
I think the hairspring, Neds adjusting the "bend" that goes up to the regulator clip/pivot. (not sure about the correct term)
The spring is overall, poking towards the mainspring barrel. E.g. Its not circular even. ?
Just a thought.
I feel spoiled, being able to learn all this, via such forums like this.
Getting this knowledge before the inter webs era. Was only true a real watchmakers school. Or very, very frustrating hard and dedicated work.
With that. We can stand assured, watchmaking is not going to die. Probably on the contrary. More and more ppl will appreciate skilled work, and things as mechanical watches.
Looks the hairspring is slightly out of order. If you peek at the area where the arrow is you see it might be a bit of contact.
On 7/31/2020 at 12:34 AM, Rocket said:
A microscope is now on the wishlist
Hej och välkommen Johan! Kul med ytterligare en landsman!
During my first service attempt some years ago I decided to invest in an inexpensive Chinese stereo microscope from eBay (you can read about it here) and I still consider it my most important tool alongside my tweezers, screwdrivers, and oilers. Using the scope I can see exactly what's going on, what I'm doing and the result of it and it's just invaluable. I just couldn't do without it.
Well done!  I got more than one Oris from eBay from India for a song.  The dial was repainted, and that was the strongpoint.  It, too was glued to the main plate.
Yes, the parts are small, aren't they?  ?  It gets better when you disassemble, oil and try to put back together an incabloc assembly; the one held in place with the rotating spring.  Once the spring is off, you develop an appreciation for how small things are.  Once the cap jewel is removed from the ass'y, it has to be in the top 10 for smallest manual-wind movement part.  If you're familiar with the game tiddly winks, that's what picking up that jewel is like.  It's small to the point where one could place it in a zero from the date on an American dime, and if viewed from the side, it wouldn't protrude.  I exaggerate, but that's small!
You really did go big with the screwdrivers.  Good luck getting that watch tip top.
Little bits of Rodico are great for handling the really small parts.
Either by itself, or stuck on the end of a toothpick or other small stick of some sort.
Cousins also sells very small silicone-tipped devices that I now use to lift incablock circular springs (can't remember the name of them right now), and remove/replace the cap jewel from the chaton.  They work very well, and are fairly inexpensive.
Came home from work, later than planned. So, I’m a sofa and keyboard horologist, this evening! ?
Sharpeyed to spot that! Have to look in to that tomorrow!
Hej, och tack!
Känner mig mer än välkommen! ?
I have plans for a microscope. Infact, I miss one already! But on the way collecting tools and equipment. I had high hopes for this one. https://www.cousinsuk.com/product/multi-lens-with-led-light-tec
Hope it would reduce eystrain and working positions. But, this one was a miss. Only tried it for a couple of minutes. Got dizzy from the absolute lack of flatfield view. It works ok in the lowest magnification. But then I can do without.
One problem with sore eyes ect. It that one maby shouldnt do 8-12 watchmaking. As a beginner anyway. Bit its so fun, and the time flies away! ?
Ty! ??
it is really fun! But,  it would not be possible without the welcoming knowledge of all the people. I think ”hairspring”, is called that. Just because it gives people grey hair! ?
I have had the incablock apart, cleand and oiled. Well, a reasonable try anyway. It was not easy. Not at all.. The bottom one, pinged away. Almost got brown pants. Because I didnt have any replacement. Was 2am. And I was close to get it ticking. Thankfully, it didnt go far, and I found it emidietly. Used rodico to hold it in place. Well, almost lost it in the rodico while trying to clean it. ? After som quite nervous and shaky time. I got it popped in place. Fitted the balance, winded the barrel, and ot ticked away nicly.
Was tired, but sheerfully happy!
I do notice, that practice makes perfect. Well, in my case. Better anyway! ??
On the screwdrivers. Im very happy with them. Feels solid and ackurate when working with them. They are also pretty!
As most, I do regret not getting better tweezers. But I knew I had one better somwhere. Was looking through my old finemechanik tools stasch. Bit could not for my life find it. The other day, I suddenly found it in my wifes hands!
She had my boley Leinen tweezer, picking ticks from the family dog! ???
Well, she now got a ”better” one. As she needs propper tools for picking ticks from the family dog! ?
    • Thanks for the information, its a big help. I'll try and pull off the pipe. I think I'll try using the Presto hand remover. Then I guess I'll try to fit the pipe into the hands(?) though maybe I won't have to as I'm putting a new set of hands on the movement.
    • One of the problems with chronograph hands and whoever manufactured the watch would be that often times they are put on with considerable force. The problem with the amount of force they go on with is that often times when removed they disintegrate. So disintegrating hands unfortunately is quite common on a chronograph. With those lucky enough to have an account with were be authorized by whoever made the watch or the service center they would have a complete package of hands. so yes that does look like the brass tube of the hand that disintegrated.
    • The unfortunate problem of the three jar cleaning machine. At least I assume it's a three jar machine. Classically with three jar machine the first is a cleaner and the second to be a rinse of the same type. Cleaning is a interesting process and it's not exactly cleaning and rinsed the entire procedure is cleaning. The cleaner is supposed to have chemicals to put things in the solution and things to make things right and shiny. The rinse continues to put things in solution and reduces the concentration of things in the fluid on the plates. Ideally you should have two rinses not one and alcohol. If you look at the modern cleaning machines you find typically now they will have a minimum of four jars or whatever. Often times the last one will have alcohol because depending upon where you live the rinse itself may not evaporate. So you have a final rinse of alcohol just to rinse off the rinse. Then the only thing I've ever seen on baskets would be this quoted below from something Omega has. But they are assuming that you have genuine Elma baskets and not a machine made in India from unknown materials. Although a lot of people are using the baskets from India I just don't know enough about them. Personally I've see in the baskets for other machines especially the holder which would be as it's implied below nickel plated where the plating wears off and eventually the brass will be etched away from the chemicals in the cleaning product. One thing I didn't see you mention was how long in the each of the baths? Usually for the cleaning products that make things bright and shiny. Time-limited approximately 4 minutes works really well. The rinses of less of concern it depends upon how much the cleaning fluid is dissolved in it though. You can download the specifications the cleaning products I like they have recommended times the final alcohol rinse is supposed to be relatively short as any time we mention alcohol and watches people get excited over dissolving the shellac. But typically with isopropyl alcohol it takes a little while longer and I've even used alcohol which I know dissolves shellac but I was just using it to rinse off the rinse so it was never a problem.
    • I think i am done. I was working withe two pieces, one was 316 SS and the other 304 SS. The starting material for 304 was thinner, so I opted for finishing it. Since I only have images of one of these watches, I cannot know the exact dimensions. The owner is not critical...just wants a working solution. I think this is it. It was quite the challenge to turn the inside  locking rim. An inside angle cut. Had to be damn close in order to have a snap fit. Frankly I think I just got lucky. Sometimes lucky is better than smart! The inside edge that interfaces with the crystal is an interference fit. This was on purpose in case my locking-edge cut was overshot...then the bezel and crystal would work together to stay put. Tens of hours working on this, and I learned a lot!
    • I'm using: 2.5L Elma WF Pro – New Formula for the main cleaning 2.5L Elma Suprol Pro – New Formula for the first rinse Isopropanol Alcohol IPA 99.99% for the final rinse So far, all fresh fluids. I was also under the impression they shouldn’t cause rust, so I’m wondering if maybe the damage was already there and is just progressing now. Because my baskets came with the machine when I bought it pre-owned, I’m not sure if they’re original Elma or not. That’s exactly why I’m hesitant to buy a new set—I don’t want to end up with lower quality clones again if that’s what these are.
