Miyota 8215 - Seconds hand installation
Hi guys,
I am new to watchmaking and I am trying to build a custom watch with Miyota 8215.
Unfortunately I am very impatient when it comes to new things and I started working on the project before having all the tools (lupes and hand press).
Anyway I bended the seconds hand and then I tried to fixed it. I waited to try again until I have the hand press.
Hours and minutes hands are installed correctly but no matter what how I press the seconds hand it doesn't click and it's very loose.
Any ideas? Did I break the movement?
Video attached
:startle:
Doesn't look like a hand press would have made a diference. If the seconds hand isn't intact, I start looking for the broken piece.
Edited by Nucejoe
seconds arbour helps
Hi   Having watched the video  like Rodabod you are using way too much pressure, just a gentle press is enough. Whats probably wrong id the second hand pipe is oversize and no amount of pressing will make it stick. I suggest you measure the shaft where the hand fits (with Vernier or Micrometer) and source a new hand.  using excess pressure may have damaged the centerwheel bottom jewel so better check that out.
This is the url for the hands:
https://www.ebay.co.uk/itm/Watch-Hands-Silver-For-3-Hands-Pilots-Watch-Fit-DG2813-Miyota8215-Movement-Lume/372861617253?ssPageName=STRK%3AMEBIDX%3AIT&var=641672576476&_trksid=p2057872.m2749.l2649
Seconds hand is 11mm and it's compatible with Miyota 8215.
So the issue is that I am pressing too hard?
I will try to straighten hands and install them again.
Any other suggestion are welcome! I am new to this and every bit of help is appreciated!
If the seconds arbour still intact, use a nail clipper to tighten the mid-section of the tube of seconds hand, you should make sure the tube is mounted on the arbour then press it home. Tube will not find the arbour itself.
If you think the tube size is right but got problem getting the minute arbour inside the tube, you can widen up the entery section to the tube, use a sewing needle the tip of which enters the tube.
And it's official! I broke the seconds cannon pinion. I will proceed without the seconds hand for the moment.
Lesson learned!
I am also having another problem with the case. I am following a tutorial on how to secure the case with casing clamps. The tutorial says that the clamp's bend should be facing upwards and secured under the rim  of the case. But I can't get it there. Maybe the dial and the movement are higher than they are supposed to be? Any ideas?
I think you've broken the arbor of of the seconds wheel. Cannon pinion is relative to minutes only.
Quote
Do not count on assorted parts for a Chinese watch to fit togheter right away. Adapting is always required.
Edited by jdm
Lesson learned!
I am having the EXACT same issues as you.  I have a Miyota 8215 with a set of hands where the second hand will not seat and the case clasps also not seat due to thickness of the movement... Let me know if you figure anything out!!! So frustrated
I suppose you got all that from China? Tipically these sellers don't care about what they send as long the order is formally fullfilled. Just claim with the card issuer and get a refund.
BTW, we have a section here wheee is considered polite to introduce oneself even before asking questions.
    • I would cut my losses, keep it for parts. Buying a balance complete would be a Sunk cost fallacy.
    • I recall a video on YT from Steffen Pahlow where he talks about getting himself a Chronometre (for which he paid more than he would have liked), but in his words "I had to. It is a Chronometre." I am wondering if you have more watch there than what you are aware of? Especially with what @Neverenoughwatches mentioned about two springs.
    • If you are having counter tops ( i think thats the amercan term ) and some cupboards underneath where you dont require working legroom then that corner doesn't have to be a difficult access void. Lazy susans , we ( kitchen fitters ) call them cabinet carousels or you could just have two adjacent doors with a corner post fixed to one of them, though it does make for a long reach to get to the very corner. But a carousel is a good access solution, also there are sliding steel baskets available but these are bloody expensive and typically problematic, i really think they are a crap idea. What i like about fully fitted worktops, very tidy looking, no loss of space, and sidewards pinged parts are hopefully going to stay worktop side and not end up crunched on the floor.
    • Aren't corners of rooms a bugger though as it is really difficult to use the space underneath the intersection of the two benchtops. Lazy Susans are an idea I suppose. Somewhere to be able to put tools/soldering iron/testing machines that aren't needed on the bench top all the time. It is a bit tight in there, but at least I won't have to move great distances to get to another area. I need to get hold of another chair to have at the cleaning bench. I'll stand all the time at the lathe and I already have the stool for the workbench. Need to get the power sorted now and move the LED lights for over the workbench. There are four downlight in the ceiling that are currently halogen bulbs. Really quite bright so that's good. Ceiling fan as well. What else could one hope for?
    • So all that glitters is not gold when it comes to buying from ebay ( in fact very very rarely) i bought this as554 a few months ago. It was it's dial that attracted me to the joblot, which turned out to be printed on a postcard, that was the first red flag. During disassembly many faults were discovered as listed above,  but i was prepared to soldier on and see what i could achieve. I managed to make a setting lever for it which was a great learning experience and also correctly shape and de rust the hairspring.  Turning my attention to the balance assembly i have hit a road block. The staff broke when removing the roller but that wasn't so much of an issue as it was quite deformed anyway.  I also had several AS554 staffs that I could replace it with, problem is they dont measure up the same. I thought i had identified the movement correctly but what i think has happened is some heavy modification has taken place to make an incorrect staff fit. A nos staff is a slack fit on the balance wheel, the roller and the collet. The balance wheel has also been filed to within an inch of its life. I'm starting to doubt my identification of the movement either that or someone has converted the movement into a pure nugget of trash. Bit disappointed as i managed to get the train to spin lovely and put a good few hours into the setting lever. A balance complete might be the only option if one is available but you know when you are just wasting money. My thoughts are to make and modify something else to fit and work if that is possible, any ideas anyone ?
