Seiko watch case bezel
Hey
This watch case is numbered 7009-8140 I am trying to fit a replacement glass to it and it wont fit.
Looked around online and cannot find anything about fitting glass to this case. Can any one tell me, can the bezel be removed. If it can i can get it to fit . Don,t want to force it and break it if the bezel can be removed.
Or if any one knows were there is info on fitting this glass to this case.
And it is the right glass for the case XMF320-855  sternkreuz.
Sorry pics are not better.
cheers
gary
Hi Gary. I think the crystal can be pressed out from the back. But if you want to remove the bezel, remove the bracelet first. The bevel of the bezel is hidden there between the lugs. But you will need a bezel removal tool. There is no space to insert a knife there.
Goodluck.
Hi
Well my bezel wont come off. unless i take a hacksaw to it.
thanks any way
cheers
gary
Question, IMHO, is "is the bezel removable or not" ... to answer that a good (no blurry) close up pic showing the side of you case could help a lot ...
If your bezel IS removable you could use a single edge blade (one-side is protected so that you can kill your finger) like that one
https://images.app.goo.gl/BTNaBfoa9eCDW8DbA
- remove the bracelet and put you watch case on a flat surface ... upside up
- hold your single edge blade horizontally and put the sharp side on the "groove" between bezel and case
- gently hit the protected size of the blade, repeatedly until the blade goes between case and bezel
- remove the blade and proceed the same all around the bezel so that it moves up about 1/4 mm
- proceed again all around the bezel until you can insert a thicker blade (pocket blade for instance) between case and bezel
- gently use the pocket blade as a lever, proceeding all around the case, to slowly move the bezel up and up until it comes off
Envoyé de mon moto g(7) power en utilisant Tapatalk
Hi Gary   had a look as promised, they look removable but as far as I can see on mine there is no slot or cut out on either of the watches what will be needed is a bezel removal too as per the picture. It places equal force in four places lifting the bezel, this tool will double up as a case back removal tool.  hope this is informative.
If I may ... I wouldn't use such a tool for a steel bezel without retaining ring ...
Would you kindly post a side pic of one of your watches to check if a single edge razor blade could be used ?
5 hours ago, VWatchie said:
Could you make any recommendations on what bezel removal tool to get? Thanks!
I got a China made copy of the Horotec. Works on bezels and casebacks. Cousins has it in their bezel removal tools section.
Hi
This is the best i can do with phone camera.
Hope this is what you wanted to see.
I have seen on youtube they just push there,s on.
I cannot see a groove to enter a razor blade.
I just seem to get watches that are weird or strange.
Thanks for looking and helping.
cheers
gary
Hi Gary  I had another look at mine and tried to remove the bezel with the clamp and it refused to move didnt press too hard not wanting to break the watch case or bezel.  I have attached some pics of the rim and a couple from the scope Manodeoro asked for . If you get it off getting it back will be a fun time.        Cheers
While I don't have the same model, on both my 6619-8190 and 6719-7050 I removed the crystal with a crystal press and after I threw the case into the ultrasonic to clean it, the bezels came off with me using a razor to start it an then my case knife to get it all the way off.
    • This makes much more sense now, the oil is withdrawing itself to make as little contact with the epilame as possible. Same principle as wax on a car creates a hyrophobic surface that makes the cohesive properties of water molecules pull together.  The water beads run off only when under the influence of gravity but still remain cohesively beaded up. And as mentioned earlier a pivot would keep the oil in place on a cap jewel.  Epilame on an escapement would be a different scenario, there is nothing to hold the oil in position if gravity tugs at the bead to move, plus the escape teeth pull the oil about Maybe this is why its suggested to run the watch for a short while to remove the epilame to make two oleophobic surfaces either side of the oil, creating a ring of fire 🔥 around it 😅
    • As with every skill it watchmaking, it takes practice. Notice at the top of the document it says, "Practical work - 40 hours".  I can get the balance wheels 'close enough' to flat, but never seem to get them perfect. Same with gear wheels. Guess I need more practice.
    • Has it got a beat adjustment on the platform or is it a fixed hairspring? in short what you are looking at to get it just about in beat is to get the roller jewel sitting dead centre between the banking pins. So remove the platform and take of the pallet fork and escape wheel to give you clear line of site, sit the platform with the balance in place and with it level look between the banking pins and see if the roller jewel is sitting between them, if it is nice and central its there or there abouts in beat, if its not the the position of the pinned end of the hairspring needs to be adjusted to move the roller jewel into the correct position, thats why I asked if it has an adjustment on the platform or not, if it has its an easier job.
    • I've managed to adjust it. I'm going to try and explain it as well as I can with my limited horology knowledge but I hope it helps someone in the future. There is a cam to the right of the front plate as shown in the picture. As the clock ticks along, the pin indicated in the gear comes around and slots into one of the silencer cam gaps, turning the cam. The pin completes a full rotation in 2 hours. To adjust the cam to start at the right time set the clock to just before 7. I did 6:45. Then I turned the silencer cam anticlockwise, which spins freely, until it pushed the silencer lever up and was placed just before the drop. Just before the 7AM indicated in the picture. All I then had to do was progress the hands to 7-7:15which made the pin slot into the silencer cam gap and turn the cam so the lever comes down again, unsilencing the clock. That was it. If anyone comes across this issue again I'd be happy to assist. Thanks again to everyone that helped. Hey Transporter! Thanks a lot for the reply. That was a really good explanation and I'm sure it would have made my troubleshooting a lot less painful haha. I'm sure someone will find it useful in the future. Thank you again for taking the time to try and help me out with this.
    • Now I'm completely confused, it would appear that the epilame  is oleophobic  as @Marc states: This oleophobic  behavior can be seen as beading of the droplet (as above) which stops the oil spreading which is supported by what we observe on treated/untreated cap stones (for example), but as @VWatchie states this should make the drops more mobile and is supported by the literature:   A review on control of droplet motion based on wettability modulation principles design strategies recent progress and applications.pdf   However the whole point is that we have less mobile oil so an oleophobic  would see to be the opposite of what we want. In fact this beading and high mobility are desirable properties in things like smart phone covers, see below.  I am fairly sure that epilame doesn't make the droplets more mobile, so maybe its a strange coating with dual properties that are both oleophobic (beading) and cohesive/adhesive resulting in low mobility?? This may explain the high price??
