Hello from Belgium !
HardTop
Hey there ! I'm HardTop and I am from Belgium.
I have some interest in vintage watches and I recently started learning a bit more about how mechanical watches work.
I have a a dozen watches or so, mostly "low value" ones but nice nonetheless. Some I keep for sentimental reasons (Citizen quartz from the 80's, Festina chrono from the 90's, Calypso watch from my late gramps, ...) some other as a small vintage collection (Lanco's from the 60's, a Seamaster also from the 60's, some other obscure mechanical watches from around that same period) and two pocket watches.
I started teaching myself how to perform some basic maintenance tasks on those watches, starting with "cheap" ones I found on eBay. I managed to pull a movement apart, replace some broken parts, reassemble the whole thing and have the watch still running OK. I guess that's better than nothing ;-)
I want to continue learning some tricks because this is really interesting and fun, rewarding, and overall a very cool skill to learn.
Anyway, thanks for your attention, I hope I'll be able to bring some of my own knowledge to this forum someday !
    • Next is to drill the screwhole this then provides an anchor point so the bridge doesnt slip around while scribing the shape. A cork lid, a pin and a piece of gaffer tape ( 😅 ) keeps it all in place. The hole is measured from the broken part using a hand measuring gauge. Mark the hole, punch it and drill it off to size. The awkward bit is working out where the jumper should be and the detent positions.  I remember watching a youtuber a while back do this with dividers, so i dug out my old school compasses and improvised a little. This bridge only has one hole and to find the detent positions you need two points of reference, so i just worked the second point from one of the corners, hopefully its near enough. Then scribe in the jumper using the two detent positions ( wind and time set ) that were marked and a big picture of the complete spring to look at that helps to give you a feel of where the jumper should be.
    • Right now I'm making do with a similar micrometer (the one below is $45 shipped but you can find better deals) and a $20 stand. You do have to be excruciatingly careful measuring jewels, since there's no table, but if you don't have the $500 to throw around, it's a nice option.
    • As  I kid, I'd watch Godzilla stomping over buildings and cars and I'd think to myself: Tokyo is a really dangerous place to live... . Cool watch!!
    • Next one up an AS 554, looks like a bit more to this one. First job is to check thickness, most springs are somewhere between .3 and .4, this one measures .35, that matches in with the .4 spring steel i ordered. So for marking up a permanent marker comes in handy to colour up the steel to be marked later with a scriber once its dry. Bestfit provide the extra bit of info for the jumper spring that is missing.
    • Thanks again, Marc.  Super helpful. I was wondering what the hole was for, and now it makes perfect sense. With your help and the other members here, it looks like I'm good to go with my Seitz tool set. I had to order some replacement pushers, but with those, the set is complete and in good condition. Now, I need to figure out what tool to buy to measure jewels (amongst other watch-related parts). I had my eye on the JKA Feintaster micrometers, but people get crazy bidding on them for $400-600 USD. I was thinking of just a regular digital micrometer (Mitutoyo). Thoughts?  Mahalo. Frank
