Pin pallet question
Fellow horologists, happy new year to you all and thanks for all the help so far and in the coming years.
Right here we go, I’m wondering wether or how do you set a pin pallet movement in beat?
as there are no pins for the pallet there is no visual reference of where the impulse jewel should sit when at rest.
So having read a few of Mr De Carle books where pin pallets are mentioned but he doesn’t mention anything about putting in beat.
Yes I saw that also, and the manipulation of the pin arms themselves for the correct lock etc.
I was wondering if there was a ref point to work from for the impulse jewel ( ok it doesn’t have a jewel but a nice piece of brass ) to be in line.
If the movement is powered down the impulse jewel sits off centre to the fork.
Let the balance wheel come to rest, the impulse pin/jewel is in beat, if a slight turn (in clock/anticlock direction ) of the balance wheel , lets the escape wheel/teeth to the verge of drop or lock.
At TDC ( top dead center) of balance wheel, ( balance pivot  & impulse pin & escape arbor fall on a streight line).
So mark the balance wheel ( at rest) and main plate so the two marks are in front of each other, turn balance wheel to the point you see the pin( pallet) about to drop or lock. The arch you have turned the balance wheel, is how much the roller or hairspring is to be adjusted.
Regards joe
No book, no school, that is a simple common sense approach to all mech timings, be it timing valves in automobile engines, escapement or else.
You would keep an eye on escape wheel,( for instance )observe when its about to do a drop you mark the angular position balance wheel is at, at that instance, that is when the fork is about to receive energy from the drop and deliver it ( the energy in the form of impulse) to the impulse pin/jewel, you want the delivery to happen at the instance the guard pin is in roller hollow. Think about the workings of escape mech,  the whole picture will come to you, you will master the approach,  in couple of tries.
Best wishes.
Hi  T  de Carles book chapter 6 there are several pages explaining the pin pallet operation and adjustment. Mine is the second edition and quite old. But as Joe explains its just a job of observing the lockings and making any adjustment as required. In beat is when the arm of the fork is centered between the index/banking pins at rest no powerand the pallet pins are just about to release and lock to achieve this its the same as theJewel lever done by adjusting the balance spring on the staff to achieve the center.
Hi  T  If you wish to delve deeper into pin pallet types and repair there is a book by Robert D Porter who seems to be the expert on pin pallets Amazon £35   ASIN B0006QQYE4  there is no ISBN number for it,  I have seen copies on ebay but all seem to be from America
2 hours ago, transporter said:
Just looked at that book and it appears to be more for clocks. I’m working on a pin pallet pocket watch, although I might still get it and add it to my growing collection
   that book?    what is the title?     vin
    • I loved his explanation of a teardown 😅 Ex military Richard Perrett, pretty knowledgeable guy.
    • I also see a bit of danger for the wheel, at least you have to keep away from it and may get a too thick rest ring. My rest rings are about 0.05 mm. Better way would be a grinding wheel touching the staff with its circumference. Frank
    • Not easy to find this one everywhere,  so it depends where you are located. Joining it back together might be possible, i have silver soldered mild steel before even with traditional plumbers lead and its a pretty strong joint, but bere in mind this is only 1mm diameter.  The join would need to be very accurate,  it not something i have heard of anyone trying before. The part no 401 is the swiss code number and relates to watch winding stems in general
    • Thanks everyone for your helpful replies. I think between us we’ve worked out what’s going on. Next job is to have a proper look at this great wheel assembly, see if I can remove the clip and the friction fit pinion, give the bits a good clean, then put it back together with a bit of blue grease. I’ll also get the pallet fork under the microscope to see if it’s ok or been damaged.
    • The cannon pinion (be it conventional style or what you see in this movement) should slip on its arbour so the hands can be set independently without affecting the gear train.  If there is too much friction between the cannon pinion and the second wheel, turning the hands to set them backwards can sometimes force the escape wheel teeth to overrun the pallet stones, creating the behaviour you describe. The train is running in reverse when this happens.  This can often chip the pallet stones. I’d say at least half of the watches I’ve inspected with very tight cannon pinions had chipped pallet stones. Hopefully this isn’t the case with your watch.  I’m not familiar with this movement but you need to get the friction in the cannon pinion adjusted correctly.  Hope this helps, Mark
