Searching for a Seiko Crystal
As often asked and answered. There is no secret place for parts. The searches you can do are the same that all others here do - Internet, Ebay, well-know online material houses.
18 hours ago, Dave84 said:
I ended up finding one on ebay for £38 including postage
Congrats! Objectively it's still a lot of money for a crystal (you can get a great mechanical Russian watch for that money), but for a watch that means a lot to you, £38 can still feel like a bargain.
Edited by VWatchie
you dont always need an original,  measure the old one, I can see from the part number its 30mm and probably is a tension ring too so you can get a generic one for less than £10.00 that will do the same job.
I have done this one many plain Seiko crystals even glass ones.
Are you sure? Picture from the Ebay listing of someone asking $78 (!!) for it.
With it's large bezel and domed shape is not a good candidate for generic replacement. And it happens, beginners and amateurs aren't able to swap a bezel or tension ring from a crystal to another.
And here's how anyone can decode (up to an extent) Seiko crystal codes Crystal Codes.pdf
Edited by jdm
Hi Guys, just a quick update, again thanks for the responses.
Just wanted to add a quick pic of the new crystal which came fixed within a retaining ring which sat beneath the bezel ring.
Cheers
Dave
    • You could also use a very fine artist's brush to brush between the coils.  If you get a size 00 or even 000 that should be small enough for convenience, and with bristles so fine that they are incapable of damaging the hairspring.  Get a good one though, like Windsor-Newton or similar.  I have never had a Windsor-Newton brush shed on my art or other work.  You want a soft brush that will not shed.
    • Sounds interesting but how do you push the button if you’re holding both ends? the large current draw overheats after 3-5 seconds and the thermister triggers. A great tool for magnetizing things but I’ve not be able to ever demag anything with it because the emf is so strong it pulls the item off center (down or up).   I paid $89 bucks for it from  CAS-KER, if someone on the board wants it I’d gladly sell it for $25 plus shipping (probably US only otherwise postal costs are prohibitive). Just sent me a note offline.
    • Hi. First thing to do is measure your oil movement as the vx32E and the 43 look very similar but one is a couple of mill smaller the vx32E.  Also the canon pinion heights differ attached tech sheets for 7N22. And  VX43, check details on the sheets. 7N22A_29A_33A_42A_43A.pdf VX43.pdf Hattori VX32E - Specification.pdf Hattori VX32E - Disassemble.pdf
    • I was spitting out flowers and leaves for 10 minutes,  fortunately 3  people saw it and promptly whipped out their phones to film the quick " nothing to see here " recovery  🤣🤣
