bluewarrior
Hi every one, I'm a complete novice when it comes to watch repairs, in fact my background is in heavy engineering. I have an Omega Genive  that I inherited from my Dad. The watch works well but the crown separated from the stem. I have the crown and I've removed the stem. My question is how do I reconnect the crown to the stem ?
Hi  Is the stem removed from the watch as well or is it just the crown which has become detached.  A good clear picture of the movement from the back and also the calibre number of the watch. Usually on the plate near or under the balance wheel and cock. The number will be like    705 or 522 .
Hi  Looking at the pics the stem end looks worn, This may be why it comes loose. I would recommend a new stem, available from cousins uk.  Cut the new stem to size ( same as old one) with top cutters and stone the end conical ( slight bevel) this will aid fitting the crown. Dry fit every thing to be sure its right then remove the stem and crown, put a drop of loctite on the stem and re fit the button, hopefully job done.
    • As I'm only cleaning watches in small numbers at home, I pre-clean any significant deposits of old grease and oil before using the cleaning solutions. I scrape off deposits with pegwood and Rodico, and if really dirty, wash parts in naphtha with a brush.  So I'm happy using DX, but can understand why it's avoided by the pros.
    • I think attaching a nut to the lid to pull it off is the least destructive, any damage damage on the outside is going to an easier fix than any created when trying to push it out from the inside. Scratching up the inside of the lid , mainspring or arbor bearing will be risk. Just my opinion.
    • yes the things we read in the universe I did see some where it was either difficult to clean off or it contaminated the cleaning fluid there was some issue with cleaning. I was trying to remember something about grease where as opposed to a substance of a specific consistency they were suggesting it had a base oil with something to thicken it. That conceivably could indicate that the two could separate and that would be an issue. But there is something else going on here that I had remembered so I have a link below and the description of the 9501 notice the word that I highlighted? Notice that word appears quite a bit on this particular page like 9415 has that property all so they 8200 mainspring grease and that definitely has to be mixed up when you go to use it because it definitely separates. just in case you didn't remember that nifty word there is a Wikipedia entry. https://en.wikipedia.org/wiki/Thixotropy   https://www.moebius-lubricants.ch/en/products/greases I wonder if what you're seeing is the boron nitride left behind after cleaning. In other words it's the high-pressure part of the grease and it's probably embedding itself into the metal which is why it doesn't clean off and shouldn't be a problem?
    • Hi not found one either yet,  close relative is the 436 and 4361 according to ranff.db.   It gives quire a lot of detail but not as good as the old site.      RANFF.DB.
