Newbie hobby watch repair here
URMINME
Hello everyone I am new to watch servicing and repair. I am looking for a repair or service manual or guide to the Miyota 82S0 how ever I have been unable to find anything at all, I have a watch that means a lot to me and I've stripped it and cleaned it but not sure in which order each part goes back and or the correct oiling points
Especially for beginners is always a good idea to take detailed pictures at every step.
I suggest that you practice on other, possibly similar mov't, you will then find that parts sequence and oiling point are always similar if not identical.
The video series below, although not as good as the ones by our Host Mark Lovick can also help. BTW enrolling in his training is the best way to learn.
Edited by jdm
Thank you all for being so kind and helpful it's been greatly appreciated, I've been on many forums for various things over the years and it's nice seeing people welcoming newcomers with out being rude, I have a old pocket watch I am going to attempt to disassemble and take images of every step so I can back track. Thanks again for all the great tips it has been very helpful
    • Hello, I am working on a eta 2970-1 and as soon as I screw down the rotor, the watch stops. The watch runs great without the automatic bridge, when I attach the automatic bridge, it continues to run well, but as soon as I attach the main rotor the watch stops. Can anyone please share schematics or pictures of the automatic bridge? I have looked up a few pictures online and it looks like I have assembled the bridge correctly after cleaning, but the fact that the watch stops as soon as the rotor puts counter pressure on the bridge, points me that there js something wrong with the automatic bridge. Thank you.
    • Thank you for your introduction and welcome to this friendly forum. We all look forward to your contributions and continued involvement.  This should help you.  704789946_TZIllustratedGlossary(2).pdf
    • I think you are right wish one of the two spring should make contact do you know what one?
    • So I was cleaning an especially dirty balance spring with B-dip because several turns were sticking together.  However, after a wash and dry, it seems there are more turns sticking due to the B-Dip.  I can see it clearly in-between the spring turns and it is not evaporating.  I even stretched the spring upwards a bit to let them air out and they continue to stick.  This is after two washes.  You can still see the liquid between the springs. Not sure if anyone has seen this, but I don't know if this is an indicator of my dip going bad or being contaminated.  I would rise with IPA, but the stud and collet aren't pinned--they are either glued or shellacked so I won't risk it.  If I keep seeing this, I'll probably switch back to a heptane or naphtha for this type of cleaning, but I wanted to see if anyone else has seen this with B-Dip.
