Vintage one day wind clock,cannot time it
chriseames168
Hi,hope someone can help me please.have a old vintage air spring one day wind up clock and cannot time it, the adjustment on the air spring is not doing anything,and the clock just running away and time is not any issues on the hands,how can you resolve this problem.been trying to adjust spring but beat goes out and stops.
I would say it could have had a different spring fitted and its to strong or it has the wrong hairspring. My guess its the main spring. Try a weaker spring. I cant tell by the photo but the movement looks like a 2 inch movement, if so it should be replaceable. Do you know the size?
Looking at today's clock part suppliers, it looks as if they only supply Quirts movements , no longer do they have the old 30 hour ones. So I don't know what you would like to do, look at suppliers and get a Quirts or try a weaker spring.
Hairsprings coil, should be flat, level and concentric.
It looks unlevel and  not concentric in the picture, likely to touch the main plate.
Luckily, It looks undamaged though, perhaps the regulator are in pushed down causing the coil to sit oblique.
Check what is causing the hairsprings to sit unlevel, it will time fine once hairsprings is sorted out.
Perhaps the picture did not open for OH.
Edited by Nucejoe
Correction Regulator arm is pushed down.
How do you get the regulator arm back up then please,if pushed down,
On 3/9/2020 at 10:04 PM, chriseames168 said:
Hairsprings coil clearly touches the regulator pin.as the coil expands in every oscillation, effectively shortening the active length of hairspring,  the coil is also not concentric and unlebel unlevel.  Therefore, runs fast.
The issue with the main spring OH is helping with, is totally another issue.
Hi   Has this clock been dismantled and cleaned,  and the balance re fitted because as Nucejoe explained the spring is not concentric and bearing on the regulator.  I would un pin the balancespring and remove the balance and check the concentricity of the spring and its flatness. Having done that re fit the balance .and refit the spring through the regulator slot and re pin lightly maintaining the flat profile and getting the balance in beat   you should be able to  move the regulator aroung the arc of the outer coil without it moving the coil, If that happens then the spring will require adjustment to achieve that aim. Without that timing the clock will be a lottery.
11 minutes ago, chriseames168 said:
Ok thank you,how do you stop the pin touching coil without it going out of beat.
Manipulate the hairspring to get all circles concentric. Mark teaches it in one of his lessons. Start by pushing on the free end of hairspring ( between reg pin and the stud)
I feel I must apologies for the remarks I have given about the problem with this clock. My eyes are not good these days, it wasn’t until a member mentioned that the hairspring wasn’t right that I magnified the photos to take a look. I could then see what the problem was. Well done members for sorting this out. I will now sit in the corner.
To our much beloved master watchmaker moderator  OH :bow::bow::bow: .
1 hour ago, oldhippy said:
If you have let the hairspring out as far as it will go and it is good between the regulator in all positions. I'm assuming the balance has a good action.  Then you need to try as I previously said a weaker mainspring.
Hi OH, Am I right to think, a mainspring partially wound, correspondingly delivers less torque. If so, for instance,  OP can wind a third of full, thence get less torque, in effect as if using  a weaker spring.
Hi Chris, will you mark on the pic the part you think a gear should be mounted on.
Hi  What sort of a rate error do you have, is is gaining substansialy,  You say the balance is running too fast, from that I deduce that it is gaining in time. If you could quantify it   e.g.   10min   per Hour.  and as Old Hippy said is the balance spring pinned at its limit and is the beat ok.     There is an app on the apple store (CLOCKMASTER ) which is handy for tuning clocks . I use it as a mobile device . There are others available but I personally found this one the best.              Cheers
    • It looks like the canon pinion function is part of this great wheel. The pinion nearest the clip runs the minute wheel on the dual side. The pinion nearest the wheel is driven by a small wheel from under the setting lever cover plate that engages in hand setting position.    So when assembled the crown was driving the whole great train. Does this mean the pinions are too tight? Should I attempt to disassemble this great wheel and lubricants?
    • Picking up this side-tracked post again as I just removed a balance staff of a 1920's Omega (35,5L-T1) I was impressed by the way @Delgetti had his setup when he had to change out a balance-staff (https://www.watchrepairtalk.com/topic/28854-new-balance-staff-not-riveting-to-balance/page/2/#comment-244054 Not only that, but also the idea of removing the seat first before punching the staff out from the seat-side, avoiding the whole discussion of the rivet yes/no enlarging the hole. I didn't have the fancy clamps & tools Delgetti has, so I used my screw-head polishing tool. Initially I used #1500 grit diamond paste on the steel wheel, which kinda worked, but very slow. I changed to #800 grit diamond paste, which worked better, but still slow. Then I glued #240 sanding paper to the steel disk; That worked and the disk was hand-driven. Once close to the balance wheel, I took the sanding paper off and continued with #800 diamond paste. One can only do this when the balance wheel sits true on the staff and has no "wobble". I went on grinding until I saw some diamond paste on the rim of the balance wheel. This was as far as I could grind and it seemed that there wasn't much left of the seat. Carefully, with my staking set, I knocked the staff from the seat-side out. Turns out that the thickness of the seat left, now a small ring, was only 0.1mm. The balance wheel hole is in perfect shape and no damage done to the wheel at all. Of course, if the wheel has a "wobble" or isn't seated true on the balance staff, you can't get as close and there will be more left of the seat. In my case, it worked perfect 🙂 I'm very happy how this method worked out ! 😊
    • As is tradition, one step forward, two steps back. Got the board populated and soldered into place without any issues.   But no hum. So I started testing the coils with an ohmmeter. I got 5.84k ohms across D1 (from red to red in the picture below), which is as expected. But I'm getting an open circuit for the other drive coil and feedback coil, D2 and F1 (from green to each of the two yellows).   Since the movement was working with my breadboard setup, it implies I somehow broke the connection between the coils and the solder lugs. They're all the way at the bottom of the lugs, but maybe the heat migrated down and broke the connections? I guess it's possible it happened while cleaning the flux off, but I used a soft artist's brush and isopropyl alcohol. I did a lot of high magnification examination, and I don't see any issues, but let me know if you see anything I missed or if you can think of anything else I should check.
    • 1947 NOS Ambassador 'C'. Actually, the case came without the movement so the movement isn't NOS, but she sure is pretty.
    • Hi attached is the AS 20XX. Service sheet although there is no 2063 mentioned it may be of some use to you AS_AS 2060,1,2,6,4,6.pdf
