Made a tool for probing hair springs
Colditz
I needed a tool for probing hair springs. I could not find one so I made one.
Here are the pics.
Materials:-
Handle - Brass 5mm hex
Probe wire - 0.3mm stainless steel from a wire brush.
Drilled a 0.4 mm hole and Haroldited the probe wire in the handle.
All anti magnetic.
Edited by Colditz
added written detail
No Problem JDM thank you for the heads up.
As you can probably tell I an still not site familiar. Probing an hair spring when it is slightly distorted particularly in the case of pocket watches. I needed something that was stiff enough but thin enough to manipulate the spring.
I see. That is normally called "correcting" or "manipulating". We have some topics where specific tools are discussed, there should be more.
3 hours ago, jdm said:
Sorry, what is "probing an hair spring"?
BTW, there  a section for discussing tools. "chat about anything else" should about for whatever that is not about watches. Please forgive me for being pedantic.
"Chat About Anything Here
Talk about whatever you fancy within the forum rules, not just about watches."
I found it useful information, probe things all the time and seldom look at the tools section.
Anything here means that to me.   Not JUST about watches does not preclude watches and tools.
Perhaps there is a language barrier at work.
  • Confused 1
    • I think that a 814/825 stem would work, there are a lot of compatible parts between these.
    • Hi everyone, I put together a Venus 178 recently, but found that the hour counter "creeps" ie. runs when the chrono is disengaged. This is the similar type of setup as the Omega 861, where the hour counter is driven off the mainspring barrel, but stopped when the chrono is disengaged by a friction spring.  Am I correct in assuming that the friction spring for the hour counter driving pinion should be dry? I am guessing that the issue will be either the spring or the driving pinion, but while the driving pinion has some wear the spring looks decent.  I've attached a couple of photos in case anyone has any tips. Thanks in advance!
    • Thanks everyone for the replies. It seems setting the hand is a bit of a guessing game, and I thought there would be a very specific way to do it. Since the reserve indicator hand moves clockwise as the spring is wound, I tried setting it right at the start of the black side. But setting it there doesn't really make sense, because by the time the spring is halfway wound, the hand is only at the end of the red side... In my head halfway wound shouldn't mean the hand is still "in the red."
    • Lovely part of the country! I spend most of my days driving along the A64 for work in and around York. I'll be sure to drop plenty of questions soon! I've actually got a couple of watches on the way that I'm pretty sure I'll need some help with! They look pretty beat up from the pics but I love a challenge and an excuse to buy more tools 🤣
    • I have two of these in my home. You need to remove the movement from the case, take off the hands and remove the dial and take a few good photos of the front plate so I can see what the problem is. The round nut unscrews and the hands pull off pull them off from the center and not the tips as you could break them.
