3 hours ago, MannyE said:
Then we can all watch the watch for the next few years and see how it does.
To each their own but count me out.
6 hours ago, MannyE said:
Actually, I think the silicone oil is the one that swells the gaskets.  I've seen watches that have spent years  filled with mineral oil that are still doing OK.
Unless silicone oil has a very different composition to silicone grease then your first comment is incorrect . And mineral oil (petroleum based)  absolutely will react with a rubber gasket. Hopefully the gaskets are from vulcanised rubber....but maybe not.
I use silicone grease with all rubber seals in plumbing applications. Mineral oil will degrade some rubbers and some plastics over time. Might take a few years but it will happen.   I have visions now of everyone that has mineral  oil filled a water resistant battery watch....quickly emptying out the fluid 🤣🤣🤣🤣
Pretty sure you were never in H 🤣🤣. Sounds like a cool idea... I'll try it on my past father's first digital watch , its about 50 years old, then I'll chuck it in the bin when half the insides turn into black goo 🤣
4 hours ago, oldhippy said:
There are always idiots on youtube.
Which creates more idiots that watch em OH 🤷‍♂️
Edited by Neverenoughwatches
Chronoglide did a video on a Bell&Ross Hydro which has some interesting info on "oiled" watches. They mention some things in there:
- The B&R hydro uses a standard lithium CR cell, for longer life and higher power (which helps overcome the additional friction)
- B&R was silicon oil
- The fun bit: To fill it *completely* it's filled through the crown tube. He even suggests using a watch case pressure tester to help force the air out
🤔 silicone oil eh. 🙂
I was working on a Seiko Kinetic the other day. It hadn't been oil-filled, but it wasn't far off!  There was oil everywhere, on the dial, even under the rotating bezel.  The movement was junk, replaced with a new one.
In the spirit of the general destruction of perfectly good time pieces that this thread embodies, I would like to point out that DOT5 brake fluid is mainly silicone oil with a few herbs and spices for rust inhibition and improved lubrication. Make of that what you will.
A note of caution for anybody daft enough to be interested in this observation, DOT3, DOT4 and DOT5.1 brake fluids probably would not be suitable for this game, as they contain glycol ethers, and may well dissolve some plastics. Always check the label before filling your perfectly serviceable watch with bizarre fluids. I take absolutely no responsibility whatsoever for anybody dissolving their watch/arm/cat/beloved family member when conducting said experiments.
Brake fluid also acts as a good paint stripper.
That's most probably the glycol ethers. Perhaps I should add "accidentally stripping the paint from the bonnet of your classic car" to the list in the above disclaimer.
It's these kinds of jokes that make me wake up with a scream in the middle of the night 😉
Seriously, oiling a watch is an art form. Filling it with oil is nothing but an abomination.
OK, I will never buy a Bell & Ross. I would never take the risk of degrading my brand name for a few extra bucks.
It strips car body paint beautifully, so if you have a particularly awkward vehical driver that insists on causing obstructions down your street ie.parking in front of or extremely close to driveways making exits and entrances difficult and the said driver pays no attention to polite requests to ease that situation then test its alternate use ( under the cover of darkness ).  Just a suggestion not a practice ahem.
At least they use silicone oil not mineral oil 😄
If he makes regular updates on this mineral oil filled Casio, I'll keep posting them.  This is after 3 months.  But forget about the oil filling...  THE LUME mod is amazing.  I'm totally gonna do this.
    • Why do you think this is Fontainemelon ?
    • Hi Watchrepairtalk, I have some questions about part sourcing I was hoping someone here might be able to help with. I'm working on an FHF 180 movement with a broken balance staff, broken regulator pins, and damaged cap jewels (both top and bottom). Some Googling says that this is similar to other FHF calibers like 150s, 160s, 180s and so on but I can't figure out what the functional difference is between these movements.  Is there any reason I wouldn't be able to acquire a donor FHF 150 or similar (with no shock protection) and use parts from that or would it be smarter to source replacements individually? Also are there any sources someone could recommend to get bulk cap jewels like this? Thank you for the help!
    • Hello and welcome to the WRT forum.
    • interesting video nice to see the machine what it can do now I wonder what it costs and I'm sure it's not in my budget. Plus the video brought up questions but the website below answers the questions? What was bothering me was the size of his machine 4 mm because I thought it was bigger than that? But then it occurred to me that maybe they had variations it looks like four, seven and 10. With the seven and 10 being the best because way more tool positions in way more rotating tools. Although I bet you all the rotating tools are probably separate cost https://www.tornos.com/en/content/swissnano   Then as we been talking about Sherline. Just so that everyone's aware of this they have another division their industrial division where you can buy bits and pieces. I have a link below that shows that just in case you don't want to have the entire machine you just need bits and pieces. https://www.sherline.com/product-category/industrial-products-division/   Let's see what we can do with the concept I explained up above and bits and pieces. For one thing you can make a really tiny gear very tiny like perhaps you're going to make a watch. Then another version the center part is not separate it is all machined from one piece. Then fills gear cutting machines have gone through multiple of evolutions. A lot of it based on what he wanted to make like he was going to make a watch unfortunately eyesight issues have prevented that. Another reason why you should start projects like this much sooner when your eyesight is really good or perhaps start on watches first and then move the clocks then local we have from the industrial division? Looks like two separate motors and heads. Then it's hard to see but this entire thing is built on top of a much larger milling machine as a larger milling machine gave a very solid platform to build everything.   Then like everything else that had multiple generations are versions the indexing went through of course variations like above is one version and the one below was the last version. Now the version below I mentioned that previously and somewhere in the beginning to discussion and somebody else had one in their picture. As it is a really nice precision indexing. Then I wasn't sure if I had a the watch photos here is his unfinished watch. No he wasn't going to make a simple watch like none of his clocks were simply either what would be the challenge and that.
    • Use a Portwest Howie lab coat. They are the biological type so they have tapped cuffs so you don't end up getting the loose cuffs of normal lab coats catching everything.
