How remove Certina movement? (KF 404)
Sorry for asking yet another how to remove movement question!!!
I have the back off and the crystal off.  It was not a split stem.
The movement and dial do not fit out the back or the front.  A conundrum indeed.
The movement and dial move front to back about 1/16 of an inch, so it is loose in there.  And it rotates freely.  But the front and the back of the case are not wide enough to get the movement and dial out.
I think the movement would come out the back if the dial were not attached.
There is a rubber gasket still on the back rim in the photos.
As always your help is much appreciated.
-George
Hi  The fact that it rotates ok and moves front to back ok and the movement locking screws are out there is not much left to hold it except probably the rubber locking gasket, But if it moves forwards enough for you to check and see is there are dial retaining screws around the edge of the movement and if so can you gain access to the  to remove the dial.   I have attaches some certina case details in the hope they might prove usefull.
Certina C0174101103700 Case.pdf
Certina C0174101103700 Case.pdf 167.92 kB · 1 downloa
Hi watchweasol, thank you for these PDF links, great.
In my book, you win the day everyday.
Thank you, as always, for your help.  Thanks for the PDF - not really what my case construction looks like.
The 2 movement retaining screws have been removed earlier.
I just scraped off some of the gasket material. (yellow arrow)
It looks like there is a metal ring inside the case.  (red line)  This is certainly what is preventing the movement/dial from coming out the back.  Do you think this ring is removable?  If so, how might that be done.
Any ideas on how to get the movement ring out?
can I use a back press and push it out from the front?
or
maybe remove all of the old gasket and put some penetrating oil around the ring?
Do they pry out?
Open to ideas.
I am beginning to think that with this watch stuff - knowing what to do is half the battle (that and not losing any of those tiny parts ;-)
Thanks so much.  Pried the ring up after taking out the gasket gunk and it came up after a bit of a battle.
Movement and dial and movement ring are out of the case!
    • I was pleased to pick up a selection of some tools on ebay (v cheap 🤣), and they've just arrived,  I've been looking for a crystal press for a while, and this one is ideal But in the selection is this thing - what is it for?  (it's about 3" long) Something to do with stem tubes?
    • You'll have to strip it back anyway.
    • I think I've heard that more than from just Alex. That doesn't make it right though, but I'm convinced i saw some literature diagram explaining why to do that. There must be good info here in the archives, I'll have to have a dig around.
    • That will mean dismantling the gear train, which with 5 pivots to align was a pain. Probably going to have to though. I'm convinced it's something to do with the great wheel.
    • As far as I know, the only time an epilame treatment has potential drawbacks is when something is rubbing on the treated part w/o lubrication in between creating abrasive dust. That is, I don't believe in the method of "running the watch to make a groove through it first in the pallet stones where the lubrication is then placed". So, I think the rule would be; do not epilame treat parts where rubbing is going on without lubrication. Other than that I don't think we have anything to worry about. That said, I'm not an expert, and I'm always happy to learn more. Has any other repairer than Alex suggested or explained the "making-a-groove" method? My impression is that it's just something he constructed in his mind. I have not perceived it as a generally practiced method. Again, I could be wrong!
