Gucci 9300
Dylan123
Hello there, I have recently acquired a gucci 9300 watch. It's a chronograph and as far as I can see looks akin to other pictures of this watch on the internet. None of the hands are moving however I think that  this Is due to the fact that it hasn't been worn/serviced/touched for a few years. I have purchased a watch repair kit and am thinking of replacing the battery and maybe adjusting the links. Any advice on this, what battery to use, things to look out for ect.
Any help greatly appreciated thanks for your time,
Dylan.
Any first brand battery is fine. Being it a quartz watches there are chances that it will not work anyway due to the module being faulty. Work carefully to not lose or damage parts. There is many many videos you can watch on the internet.
9 hours ago, Dylan123 said:
Do you know what type of battery?
Begin by opening it (ideal for beginners is a lever-type snap case back opener). You may also need a small press to close it. Then identify the battery which is easy to obtain at electronic stores or even online. If the time and cost associated with the above is excessive then I recommend that you continue having a watch shop to do that for you.
Hi Dylan one can only second the advise given by jdm , the only way to find the battery type is to open the watch,  check the battery terminals for corrosion, A green crystaline deposit. If the watch has been stored with the battery in there is always the possibility of it leaking due to age.      All the best
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
    • No problem to replace the setting with the staking set. Press the new setting from inside, use flat face punch with hole. The punch must be wider than the setting, the hole to be as not to press at the stone, but only on the bush. Press by hand until the setting gets flush with the plate surface, so the punch must rest on it.
    • Yes, the arbor usually makes about 3 to 3.5 turns. But usually spring takes 2/3 to 3/4 of the free space in barrel, not 1/2, so take it for the calcullations. This way the change in torque is smaller. I have a picture for You, this one is little older, but no mater
