Omega 1337 Movement
rogart63
Has an Omega Jaques Mayol 120 m watch incoming . Its a repair or parts watch with an Omega 1337 engine . Don't now if i could service it . Would be nice to see if i could get it going again . Any tips until then . Is their any one out there servicing quartz movement . Preferably Europe
Nice Omega, check this out:
I hope you find what you are looking for for servicing the Omega. Did you check out Mark's video on quartz servicing? Maybe it will help.
Cheers,
Bob
Nope .Is that thread in here somewhere ? Or is it youtube ?
Thats a bad one.   I have used before supplied by meadows & passmores "tarnish remover" followed by "rust remover"
Mark uses bicarbonate of soda. These products might help I but must say that is a real challenge.
Edited by clockboy
In a pinch a few drops of CocaCola would work too...but then it needs to be cleaned well!
Cheers,
Bob
PS. Not that the watch looks thirsty thought... :) I couldn't resist!
PS It does work on battery rust...
Edited by bobm12
We used to put copper coins into Coca Cola years ago - shone them up beautifully - lord knows what it does to one's stomach (I never drink it).
That's a challenging movement you have there, but it's looking better already. Good luck with it!
That cover plate cleaned up remarkably well ... very impressive.
The coil looks in good shape too.  Have you ohmed it out to see if it's a goer?
Is the IC Board is still viable? And is a replacement still available?
Yepp .Going to do the whole movement when i have time to dismount it  . Will post then  . Have a nicer movement on an auction site going . Hope it doesn't get to expensive . But sure will test to clean this up anyway . My electric nohow isn't that good but how do i Ohm it ? Have an ohm meter . The IC board is really a mess . Don't now if it works .
Ohms is an electrical unit of resistance. George Ohm named it after himself ... the sanctimonious scallywag! :P
Anyhoo, what you are trying to find here, is how much resistance has been created by the windings in that coil of wire.  Normally it will either be on spec, give no reading at all (an open circuit), or to low (a short in the wiring).
Each an every coil of wire, whether it be in a quartz watch, or the electric motor in a vibrator, will have a specific Ohm reading: depending on how the factory wound the coil.  Every coil is different, so you have to have the factory spec sheet to know what resistance it should have.
As an example: here is the spec sheet for the coil on an ETA 955.412 Movement.
You will have something similar for your caliber.
To test the coil, place the probes of the meter on the two copper pads connecting to the wire making up the coil (as shown below), and note the reading.
BE CAREFUL!  That wire is VERY fine and delicate.
Hope this helps mate ... and I wish you well on restoring this little gem :)
More pictures tomorrow . Have put in the keyless work and some other parts . Some of the wheel is in nafta over night . Will go in the UL tomorrow . Atl east i will try to get it to work again . If the electric doesn't work i will see if i could find it sometime in the future .
Don't do this :) . A really hard job getting all the gears in place . But now it's there ! First side finished .Geartrain running smooth . Haven't  measured the coil yet
Edited by rogart63
    • You need to know at least the basics. Then the questions that You ask will begin to make sense. From what is seen on the video, the gear train and escapement look fine, but the balance doesn't rotate free. I can suppose that the thin gold colored shim that must stay under the balance cock is not in place.
    • Yes, there are a lot of shapes and all of them are used in different cases. The one in Waltham A11 is one of the most spreaded and is what I have shown in the beginning. Of course, the radius of the final curve will depend on the distance between the hole in the stone and the regulator pins on the cock
    • I just found these. They don't really grab my eye at the moment, but having seen the change in some of the watches on here, before & after, the results have been pretty impressive. https://www.ebay.com.au/itm/196382906131?itmmeta=01HXBSJJXDB5J6H916ARJP9PHE&hash=item2db9555713:g:REwAAOSwUNdmOYAZ&itmprp=enc%3AAQAJAAAAwOAlUO3a1pAUX60Y8gUeXMPriraj5e7rkBNH2EA6cIUH7kb7hzoq6jRmOsYOQazk9R%2FteDESr1e50Asabv2tbJyDM%2FVODtmrAScFS4jPhHdgu6Jvt%2BFuRGBijpTkPl4NiK%2FDGr6qztc1Ujb33Tt6YdaUztOH9R1y9XJbwjH0puPDy8m0ilYcal7Vphcp7d59DLtBliNnbqfxfWhxdia2xMRyHYFHzR0Rg7NqB1z4xQGMZb73MAG4QBiF9FMkrII88Q%3D%3D|tkp%3ABk9SR_KuyvnqYw
    • I agree, it's getting harder and harder to find anything that meets the brief other than complete junk, or fake/frankenwatches. I would be in favor of raising the limit so people can continue to enjoy the challenge of resurrecting these low cost watches to their former glory and allowing the watchmaker the ability of practicing new skills without the worry of breaking the bank if all doesn't go to plan. Now all we need to do is settle on a value - maybe base the value on a standard currency so we are all playing by the same rules ($, £, €...?) Unless anyone minds I could start a poll and we could all vote on currency and value... let me know!
    • Same for me, but this is the first time I use the Bestfit. I understand that, for a 17-3/4 caliber, I have to consult page 150, but I can't find any resemblance. Thank you for all your research. I learn a little more each time I use this forum 😀
