Cleaning the pallet fork and balance
vext01
Hi everyone,
I recently read on a forum that you should not clean the pallet fork or the balance with IPA alcohol.
I knew that you shouldn't use IPA on the pallet fork, as it removes the shellac, but why not the balance? And what would you use on these components instead if you were on a budget?
I've recently serviced a Vostok movement where I *did* clean the balance with IPA. No damage was done and the watch works fine, but now I'm curious.
Thanks
The impulse jewel on the balance is usually fixed with shellac too. One way to clean on a budget is to soak / brush / ultrasonic with lighter fuel, then a quick rinse in ipa to get rid of any residues and dry with a blower. Some people on here will not take the risk of getting alcohol on shellac, because it will soften it and dissolve it eventually, but the general consensus is that a few minutes contact don't hurt. Also, ammonia-based cleaners work well and are not too expensive. Then a rinse in alcohol is a good way to finish, because it drives off the water then evaporates without trace.
Just to remind once more that lighter fuel contains oils and fragrances that make it poorly suited in this time - it's formulated to burn not to clean.
Petroleum ether aka is actually cheaper in quantity and easily available.
jdm could be right about the "lighter fuel". it's a general term as far as I know, and some solutions may have oils etc. added which leave unwanted traces behind. That's why a rinse in alcohol after is a good idea. The purest ipa is not that easy to find though, and not that cheap when you find it.
For the record, this is the "lighter fuel" I use, 5 to 6 Euros for a 1 litre tin.
    • I agree with @JohnR725. Oil on an epilamed surface is essentially the same as water on a waxed surface. The same physical properties are at work (surface tension vs. adhesion).
    • I think we all get a lot out of this group, and it has been pivotal in my development by the sharing of knowledge, experience and learning from more seasoned experts such as @JohnR725 and others (you know who you are!) as well as fellow novices. I think that having a backup communication plan in reserve so that if there is a future problem just makes good sense. I don't think anyone is trying to undermine the forum, but if something unthinkable happens, like the Ranfft website for example, then it would be good if those who are willing can still keep in contact. Speaking personally, and I know I risk a charge of heresy, it would be good if Mark could be a little more visible in this forum, and maybe give any insight from time to time on the future/progress of forum and instructional videos etc. even if its just to confirm the status quo. I appreciate he is a busy man with a full time job, but so are most of the rest of us and to post a few lines every now and then shouldn't be too much to ask to reassure the restless villagers. Best outcome for me would be a message saying something along the lines of: "Hi guys, all good, no planned changes... enjoy the forum, will message again next month!" Just my two cents.
    • A nice looking watch !! Did you try 9010, instead of the 9415, on the pallet jewels / escape wheel? And if you did, did you notice a difference?
    • Knocked out another 404 last night...when you are in the zone! This watch was a non-runner which I picked up as part of a lot of 8 watches, so works out to be $3.12 per watch. Before:   And the finished watch, new crown and stem and the crystal was cracked so was replaced. I also replaced the mainspring as the original was the old steel type spiral and very 'set' - all else is original: The Movement was a AS 1686, but in reading around a little the ACCRO watch company were sued for their use of the five point crown on their Jacques Pere range as it resembled Rolex, see below: ACCRO then reverted to just ACCRO on their watches - I have done some sniffing around the internet and haven't seen another example of ACCRO and the crown together on a dial so maybe I have something unusual, or maybe I was looking in the wrong places 🙂.
    • This watch was damaged when I got it. I didn't break the escape wheel pivot, and I bodged a fix with epoxy to see if I could get it running. I'm not yet ready to get into lathe work, or shellacking jewels, and may never be. But I'm learning plenty with each watch I tackle.
