Help replacing chronograph pusher tubes
Chopin
Can someone tell me if these tubes are replaceable or not ? While trying to remove one I managed to damage it badly. The thing that makes me think that they are not part of the case is the fact that they both sit at different heights inside the case. Are these screw in ?
Trying to unscrew the damaged one but it doesn't seem to move.
The reason I wanted to remove them is stupidity and the fact that it's missing a pusher so for some reason I thought that it was appropriate to try and remove the tubes. I've done a  booboo, I know.
6 minutes ago, Chopin said:
I won't be attempting to remove the other, the problem is that the one that I tried removing is now really damaged and needs to be screwed out.
Any tips ?
Unless there is damage to the inner side or how the pusher works, leave it alone.
21 minutes ago, Chopin said:
The damage is bad. It has to be replaced. I have to get it out. :(
You can use a screw extractor. Search Internet to see what is that. Heat well the case around the tube before and proceed carefully.
Edited by jdm
Equivalent tool for a much more reasonable price.
https://www.aliexpress.com/item/4000298591084.html
Lol. I was trying to be all watch maker uppity....the one you shared is actually the one I have. Ive learned that for every ridiculously overpriced watch tool there is a cheap chinese knock off. The trick is knowing when the knock off is decent enough. Some times the chinese knock offs arent worth the cost to ship them.
Sent from my SM-G950U using Tapatalk
Alright, I managed to extract what was left of the tube.
Guess what ? It was a freaking push in tube, not screw in.
I thought that those that have those little threads/spikes on the edges are supposed to be screw in... Oh well, another lesson learned. Thanks guys! Panic mode off. :)
I had tried pushing it out but couldn't so assumed that it's screw in.
Edited by Chopin
Out of curiosity, is it possible to extract these push in (or should I say drive in) tubes without one of those expensive tools ?
Once I was able to install the tubes by using a crystal press (and improvising a bit) but don't know I could go ahead and remove the remaining one. The reason I'd like to remove it is to measure it so that I'll know what replacements to order... Do I even need to know the dimensions of that tube ?
    there are 2 types of  screw extractors available.  the square and the spyroll.   i like the square.    vin
17 minutes ago, bjd1020 said:
    is there a "tool maker"  in the house?      vin
SEND ME YOUR SKETCHES
I HAVE CNC CAPABILITIES
  they are listed in any tool catalog  - you can make the square ones out of "key stock".  vin
Managed to remove both of them and they got damaged in the process but one pusher was missing so I'll get a new pair anyway. The thing is that I've looked a bit on CousinsUK and so far those on the website don't exactly seem to fit my required dimensions.
For example all pusher diameters are in increments of .50mm. Mine is 4,8mm I believe... Being bigger might not hurt but the hole diameter seems to be 5,2mm so I'm not sure if it'll be a safe fit. Same goes for other dimensions as well, hopefully I'll manage to pull this through.
    • Good question!! Anyone know of a substitute movement??!! 🤔🙏
    • Interesting issue that I just noticed: this Seiko 5actus Watch from 1977 has a calibre listing on the dial of 7019-8030R but on the case back it says 7019-8010!! Like a mis-printed coin, is this watch therefore worth a lot of money for its rarity?? 🤪😲🤔🤪
    • I wish that was the case. The Aegler movements used in the early days by Wilsdorf & Davis (for brands like Rolex and Rolco) came in several sizes and without designated calibre numbers that survive.  They become a bit easier to identify during the 1920s. Below is an Aegler-Rebberg, 25.74mm in diameter. It’s from a woman’s Rolex wristwatch. Stamped Rebberg and 500 on the dial plate (but it isn’t a Rebberg 500, it’s the wrong size).  I’d be interested if anyone can identify the movement.  It is based off the Aegler Nr.1, circa 1903, but they based many many calibres of different sizes on it. The closest I have to a positive ID is the  ‘Rolex Nr.50’ circa 1917, but no dial side images or movement sizes are available in the references. There are identical looking movements in many sizes.  The 25.74mm of this movement is a particularly strange size for the era, it equates to 11.41 lignes.      Best Regards, Mark
    • It looks like this movement comes with a number of different shock settings. Emmywatch shows that it comes in versions with no shock settings, 'Incabloc', 'shock resist', and 'Supershock'. Perhaps the different settings position the impulse jewel/roller table in a non-ideal position relative to the pallet fork/guard pin. Are you able to check under high magnification if the pallet fork and roller table are able to operate without any interference? Just for fun I took a look and I have one FHF 70 in my collection, a West End Secundus with a non-shock protected FHF70. I had a note with the watch that said, "Movement is stamped 'FHF 70', but the FHF70 looks to have sub-seconds instead of center seconds movement (??)" but that a google search turned up both types for this movement. EDIT: I just took a look in my parts drawer and I have a few of these movements, both in center seconds and sweep seconds, but they all are non-shock protected.
    • Any info on this watch would help. I know that it's sterling from London but I could not match the o letter date or make out makers mark.  Is the movement maker Camberwell or Lamberwell?   If I give it a twist it will run for about ten seconds.  $45 yard sale find.  I don't think that I want to service a fusee.  What quality is it?
